I've got it (supposedly) showing all actions, etc. but when I arm my Ring for night it's not doing the steps under that section. The weird thing is if I go into the rule and manually "Run Actions" it will do the correct ones as it does see the correct mode.
Anyone have any ideas? This was all working fine for months.
Ever since this update my whole hub locks up and won't respond until I power cycle it. I am trying to disable various automation to pin down which ones the update might be hanging on. Really considering a rollback as the hub is mostly a brick now.
Show the Event Subscription section of App Status page for the rule. It doesn't appear that it is being triggered. Also, you might open the rule and hit Done, to see if that fixes it. Look at the Events logs from the device page as well.
I went in and hit "Done" and it's still not triggering when it goes to home and armed via the Ring app... Interestingly when I disarmed via the Ring app immediately after it DID trigger
I don't have a clue what's going on here, but it sounds as though the events are not being sent as you expect. Look at the Events from the device page.
I didn't recreate it, I just changed the trigger into something more or less equivilent.. then it started working.. have a look at the 3rd entry in my post
Yes, I just did and it works! @bravenel something's wacky with taking old rules in RM to the new version... Similar to the issue I had with my simple rule triggering for sunrise not working after update.
