Wanted to monitor battery level for all of my end devices; which are mostly motion sensors, contact sensors, and a handful of humidity/temperature sensors; in node-red. I have a virtual device for every real device (it makes swapping real devices easier for me as I experiment with new devices). Quickly realized none of the built-in virtual drivers have battery. For a short period I created a second virtual device for every device and set it to use the Virtual Battery Sensor drive from this post.
To avoid having to make a second virtual device for every real device I modified the Virtual Omni Sensor driver to add battery.
Virtual Omni Sensor Plus and Device Mirror Plus
Makes life easier when using it with the Device Mirror Plus app. Now each of my virtual devices reflect the capabilities I want to see in node-red, without having to make multiple virtual devices.
v1.0.0
-Added "Virtual Omni Sensor Plus" and "Device Mirror Plus" to HPM.
v202110031411
-add threeAxis
v202110022249
-updates to event descriptive text for humidity
-add hours and minutes to change log dates
v202110020000
-change batteryLevel attribute back to battery
