@patrick, here's my experience on MacOSX 10.13.6 in Chrome Version 67.0.3396.99: the dashboard page locks up completely when adding the attribute tile. Any attempt to open the same dashboard throws the same error.
Meanwhile this is going on with the dashboard timing out, the main hub page is glacially slow and control isn't released for quite a while after closing the dashboard page.
I noticed the same issue (assigning button numbers). For ABC I have to manually tell the app how many buttons my switches have since it doesn’t seem to automatically detect it. Would it be possible to have the same option here?
It’s the Generic Z-Wave CentralScene Switch driver. Or, if it’s a dimmer switch it’s Generic Z-Wave CentralScene Dimmer. They’re built in to the Hubitat.
numberOfButtons is set when the driver is installed, since this driver was replaced manually, installed didn't run...
I can add it to configure... @murray.sean.d can you send me the fingerprint info on both the switch and dimmer?
I'd like to get that added to these drivers.
I did have to manually change the driver since it didn’t detect it originally. Is the fingerprint something I can view in device status somewhere, or do I need to exclude and re-pair a switch and dimmer to get it?
Ahh, ok. Thanks. Below is the fingerprints for the switch and dimmer. Also, when I just did a quick search on how to find the fingerprint (before seeing your reply) I saw a post mentioning the need to hit the configure button in the device status after changing a driver. That’s not something I was aware of, and I don’t believe I did it for any of my switches and dimmers. Should I go back at this point and press that button for each one?
that is the best practice when changing drivers manually, most drivers have settings that should be applied in order to interact with the device properly.
This happens automatically when the device pairs with a matching driver, but needs to be done manually anytime you replace the driver with a different one.
The button count issue however won't be fixed until the next release comes out, when it does you should click configure again, and the buttonCount attribute will be set.
