Did you see my post just above? Switch that device to "Room Lights Activator", instead of "Room Lights Activator Bulb". Fix for this in next release.
I did. Nice to see you are adding the button property.
Dashboards for Scenes
How do I set the dashboard to use a button type for an activator? I changed the type from the default color bulb to button 1 press, but it does not work. If I set it to a switch, the behaviour is stateful. If I activate family bright(on) then family dark(on), then family bright(off) all the lights are turned off. Should the default for an automation activator not be a button?
What you've shown in the screenshot has a tile for Family Bright as button. This works for me. Please show logs of it not working, for either Room Lights or the Activation Device itself.
48 posts were split to a new topic: Room Lights, Toggle per Mode
3 posts were merged into an existing topic: Room Lights, Toggle per Mode
