Thanks @andydvsn the driver needed to have the 26LM as a known device. Once that was done, the button presses where then registered . So i performed the button press combinations, to get the presses showing on the log. please see logs below.
Not sure what the next steps would be from here!? But at a minimum it would be good to have the 26LM listed as a device, so that button presses are at least registered.
"dev:5672020-09-09 16:48:24.660 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0300060800001001, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0300060800001001, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:24.657 infoOn/Off Button press - description:read attr - raw: 937D0300060800001001, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0300060800001001, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:24.595 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0200060800001001, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0200060800001001, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:24.591 infoOn/Off Button press - description:read attr - raw: 937D0200060800001001, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0200060800001001, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:21.433 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0300060800001000, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0300060800001000, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:21.430 infoOn/Off Button press - description:read attr - raw: 937D0300060800001000, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0300060800001000, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:21.362 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0100060800001001, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0100060800001001, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:21.358 infoOn/Off Button press - description:read attr - raw: 937D0100060800001001, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0100060800001001, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:18.110 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0100060800001000, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0100060800001000, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:18.106 infoOn/Off Button press - description:read attr - raw: 937D0100060800001000, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0100060800001000, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:18.043 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0200060800001000, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0200060800001000, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:18.039 infoOn/Off Button press - description:read attr - raw: 937D0200060800001000, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0200060800001000, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:14.746 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0300060800001001, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0300060800001001, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:14.743 infoOn/Off Button press - description:read attr - raw: 937D0300060800001001, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0300060800001001, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:11.755 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0200060800001001, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0200060800001001, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:11.751 infoOn/Off Button press - description:read attr - raw: 937D0200060800001001, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0200060800001001, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:09.030 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0100060800001001, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0100060800001001, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:09.027 infoOn/Off Button press - description:read attr - raw: 937D0100060800001001, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0100060800001001, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:07.605 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0300060800001000, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0300060800001000, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:07.601 infoOn/Off Button press - description:read attr - raw: 937D0300060800001000, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0300060800001000, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:07.446 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0300060800001001, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0300060800001001, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:07.443 infoOn/Off Button press - description:read attr - raw: 937D0300060800001001, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0300060800001001, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:06.281 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0200060800001000, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0200060800001000, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:06.276 infoOn/Off Button press - description:read attr - raw: 937D0200060800001000, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0200060800001000, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:06.094 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0200060800001001, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0200060800001001, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:06.090 infoOn/Off Button press - description:read attr - raw: 937D0200060800001001, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0200060800001001, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:04.476 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0100060800001000, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0100060800001000, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:04.471 infoOn/Off Button press - description:read attr - raw: 937D0100060800001000, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0100060800001000, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:48:04.294 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0100060800001001, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0100060800001001, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:48:04.290 infoOn/Off Button press - description:read attr - raw: 937D0100060800001001, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0100060800001001, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:47:33.314 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0300060800001000, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0300060800001000, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:47:33.311 infoOn/Off Button press - description:read attr - raw: 937D0300060800001000, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0300060800001000, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:47:32.627 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0300060800001001, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0300060800001001, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:47:32.623 infoOn/Off Button press - description:read attr - raw: 937D0300060800001001, dni: 937D, endpoint: 03, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0300060800001001, dni:937D, endpoint:03, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:47:31.106 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0200060800001000, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0200060800001000, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:47:31.101 infoOn/Off Button press - description:read attr - raw: 937D0200060800001000, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0200060800001000, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:47:30.150 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0200060800001001, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0200060800001001, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:47:30.146 infoOn/Off Button press - description:read attr - raw: 937D0200060800001001, dni: 937D, endpoint: 02, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0200060800001001, dni:937D, endpoint:02, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:47:27.996 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0100060800001000, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0100060800001000, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:47:27.992 infoOn/Off Button press - description:read attr - raw: 937D0100060800001000, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 00 | parseMap:[raw:937D0100060800001000, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:00, clusterInt:6, attrInt:0, valueParsed:false]
dev:5672020-09-09 16:47:25.693 warnCluster 0x0006 NOT YET IMPLEMENTED for this model (lumi.switch.n3acn3) - PLEASE REPORT THIS LOG TO THE DEV - description:read attr - raw: 937D0100060800001001, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0100060800001001, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
dev:5672020-09-09 16:47:25.690 infoOn/Off Button press - description:read attr - raw: 937D0100060800001001, dni: 937D, endpoint: 01, cluster: 0006, size: 08, attrId: 0000, encoding: 10, command: 0A, value: 01 | parseMap:[raw:937D0100060800001001, dni:937D, endpoint:01, cluster:0006, size:08, attrId:0000, encoding:10, command:0A, value:01, clusterInt:6, attrInt:0, valueParsed:true]
