I have this really simple lighting rule where a door contact sensor to a closet turns a light on or off. All running fine and dandy, but the other day my GF was running back and forth ending up forgetting to close the door, and the light stayed on resulting in a never ending low-WAF tirade about "home automation this-and-that".
So I thought I'd fix it by simply add a timeout after given amount of time. The way I interpret the option "After this number of minutes" is: "after you close the door, delay turning off the light by X minutes", is that correct?
If so, this is perfect for a hallway light controlled by an entrance door, but not suitable for my scenario: "if the door is left open, wait X minutes, then turn the light of regardless if the contact sensor is open".
Conditions: Closet Door Sensor open
Rule: Closet Door Sensor open
Actions for true: Set Closet Lights to 99, turn Closet Lights off after X minutes
Actions for false: turn off Closet Lights
This will turn them on when the door is open, and turn them off when the door is closed. It will also turn them off if the door is left open after X minutes.
RM: something about the logic that seems a tad backwards to me - perfect time to get my feet wet. Your explanations kind of makes sense
thinking out loud the static rule "Closet door sensor open" always kicks off timer when, in fact, the door sensor is open. If false (closed) turn the light off. Ya, makes sense. Thanks!
My goal is to follow @bravenel's suggestion and have my closet light turn on when the door open, and off when closed. if left open, I want the light to turn off after 6 mins.
