Turning off S0 reduces the traffic of these by two thirds but if you have enough of them they can still cause problems.
I had 2 do that when added with the secondary. They also listed as having pending changes in the device properties. I was able to resolve by hitting the configure button in the device properties. I then pulled the battery and after replacing the configuration came down and resolved the issue. You may also need to move it closer to the hub to get it to take the update. You will know it worked when there is no longer any pending changes for teh device.
You may be on to something. I kept poking at this problem yesterday. The main offender has syncStatus reporting 1 pending change. I’ve been trying to force the device to awaken with a single push of the tiny button. Logs show device sync when I push the button, but always 1 pending change when finished.
For testing I have this sensor located in the same room with the C7. I pulled the battery, hit configure on the device page, then replaced the battery.
With debug logging on, I can see the device synchronizing parameters. But the log still shows 1 pending change. So does the device details page.
C7 log during sensor wakeup sync
dev:4602020-12-28 01:16:18.139 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:16:18.135 pm debugNotificationReport(v1AlarmType:7, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:8, sequence:false, eventParametersLength:0, eventParameter:)
dev:4602020-12-28 01:16:18.129 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:16:18.123 pm debugBasicSet(value:255)
dev:4602020-12-28 01:16:15.510 pm infoGarage motion sensor: syncStatus is 1 Pending Change
dev:4602020-12-28 01:16:15.498 pm debugThe changes will be synced the next time the device wakes up. You can force the device to wake up immediately by using a paperclip to push the recessed button on the bottom of the device.
dev:4602020-12-28 01:16:07.469 pm debugMotion Sensitivity (Param #6) = 3
dev:4602020-12-28 01:16:07.427 pm infoGarage motion sensor: syncStatus is Syncing...
dev:4602020-12-28 01:16:07.423 pm debugConfigurationReport(configurationValue:[3], parameterNumber:6, size:1) scaledConfigurationValue: 3
dev:4602020-12-28 01:16:07.379 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:16:07.375 pm debugNotificationReport(v1AlarmType:7, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:8, sequence:false, eventParametersLength:0, eventParameter:)
dev:4602020-12-28 01:16:07.370 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:16:07.365 pm debugBasicSet(value:255)
dev:4602020-12-28 01:15:37.628 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:15:37.624 pm debugNotificationReport(v1AlarmType:7, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:8, sequence:false, eventParametersLength:0, eventParameter:)
dev:4602020-12-28 01:15:37.596 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:15:37.591 pm debugBasicSet(value:255)
dev:4602020-12-28 01:15:15.200 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:15:15.195 pm debugNotificationReport(v1AlarmType:7, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:8, sequence:false, eventParametersLength:0, eventParameter:)
dev:4602020-12-28 01:15:15.180 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:15:15.176 pm debugBasicSet(value:255)
dev:4602020-12-28 01:15:06.443 pm infoGarage motion sensor: tamper is clear
dev:4602020-12-28 01:15:06.439 pm debugNotificationReport(v1AlarmType:7, v1AlarmLevel:0, reserved:0, notificationStatus:255, notificationType:7, event:0, sequence:false, eventParametersLength:1, eventParameter:[3])
dev:4602020-12-28 01:15:05.309 pm debugChanging LED Indicator Mode (Param #7) to "1" (Temperature Off / Motion Off)
dev:4602020-12-28 01:15:05.304 pm debugChanging Light Change Trigger (Param #4) to "10" (10%)
dev:4602020-12-28 01:15:05.300 pm debugChanging Humidity Change Trigger (Param #3) to "10" (10%)
dev:4602020-12-28 01:15:05.296 pm debugChanging Temperature Change Trigger (Param #2) to "10" (1.0°C / 1.8°F)
dev:4602020-12-28 01:15:05.292 pm debugChanging Motion Sensitivity (Param #6) to "3" (3)
dev:4602020-12-28 01:15:05.254 pm debugChanging Motion Retrigger Interval (Param #5) to "60" (60 Seconds(Firmware 17.9) / 60 Minutes (Firmware 5.9 & 16.9))
dev:4602020-12-28 01:15:05.204 pm debugChanging Wake Up Interval to 43200 Seconds
dev:4602020-12-28 01:15:05.092 pm debugsyncDevice()...
dev:4602020-12-28 01:15:04.913 pm infoGarage motion sensor: temperature is 71.78°F
dev:4602020-12-28 01:15:04.909 pm debugSensorMultilevelReport(precision:2, scale:1, sensorType:1, sensorValue:[28, 10], size:2, scaledSensorValue:71.78)
dev:4602020-12-28 01:14:57.072 pm warnAll the settings will be sent to the device the next time it wakes up.
dev:4602020-12-28 01:14:57.068 pm infoGarage motion sensor: syncStatus is Resync All
dev:4602020-12-28 01:14:57.054 pm warnconfigure...
dev:4602020-12-28 01:14:55.562 pm infoGarage motion sensor: tamper is detected
dev:4602020-12-28 01:14:55.558 pm debugNotificationReport(v1AlarmType:7, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:3, sequence:false, eventParametersLength:0, eventParameter:)
dev:4602020-12-28 01:14:49.250 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:14:49.247 pm debugNotificationReport(v1AlarmType:7, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:8, sequence:false, eventParametersLength:0, eventParameter:)
dev:4602020-12-28 01:14:49.218 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:14:49.214 pm debugBasicSet(value:255)
dev:4602020-12-28 01:14:38.909 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:14:38.905 pm debugNotificationReport(v1AlarmType:7, v1AlarmLevel:255, reserved:0, notificationStatus:255, notificationType:7, event:8, sequence:false, eventParametersLength:0, eventParameter:)
dev:4602020-12-28 01:14:38.865 pm infoGarage motion sensor: motion is active
dev:4602020-12-28 01:14:38.859 pm debugBasicSet(value:255)
dev:4602020-12-28 01:13:53.701 pm debugThe changes will be synced the next time the device wakes up. You can force the device to wake up immediately by using a paperclip to push the recessed button on the bottom of the device.
dev:4602020-12-28 01:13:49.608 pm warndescription logging is: true
dev:4602020-12-28 01:13:49.604 pm warndebug logging is: true
dev:4602020-12-28 01:13:49.600 pm infoupdated...
dev:4602020-12-28 01:12:54.446 pm debugThe changes will be synced the next time the device wakes up. You can force the device to wake up immediately by using a paperclip to push the recessed button on the bottom of the device.
dev:4602020-12-28 01:12:50.314 pm warndescription logging is: true
dev:4602020-12-28 01:12:50.310 pm warndebug logging is: true
Can you confirm z wave stick still works? Everyone’s saying “so far so good” after couple days. I ordered aeotec stick. I’m seeing this z wave stick can be used for many purposes- ota updates, adding excluding, ghost nodes etc.. And which one did you purchase?
I have 8 zooz 4 in 1 motion sensors! Replaced with a mix of fibaro and eco, I need humidity readings for some of my automations.
Even with the no security stick inclusion you will have issues with that many sensors. Probably anymore then 2 and you'll start seeing problems.
Anyone think this new one is worth a try?
Even with adding them with no security and setting reporting to the minimum 24h I was still having occasions where my Zwave switches would stop responding for several minutes. I suspected it was the 4 in 1 sensors so I swapped them out for Zigbee motion sensors and have not had the unresponsive switch problem since.
I would say these 4 in 1 sensors are just not compatible with the C7 hub. I would not recommend using them even without security set.
