Rooms Manager: Smarter Rooms: Personalized home automation with Occupancy
time restrictions are a bit different from what happens only on state change that @murray.sean.d and i were debugging earlier.
when you do this also turn off the flag in general settings to turn off all switches when rules dont match and this will work fine.
the only reason rules deletes are not supported is because ST does not support a way to remove input settings. HE does allow that now. i will see if i can support this with HE.
but as mentioned before dont think the disabled rules were causing this. because the turn off all switches when rules dont match flag is on by default … it was turning off the switches outside of the rules time restrictions.
another way to do this is to use the locked state. the locked state is there for specifically controlling switches etc in the room manually without rules being processed.
If I set Turn off all switches to false, wouldn't I then have to handle the vacant state so the lights would turn off during the restriction bubble?
Yea.... cant find the problem, i will look at it again tomorrow. I’ll let you know
right. that is the purpose of that flag so normally dont have to create a rule to turn off lights for vacant state.
if you do turn off the flag you can just create another rule for the vacant state which turns off light with vacant state when within that time restriction.
or use the locked state for when you want to control the lights manually. you can use switch || power value || contact to set room to locked. if you want to use a button push, hold or double tap to set and unset locked state i can add that as well to locked settings.
Occupancy Icon, I added it to my dashboard and it shows up like this:
any suggestions on making it a little bigger?
Ah. I've been seeing this wrong. I will begin implementing vacant rules where I need restrictions.
occupancy icon should look like this:
please check the following:
  1. room device has been added to that dashboard in the app -> choose devices
  2. in the dashboard you are using attribute / occupancyIcon:
I consistently crash my dashboard and the hub stalls when adding a new attribute tile and enter "occupancyIcon" :frowning:
i use those icons in many dashboards … havent seen that happen … is the icon too big for the size of the tile … maybe? any error in the logs?
i will publish a new version today where i have removed html breaks to see if the resizing works better. please give that a try again after updating.
edit: i just crashed my dashboard by making the tiles too small for the icon. :slight_smile:
Mine doesn't crash, it is just empty.Screenshot_20180803-132737|281x500
cant see the screenshot here but from the previous screenshot see that there is no image.
please go to the room in devices and check what the value of occupancyIcon is in the state for the device.
then check these:
@bangali Please let me know if you find a solution tho the dashboard crashing issue. I was unable to find a way to avoid crashing with my custom driver as well. Thought I fixed it a few times but eventually the dashboard would crash.
i actually havent spent any time on the issue. whenever i am going to use the occupancy icon i just make sure the tiles are big enough on that dashboard.
the simplest solution would be for HE to allow specifying a state variable as image URL.
Not sure what you mean by this.
as an example … the image size of the occupancy icon is 156x156. the dashboard tile icon display area needs to be larger than this otherwise the dashboard is likely to crash.
Still no icon picture, wierd.
has the occupancy changed since you updated the tile on dashboard?
does the icon show in the state for room device?
yes and yes, it isn't a big deal since I am also using occupancy
is the dashboard tile big enough for 156x156 image? if not please try changing the tile to be large enough excluding the header and footer then trigger a occupancy change to see if it shows up.
I figured I'd try the occupancyIcon attribute. My dashboard also crashed. Any attempt to reload results in just the loading spinner. Chrome will report unresponsiveness, Edge does nothing. No errors go into the console.
