This was a bug introduced by a new feature that you don't need anyway, that feature has been removed and this should not happen in the latest version.
I have two Aqara temperature and humidity sensors. One has worked perfectly ever since I set it up, the other can't seem to stay connected for more than a couple hours - it works again after I delete and re-pair it, then stops again. I am getting this in the logs:
It has two zigbee outlets nearby it can hop through.
This is the right version, The message you get is fine, that is a normal message. As long as there is no state update in the event log of the device all is as it should be.
What model are these? Are they known to work well with Xiaomi/Aqara? This should probably be moved to a thread for mesh stability though.
Actually 3 stable zigbee points - 2 smartthings power outlets and 1 Sonoff inline switch. Ok I wasn't sure from the log what exactly could be wrong whether it was the mesh or whether something I have set up wrong in the many preferences offered. NB there are two Smartthings window opening/vibration sensors within a meter that have never had any downtime at all, presumably hopping through the same waypoints. I am going to bring the offending sensor into proximity with the hub and see if it does any better there, it could be a faulty device.
These work well but have a rather limited transmission power so should not be alone as repeaters anywhere.
They are also fully Zigbee compliant so will accept many things which would make a Xiaomi/Aqara device drop.
This is a good test. Checking the battery with a multi-meter and/or replacing it is another good thing to try.
Is there somewhere I can choose the interval for polling this device?
There is no polling, if it is detected as dropped the driver will send packets to try to bring it back online, but this only works sometimes, it all depends on how they dropped.
So how can I find out how often a healthy one of these should be sending data? Is there a pattern/rule to it, or kind of random?
Once every 55-60 minutes + when there is a temperature/humidity change over a certain threshold I can't remember right now. That they miss one or two checkins during a 24 hours period is rather common though.
Little oddity this evening. Noticed some lights weren't working when pressing keys on the 3-button 25LM (I'm using the switch status to toggle a couple of smart plugs). Seeing this in the logs:
dev:1192020-09-05 00:34:53.535 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200 | parseMap:[raw:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200, profileId:0104, clusterId:000A, clusterInt:10, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BCFA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, 00, 02, 00]]
dev:1192020-09-05 00:33:53.881 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200 | parseMap:[raw:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200, profileId:0104, clusterId:000A, clusterInt:10, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BCFA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, 00, 02, 00]]
dev:1192020-09-05 00:33:15.137 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA01FCC044F700411E64100065100066100003281005211A009A2010082119010A2116650B2000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 44, attrId: 00F7, encoding: 41, command: 0A, value: 1E64100065100066100003281005211A009A2010082119010A2116650B2000 | parseMap:[raw:BCFA01FCC044F700411E64100065100066100003281005211A009A2010082119010A2116650B2000, dni:BCFA, endpoint:01, cluster:FCC0, size:44, attrId:00F7, encoding:41, command:0A, value:64100065100066100003281005211A009A2010082119010A2116650B2000, clusterInt:64704, attrInt:247]
dev:1192020-09-05 00:33:15.131 warnUnhandled Event PLEASE REPORT TO DEV - description:read attr - raw: BCFA01FCC044F700411E64100065100066100003281005211A009A2010082119010A2116650B2000, dni: BCFA, endpoint: 01, cluster: FCC0, size: 44, attrId: 00F7, encoding: 41, command: 0A, value: 1E64100065100066100003281005211A009A2010082119010A2116650B2000 | msgMap:[raw:BCFA01FCC044F700411E64100065100066100003281005211A009A2010082119010A2116650B2000, dni:BCFA, endpoint:01, cluster:FCC0, size:44, attrId:00F7, encoding:41, command:0A, value:64100065100066100003281005211A009A2010082119010A2116650B2000, clusterInt:64704, attrInt:247]
dev:1192020-09-05 00:33:11.984 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200 | parseMap:[raw:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200, profileId:0104, clusterId:000A, clusterInt:10, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BCFA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, 00, 02, 00]]
dev:1192020-09-05 00:31:28.324 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200 | parseMap:[raw:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200, profileId:0104, clusterId:000A, clusterInt:10, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BCFA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, 00, 02, 00]]
dev:1192020-09-05 00:30:58.004 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200 | parseMap:[raw:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200, profileId:0104, clusterId:000A, clusterInt:10, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BCFA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, 00, 02, 00]]
dev:1192020-09-05 00:30:45.946 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA2B00120A5500210100, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2B00120A5500210100, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:45.942 infoButton 43 was pushed
dev:1192020-09-05 00:30:45.937 infoMultistate - endpoint: 43, taps: 1, physicalButton: 43, physicalButtons: 3, button: 43
dev:1192020-09-05 00:30:45.932 infoMultistate - description:read attr - raw: BCFA2B00120A5500210100, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2B00120A5500210100, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:45.422 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-09-05 00:30:45.417 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-09-05 00:30:45.412 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001000F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0300061600001000F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-09-05 00:30:44.164 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA2B00120A5500210100, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2B00120A5500210100, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:44.160 infoButton 43 was pushed
dev:1192020-09-05 00:30:44.156 infoMultistate - endpoint: 43, taps: 1, physicalButton: 43, physicalButtons: 3, button: 43
dev:1192020-09-05 00:30:44.151 infoMultistate - description:read attr - raw: BCFA2B00120A5500210100, dni: BCFA, endpoint: 2B, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2B00120A5500210100, dni:BCFA, endpoint:2B, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:43.627 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-09-05 00:30:43.622 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-09-05 00:30:43.617 infoOn/Off Button press - description:read attr - raw: BCFA0300061600001001F5002300FABC03, dni: BCFA, endpoint: 03, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0300061600001001F5002300FABC03, dni:BCFA, endpoint:03, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-09-05 00:30:42.353 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA2A00120A5500210100, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2A00120A5500210100, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:42.349 infoButton 42 was pushed
dev:1192020-09-05 00:30:42.345 infoMultistate - endpoint: 42, taps: 1, physicalButton: 42, physicalButtons: 3, button: 42
dev:1192020-09-05 00:30:42.340 infoMultistate - description:read attr - raw: BCFA2A00120A5500210100, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2A00120A5500210100, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:41.843 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-09-05 00:30:41.838 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-09-05 00:30:41.808 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001000F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0200061600001000F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-09-05 00:30:40.631 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA2A00120A5500210100, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2A00120A5500210100, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:40.626 infoButton 42 was pushed
dev:1192020-09-05 00:30:40.621 infoMultistate - endpoint: 42, taps: 1, physicalButton: 42, physicalButtons: 3, button: 42
dev:1192020-09-05 00:30:40.617 infoMultistate - description:read attr - raw: BCFA2A00120A5500210100, dni: BCFA, endpoint: 2A, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2A00120A5500210100, dni:BCFA, endpoint:2A, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:40.124 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-09-05 00:30:40.119 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-09-05 00:30:40.114 infoOn/Off Button press - description:read attr - raw: BCFA0200061600001001F5002300FABC03, dni: BCFA, endpoint: 02, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0200061600001001F5002300FABC03, dni:BCFA, endpoint:02, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-09-05 00:30:38.773 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA2900120A5500210100, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2900120A5500210100, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:38.767 infoButton 41 was pushed
dev:1192020-09-05 00:30:38.763 infoMultistate - endpoint: 41, taps: 1, physicalButton: 41, physicalButtons: 3, button: 41
dev:1192020-09-05 00:30:38.760 infoMultistate - description:read attr - raw: BCFA2900120A5500210100, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2900120A5500210100, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:38.294 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-09-05 00:30:38.287 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-09-05 00:30:38.281 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001000F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 00F5002300FABC03 | parseMap:[raw:BCFA0100061600001000F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:false]
dev:1192020-09-05 00:30:36.250 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA2900120A5500210100, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2900120A5500210100, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:36.244 infoButton 41 was pushed
dev:1192020-09-05 00:30:36.239 infoMultistate - endpoint: 41, taps: 1, physicalButton: 41, physicalButtons: 3, button: 41
dev:1192020-09-05 00:30:36.235 infoMultistate - description:read attr - raw: BCFA2900120A5500210100, dni: BCFA, endpoint: 29, cluster: 0012, size: 0A, attrId: 0055, encoding: 21, command: 0A, value: 0100 | parseMap:[raw:BCFA2900120A5500210100, dni:BCFA, endpoint:29, cluster:0012, size:0A, attrId:0055, encoding:21, command:0A, value:0001, clusterInt:18, attrInt:85, valueParsed:1]
dev:1192020-09-05 00:30:35.724 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-09-05 00:30:35.719 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-09-05 00:30:35.714 infoOn/Off Button press - description:read attr - raw: BCFA0100061600001001F5002300FABC03, dni: BCFA, endpoint: 01, cluster: 0006, size: 16, attrId: 0000, encoding: 10, command: 0A, value: 01F5002300FABC03 | parseMap:[raw:BCFA0100061600001001F5002300FABC03, dni:BCFA, endpoint:01, cluster:0006, size:16, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, additionalAttrs:[[value:03BCFA00, encoding:23, attrId:00F5, consumedBytes:7, attrInt:245]], valueParsed:true]
dev:1192020-09-05 00:29:55.485 warnUnknown model (126C756D692E7377697463682E6C3361636E33) - PLEASE REPORT THIS LOG TO THE DEV - description:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200 | parseMap:[raw:catchall: 0104 000A 01 01 0040 00 BCFA 00 00 0000 00 00 00000200, profileId:0104, clusterId:000A, clusterInt:10, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:BCFA, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[00, 00, 02, 00]]
--- Live Log Started, waiting for events ---
And the model is being reported as 126C756D692E7377697463682E6C3361636E33
, or 'lumi.switch.l3acn3', but not converted from hex. Now, the only thing that has changed was me upgrading to 2.2.3.142 from 2.2.3.125(?).
Going to reboot and see if it starts behaving again.
Huh, yes. Works fine again after rebooting the hub.
This is definitely not normal... I hope it's not a recurring issue, if anyone sees this, please report it. There are so many platform changes that I'm worried there could be something breaking now and again.
Hello @markus, wonderful job you did! Now I came across this ceiling light. Do you think you can get it to work? I'm not afraid to buy it and supply you with details you need and testing results. What do you think? Is it worth to give it a try?
Edit: Oh, and what about their door locks?
I've never really looked at those since I worry they will be bad repeaters, they might be great, just haven't seen anyone try them. They should be rather straight forward, no guarantees, but if you get one I'll give drivers a go.
Can't lock or unlock them remotely through Zigbee, really annoying. I've talked with an Aqara sales guy and they've been told it's for "security" reasons... anyway... I could understand not allowing unlocking, but not allowing locking? You also can't manage lock-codes though Zigbee from what I've been told. There are those that like these locks, but with these limitations I wouldn't touch them.
Nice! Just ordered the light. ETA 10/7 so we'll see.
The light is for the bedroom ceiling. Next to the bed we both have a light with IKEA smart bulbs in it. The idea is to be able to turn the ceiling light on by hand from each side of the bed and from the door. The bedside lights only need to be switched from the bed so 1 button for our own light only. I think I'll order these nice opple buttons for them but which ones?
Ceiling light adjustable brightness and white. Bedside lights only dimm.
@andydvsn what driver did you use for this switch? I have the QBKG26LM, which is the neutral version of the QBKG25LM. I don't see the same behaviour as you do, Virtual Switch 1, 2, 3 aren't identified for me. But your's seem to have somehow. I must be using the wrong driver for this!? Thanks
I'm using 'Zigbee - Aqara Wall Switch' for the 25LM, but it's only luck that it's partially working for me. There's extra code @markus will need to add to the driver to properly support the 25LM and the other models I have. Unfortunately I don't have a 26LM otherwise I'd have done the logs for that one too. It will need to be coded for and won't necessarily act in the same way as the 25LM.
Heck, the 22LM with two buttons behaves totally differently to the 25LM with three buttons (so far as I can see) even though they're in the same product range and generation!
@andydvsn thanks very much for the info. Yes, that's the driver I'm using (I haven't added any extra code to it tho!), I even tried the beta version, but same results. Glad its not just me going mad!
Is it possible to contribute towards the development of these switches? I have almost exclusively installed these Aqara D1 switches in my house (with the exception of 2 switches that have intermideiate wiring).
It’s all on GitHub, I’m sure @markus wouldn’t be against a pull request if you’re happy with those tools.
Actually, the debug logs from the 26LM would be very useful. Have a look at my posts above with the logs from mine and copy the method.
I’m exclusively on these D1 devices now as well, far better than the previous generation.
