My Problem is for every 30 minuets the lights switch changes, if they are on, they turn off, if they are off they turn on? This is where I am lost. I just want them to turn off every time.
Trigger
Front lights change
Certain time sunrise
Certain time sunset
If
Time is between sunrise and sunset
And
Front light switch is on
Then
Turn off front light
Else if
Time is between sunset and sunrise
And
Light is off
Then
turn on
endif
This should turn off if it gets turned on and in on it gets turned off between times. It works perfectly for me and should also trigger on at sunset and off at sunrise.
I don't see any problems with your rule, and it doesn't look like Rule Machine (app:104 in your logs) is turning them on, so I suspect you have some other app/automation that is doing that instead. What does the "In Use By" section for one of the affected lights/switches look like? Are you sure some other automation isn't responsible for this? And since it appears to be Caseta or RA2 (based on your telnet logs), could you have something on the Lutron side configured too that you wouldn't see in Hubitat?
So the rule is because I get home before sunrise sometimes and I have a rule to turn them on when I get home. Once I am home and the sun comes up, I want the lights to turn off. I realize most people don't have schedules that they get home before sunrise, but this house does all the time.
Point number 2, I am running X10 devices with node-red app. So apps:
dev-1 is Mochad-Client
app4 - is the X-10 Node Red-Bridge
app7- is the Driveway Light
app17 - Garage Workbench Light
app24- Back Flood Light
