Not necessarily, On average it takes about 5 -30 seconds to pick the average home lock for a professional. I was going to post some videos of people getting into some locks with a single rake in less than two seconds but decided against it.
Not true.
Depends on the state you live in. Any tool can be considered a burglary tool.
This will be my last post regarding this topic. I knew I shouldn't have posted this.
Exactly my point. But if the burglars are in possession of no tolls at all, then they can't be in possession of burglary tools, can they. You can kick a door in with your foot.
Well, this guy obviously isn't a professional because he's breaking into a house with a security system. Houses without security systems are 3 times more likely to be broken into. And to counter that...
Literally less than 2 seconds. If you weren't watching closely, you'd miss it.
If you want to start pulling anecdotal evidence, you can. But statistics are not on your side. A full 23% of burglaries in the US take place by entry through a window. Did they have to pick a lock to gain entry that way?
Well, for burglaries in 2019, only 9% of entries were made throgh a garage. It doesn't get specific enough to say if that was through a garage door or a garage window.
The most surprising statistic...2% were made through entry through the second floor! I am surprised its that high. I would have thought it would have been less than 1%.
The saddest statistic, 4% of entries were made through an unlocked door. Come on people! It's not 1950 anymore. Lock your doors!
Yeah, the Schlage commercial locks are tough and bump resistant. The locks built into their line of smart locks are not up to that same standard.
You want into my house, the fastest way is going to be to kick the door in and grab what you can while the alarm is blaring away and the police are hopefully in route.
Agreed, but the residential lock pins are superior to Yale and Kwik-set pins. You will get false sets on the Schlage not so much on the others. I didn't start this for a debate. It was just another thing to consider.
I'm curious...do you have a spare 9v in your car, just in case? Or do you just change the batteries in the lock well before they get near dead to prevent you needing one? I've considered some of the keyless locks but not having a backup key kinda scares me a bit.
I thought of that, but temps are too cold here. The battery would have to warm up before i could use it. But you wouldn't even need to put it in a lock box...just a weatherproof box. I guess you'd just have to keep it locked to keep someone from stealing the battery.
