Shelly uni
Hi, just got a Shelly uni.
Sadly there is not informations on how to set it up. I connected it to my router via the browser Shelly implementation. Just got the message you can now find it under its new address. No clue what that address should be…
Also no clue how to implement it into Hubitat…
There is just nothing I can find.
Regards for help
There is a community driver created by @TomW for the Uni. Here is some information on it:
As for the IP address of the unit, this information should be available from your internet router (assuming this is the device that has the DHCP server on it).
This post has installation instructions for HPM if you want to use my Uni driver: Vote for Shelly UNI - #16 by tomw
Thank you very much. I could find the IP. also thank you for the driver links. Probably i need to define what driver I want to use first to add the shelly to my devices...
Thank you. Also for the work to code and give the driver to others :slight_smile:
BTW: the only coding I know is GDL. But that, I use nearly daily. Now I did a dip into Groovy to learn it and hope I'll be able to code some drivers too.
