NOTE (Jul-2025) - Since I wrote this driver back in 2021 Hubitat have introduced a built-in Virtual Battery Sensor driver in platform version 2.4.1 in April 2025, which effectively makes this custom driver redundant and so I would recommend using the built-in option. People are welcome to continue to use or even install my driver if they wish, but there is no significant benefit when compared to the built-in driver, aside from the battery status attribute, which can be easily achieved through other built-in features.
Wrote a small driver to record a battery reading for some of my tablets and phone. Intention is to send the current reading via Tasker / Maker API and record it in devices that use this driver.
Features of the driver:
Implements the Battery capability
Has a custom command setBattery(NUMBER) to allow updates via Maker API or RM rules
Includes a batteryStatus attribute to indicate if the battery is Discharging or Charging
Includes a lastUpdated attribute, so that a change is recorded event when no change to the battery is recorded, allow for an assessment of loss of communication with the device
The driver is available in HPM with Tags of "Monitoring","Energy Monitoring" and "Misc. Devices". It can also be accessed manually here.
I'd post some of the XML from the Tasker backup, but not sure how to properly isolate it, so will just give a description for now.
In HE:
Create a new Virtual Device using this Virtual Battery Sensor driver
Note down the Device Id from the URL on the Device Edit Page
Setup or update an existing instance of the Maker API Built-In App to include the new Virtual Battery Sensor device
In the Maker API App setup screen, copy the example "Send Device Command" URL, substituting the [Device ID] with the Device Id for the new virtual device, the [Command] with setBattery, and the [Secondary Value] with %BATT (the Tasker variable representing the current battery reading on your device)
Get this URL string to your device in some way, or access / modify it on the device if convenient
In Tasker:
Create a new profile, selecting Event as the trigger
In the pop-up type battery in the filter textbox and select Battery Changed
From the profile screen displayed, hit back to return to the main screen
From the pop-up select New Task, type in a name if you want, press the Tick icon to enter the Task edit screen
Press the + icon to add an Action
Type HTTP in the filter textbox, select HTTP Request (if not available choose HTTP Get)
Paste in the modified send command URL string in the URL setting
Back out to accept all the changes
If you want to go a step further, I have made a start in setting this virtual device up in a separate Maker API instance that sends attribute readins to InfluxDB / Grafana, setup various reports in Device Watchdog, but haven't yet got to the obvious use case of managing charging of the devices to keep them in a sweet spot of 20-80%.
