@kkossev Thank you for the work you've put into this. Upon initial testing I still can't get around the 60 second timer. I will test more tomorrow when I'm able to look at the logs and really dig into it. I'll report back once. I have done some more testing and can provide more info.
Test with 120, 180, 240 seconds timers. Seems like the timeout timer resolution is in minutes and the timeout can not be set less than 1 minute?
The current logic is that after the valve is open, the driver sends to the device 5 seconds later the same 'auto off timer' value, trying to override the default 60 seconds timer. Or maybe the new timeout must be sent before the open() command? First set 120 in the "Set Irrigation Timer" and click on the button, this will send the new timeout value to the valve. Then click on Open() button, now the valve should have the new 120 seconds timeout already configured in advance.
What is sure, is that the valve resets to its default timeout every cycle. When the valve closes, the default value of 60 seconds (or 600 seconds) is restored automatically. So the driver should send the custom timeout every time the valve is open again.
Update: now, the driver sets the new timeout every time an open or close command confirmation is received for both SASWELL and GiEX irrigation timers models. Make sure you have the latest version before testing.
Update2: Now I think that the control of the timeout value for GiEX (_TZE200_sh1btabb) is different than the control for SASWELL. Better wait for the next tests after I implement the Irrigation Target mode ( duration or capacity).
Update3: I have added also support for Lidl / PARKSIDEĀ® Smart Irrigation Computer.
If anyone has this irrigation timer, please let me know if it works with this driver.
As there were a lot of changes accumulated in the past week, I will update the production version branch this weekend, if there are no new issues reported.
Version 1.2.0 is now pushed for update via HPM.
Thanks for the update. I can confirm that my device
- endpointId: 01
- application: 46
- manufacturer: _TZE200_sh1btabb
- model: TS0601
- tuyaVersion: 1.0.6
Works with this driver. I did delete and read the device. The consumption feature does not appear to work (I was not expecting it to as Iām pretty certain this valve does not support that feature). I had to set the irrigation mode to duration and then the valve was staying open for longer than 60seconds. I also noticed that the irrigation timer appears to be ignored now(I tried 120s and 300s). But Iām fine with this as I can control this through basic rules.
I have not been able to get my device to work with the latest version of the driver. I'm seeing this after pairing. Any ideas? I purchased the controller in the first AliExpress link in the first post of this thread: https://www.aliexpress.com/item/4000334424893.html
Hi @hoffadg ,
This is a new manufacturer, and the device fingerprint was not present in the driver. I have added it in version 1.2.1, also pushed for update via HPM.
But before updating the driver, you can try to configure it for this new device manually.
Click on 'Advanced Options' and Save. Then a new option will appear - ''Device Profile'. Select "TS0001_VALVE_ONOFF" from the dropdown menu, click on Save and try again. I expect that your valve will be working even with the old driver version. With the driver update, the same valve will be now configured automatically for new installations.
Thanks! Unfortunately, I am still unable to get open/close to work. It does, however, sense when i manually open/close by pressing the button. Here is what I see in the log.
Hi @hoffadg ,
These logs show what the driver is sending to the valve (after you have clicked on the Open and Close buttons on the screen), but there is no any response from the device.
Did you pair the valve again to the hub with the latest driver installed?
Yes, i removed the device and followed the instructions to re-pair with the new driver installed.
With the Debug option turned on, do you see anything in the live logs when you manually open/close the valve from the red button on the device itself?
Please post a screenshot of the Current States and State Variables from the device page.
I tried a manual open and close but nothing is showing in the log. The valve state remained closed.
In the State Variables section, rxCtr=0 means that nothing was received from the deviceā¦
Pair it again to the Hubitat hub, by some reason the device has disconnected.
Is this a C-7 or C-8 hub?
It's a C-7. I'll try re-pairing now.
I noticed my hub firmware was out of date so I updated that and tried to re-pair. Still no response to open/close but I do see now the RxCtr is 3.
Here is the full log from the point I paired up until I attempted to send open/close several times.
dev:7842023-03-12 10:19:30.288 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 1 {}, delay 2000])
dev:7842023-03-12 10:19:30.287 AMdebugWater Main Valve open()... sent cmds=[he cmd 0x780E 0x01 6 1 {}, delay 2000]
dev:7842023-03-12 10:19:28.614 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:19:28.612 AMdebugWater Main Valve close()... sent cmds=[he cmd 0x780E 0x01 6 0 {}, delay 2000]
dev:7842023-03-12 10:19:23.179 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 1 {}, delay 2000])
dev:7842023-03-12 10:19:23.177 AMdebugWater Main Valve open()... sent cmds=[he cmd 0x780E 0x01 6 1 {}, delay 2000]
dev:7842023-03-12 10:19:20.807 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:19:20.806 AMdebugWater Main Valve close()... sent cmds=[he cmd 0x780E 0x01 6 0 {}, delay 2000]
dev:7842023-03-12 10:19:14.891 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:19:14.890 AMdebugWater Main Valve close()... sent cmds=[he cmd 0x780E 0x01 6 0 {}, delay 2000]
dev:7842023-03-12 10:19:10.091 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 1 {}, delay 2000])
dev:7842023-03-12 10:19:10.090 AMdebugWater Main Valve open()... sent cmds=[he cmd 0x780E 0x01 6 1 {}, delay 2000]
dev:7842023-03-12 10:19:00.937 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:19:00.935 AMdebugWater Main Valve close()... sent cmds=[he cmd 0x780E 0x01 6 0 {}, delay 2000]
dev:7842023-03-12 10:18:42.355 AMinfoTuya Zigbee Valve Initialization finished
dev:7842023-03-12 10:18:39.603 AMdebugTuya Zigbee Valve parseZHAcommand writeAttributeResponse cluster: 0000 status:86
dev:7842023-03-12 10:18:39.598 AMdebugTuya Zigbee Valve Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 780E 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:780E, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:7842023-03-12 10:18:39.595 AMdebugTuya Zigbee Valve parse: description is catchall: 0104 0000 01 01 0040 00 780E 00 00 0000 04 01 86DEFF
dev:7842023-03-12 10:18:39.567 AMdebugTuya Zigbee Valve Model is : TS0001
dev:7842023-03-12 10:18:39.565 AMdebugTuya Zigbee Valve Tuya check-in message (attribute 0001 reported: 64)
dev:7842023-03-12 10:18:39.564 AMdebugTuya Zigbee Valve zclVersion is : 02
dev:7842023-03-12 10:18:39.560 AMdebugTuya Zigbee Valve Manufacturer is : _TZ3000_5ucujjts
dev:7842023-03-12 10:18:39.500 AMdebugTuya Zigbee Valve Desc Map: [raw:780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni:780E, endpoint:01, cluster:0000, size:64, attrId:0004, encoding:42, command:01, value:_TZ3000_5ucujjts, clusterInt:0, attrInt:4, additionalAttrs:[[value:02, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:64, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0001, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:7842023-03-12 10:18:39.491 AMwarnexception caught while parsing description: read attr - raw: 780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: 780E, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7842023-03-12 10:18:39.481 AMdebugTuya Zigbee Valve parse: description is read attr - raw: 780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: 780E, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7842023-03-12 10:18:39.442 AMinfoTuya Zigbee Valve Tuya Zigbee Valve is open (Refresh)
dev:7842023-03-12 10:18:39.409 AMdebugTuya Zigbee Valve Valve state changed from unknown to open
dev:7842023-03-12 10:18:39.408 AMdebugTuya Zigbee Valve event [name:switch, value:on]
dev:7842023-03-12 10:18:39.404 AMdebugTuya Zigbee Valve parse: description is read attr - raw: 780E0100060A00001001, dni: 780E, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01
dev:7842023-03-12 10:18:39.312 AMdebugTuya Zigbee Valve sendZigbeeCommands (cmd=[he raw 0x780E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x780E 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, null, zdo bind 0x780E 0x01 0x01 6 {70B3D52B600136D7} {}, delay 2000, he cr 0x780E 0x01 6 0 16 0 600 {}, delay 2000, he wattr 0x780E 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:7842023-03-12 10:18:39.310 AMdebugTuya Zigbee Valve settings.batteryReporting = null
dev:7842023-03-12 10:18:39.307 AMdebugTuya Zigbee Valve setting powerOnBehaviour to last state (2)
dev:7842023-03-12 10:18:39.298 AMdebugTuya Zigbee Valve sendZigbeeCommands (cmd=[he rattr 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:18:39.266 AMtraceTuya Zigbee Valve polling..
dev:7842023-03-12 10:18:39.265 AMdebugTuya Zigbee Valve sending refresh() command...
dev:7842023-03-12 10:18:39.258 AMinfoTuya Zigbee Valve configure()..
dev:7842023-03-12 10:18:39.256 AMinfoDebug logging will be automatically switched off after 24 hours
dev:7842023-03-12 10:18:39.223 AMinfoDebug logging is true Description text logging is true
dev:7842023-03-12 10:18:39.221 AMinfoUpdating null (Tuya Zigbee Valve) model UNKNOWN
dev:7842023-03-12 10:18:39.212 AMtrace destinationEP = 01
dev:7842023-03-12 10:18:39.211 AMtrace model = TS0001
dev:7842023-03-12 10:18:39.161 AMinfoTuya Zigbee Valve all states and scheduled jobs cleared!
dev:7842023-03-12 10:18:39.159 AMwarnTuya Zigbee Valve device model TS0001 manufacturer _TZ3000_5ucujjts was not found!
dev:7842023-03-12 10:18:39.156 AMwarnTuya Zigbee Valve unknown model TS0001 manufacturer _TZ3000_5ucujjts
dev:7842023-03-12 10:18:39.131 AMinfoTuya Zigbee Valve InitializeVars()... fullInit = true
dev:7842023-03-12 10:18:39.103 AMinfoTuya Zigbee Valve Initialize()...
dev:7842023-03-12 10:18:34.652 AMdebugTuya Zigbee Valve parseZHAcommand writeAttributeResponse cluster: 0000 status:86
dev:7842023-03-12 10:18:34.642 AMdebugTuya Zigbee Valve Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 780E 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:780E, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:7842023-03-12 10:18:34.637 AMdebugTuya Zigbee Valve parse: description is catchall: 0104 0000 01 01 0040 00 780E 00 00 0000 04 01 86DEFF
dev:7842023-03-12 10:18:34.614 AMdebugTuya Zigbee Valve Model is : TS0001
dev:7842023-03-12 10:18:34.611 AMdebugTuya Zigbee Valve Tuya check-in message (attribute 0001 reported: 64)
dev:7842023-03-12 10:18:34.609 AMdebugTuya Zigbee Valve zclVersion is : 02
dev:7842023-03-12 10:18:34.606 AMdebugTuya Zigbee Valve Manufacturer is : _TZ3000_5ucujjts
dev:7842023-03-12 10:18:34.566 AMdebugTuya Zigbee Valve Desc Map: [raw:780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni:780E, endpoint:01, cluster:0000, size:64, attrId:0004, encoding:42, command:01, value:_TZ3000_5ucujjts, clusterInt:0, attrInt:4, additionalAttrs:[[value:02, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:64, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0001, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:7842023-03-12 10:18:34.554 AMwarnexception caught while parsing description: read attr - raw: 780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: 780E, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7842023-03-12 10:18:34.528 AMdebugTuya Zigbee Valve parse: description is read attr - raw: 780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: 780E, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7842023-03-12 10:18:34.488 AMinfoTuya Zigbee Valve Tuya Zigbee Valve is open (Refresh)
dev:7842023-03-12 10:18:34.454 AMdebugTuya Zigbee Valve Valve state changed from unknown to open
dev:7842023-03-12 10:18:34.447 AMdebugTuya Zigbee Valve event [name:switch, value:on]
dev:7842023-03-12 10:18:34.436 AMdebugTuya Zigbee Valve parse: description is read attr - raw: 780E0100060A00001001, dni: 780E, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01
dev:7842023-03-12 10:18:34.434 AMinfoTuya Zigbee Valve is online
dev:7842023-03-12 10:18:34.335 AMdebugTuya Zigbee Valve sendZigbeeCommands (cmd=[he raw 0x780E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x780E 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, null, zdo bind 0x780E 0x01 0x01 6 {70B3D52B600136D7} {}, delay 2000, he cr 0x780E 0x01 6 0 16 0 600 {}, delay 2000, he wattr 0x780E 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:7842023-03-12 10:18:34.333 AMdebugTuya Zigbee Valve settings.batteryReporting = null
dev:7842023-03-12 10:18:34.321 AMdebugTuya Zigbee Valve setting powerOnBehaviour to last state (2)
dev:7842023-03-12 10:18:34.246 AMdebugTuya Zigbee Valve sendZigbeeCommands (cmd=[he rattr 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:18:34.207 AMtraceTuya Zigbee Valve polling..
dev:7842023-03-12 10:18:34.205 AMdebugTuya Zigbee Valve sending refresh() command...
dev:7842023-03-12 10:18:34.127 AMinfoTuya Zigbee Valve configure()..
dev:7842023-03-12 10:18:34.117 AMdebugcalling initialize() after 5 seconds...
dev:7842023-03-12 10:18:34.070 AMtrace destinationEP = 01
dev:7842023-03-12 10:18:34.068 AMtrace model = TS0001
dev:7842023-03-12 10:18:34.066 AMinfoTuya Zigbee Valve tuyaVersion set to 1.2.4
dev:7842023-03-12 10:18:33.970 AMinfoTuya Zigbee Valve all states and scheduled jobs cleared!
dev:7842023-03-12 10:18:33.963 AMwarnTuya Zigbee Valve device model TS0001 manufacturer _TZ3000_5ucujjts was not found!
dev:7842023-03-12 10:18:33.960 AMwarnTuya Zigbee Valve unknown model TS0001 manufacturer _TZ3000_5ucujjts
dev:7842023-03-12 10:18:33.922 AMinfoTuya Zigbee Valve InitializeVars()... fullInit = true
dev:7842023-03-12 10:18:33.911 AMinfoTuya Zigbee Valve Installed()...
I noticed in your code _TZ3000_5ucujjts had not been added to the manufacturers struct so I did that and that fixed this error:
I now see "powerSource: dc" in the Current States but still no response to open/close.
I've tried re-pairing several times and tried pushing open, close, and refresh. Still no luck but I'm now seeing some warnings in the log.
dev:7892023-03-12 12:19:37.541 PMdebugWater sendZigbeeCommands (cmd=[he rattr 0xB6C0 0x01 6 0 {}, delay 2000])
dev:7892023-03-12 12:19:37.504 PMtraceWater polling..
dev:7892023-03-12 12:19:37.503 PMdebugWater sending refresh() command...
dev:7892023-03-12 12:19:12.321 PMdebugWater parseZHAcommand writeAttributeResponse cluster: 0000 status:86
dev:7892023-03-12 12:19:12.318 PMdebugWater Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 B6C0 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:B6C0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:7892023-03-12 12:19:12.314 PMdebugWater parse: description is catchall: 0104 0000 01 01 0040 00 B6C0 00 00 0000 04 01 86DEFF
dev:7892023-03-12 12:19:12.295 PMdebugWater Model is : TS0001
dev:7892023-03-12 12:19:12.293 PMdebugWater Tuya check-in message (attribute 0001 reported: 64)
dev:7892023-03-12 12:19:12.292 PMdebugWater zclVersion is : 02
dev:7892023-03-12 12:19:12.290 PMdebugWater Manufacturer is : _TZ3000_5ucujjts
dev:7892023-03-12 12:19:12.286 PMdebugWater Desc Map: [raw:B6C001000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni:B6C0, endpoint:01, cluster:0000, size:64, attrId:0004, encoding:42, command:01, value:_TZ3000_5ucujjts, clusterInt:0, attrInt:4, additionalAttrs:[[value:02, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:64, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0001, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:7892023-03-12 12:19:12.277 PMwarnexception caught while parsing description: read attr - raw: B6C001000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: B6C0, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7892023-03-12 12:19:12.263 PMdebugWater parse: description is read attr - raw: B6C001000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: B6C0, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7892023-03-12 12:19:12.207 PMinfoWater Water is closed (Refresh)
dev:7892023-03-12 12:19:12.176 PMdebugWater event [name:switch, value:off]
dev:7892023-03-12 12:19:12.173 PMdebugWater parse: description is read attr - raw: B6C00100060A00001000, dni: B6C0, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:7892023-03-12 12:19:11.993 PMinfoWater Received device announcement, data=[1F, C0, B6, D7, 36, 01, 60, 2B, D5, B3, 70, 8E] (Sequence Number:1F, Device network ID: B6C0, Capability Information: 8E)
dev:7892023-03-12 12:19:11.989 PMdebugWater Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 B6C0 00 00 0000 00 00 1FC0B6D73601602BD5B3708E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:B6C0, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[1F, C0, B6, D7, 36, 01, 60, 2B, D5, B3, 70, 8E]]
dev:7892023-03-12 12:19:11.986 PMdebugWater parse: description is catchall: 0000 0013 00 00 0040 00 B6C0 00 00 0000 00 00 1FC0B6D73601602BD5B3708E
dev:7892023-03-12 12:19:11.929 PMdebugWater sendZigbeeCommands (cmd=[he raw 0xB6C0 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0xB6C0 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, null, zdo bind 0xB6C0 0x01 0x01 6 {70B3D52B600136D7} {}, delay 2000, he cr 0xB6C0 0x01 6 0 16 0 600 {}, delay 2000, he wattr 0xB6C0 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:7892023-03-12 12:19:11.924 PMdebugWater setting powerOnBehaviour to last state (2)
dev:7892023-03-12 12:19:11.920 PMdebugWater sendZigbeeCommands (cmd=[he rattr 0xB6C0 0x01 6 0 {}, delay 2000])
dev:7892023-03-12 12:19:11.887 PMtraceWater polling..
dev:7892023-03-12 12:19:11.886 PMdebugWater sending refresh() command...
dev:7892023-03-12 12:19:11.878 PMinfoWater configure()..
dev:7892023-03-12 12:19:06.194 PMdebugWater Model is : TS0001
dev:7892023-03-12 12:19:06.193 PMdebugWater Tuya check-in message (attribute 0001 reported: 64)
dev:7892023-03-12 12:19:06.191 PMdebugWater zclVersion is : 02
dev:7892023-03-12 12:19:06.190 PMdebugWater Manufacturer is : _TZ3000_5ucujjts
dev:7892023-03-12 12:19:06.186 PMdebugWater Desc Map: [raw:BC6301000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni:BC63, endpoint:01, cluster:0000, size:64, attrId:0004, encoding:42, command:01, value:_TZ3000_5ucujjts, clusterInt:0, attrInt:4, additionalAttrs:[[value:02, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:64, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0001, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:7892023-03-12 12:19:06.178 PMwarnexception caught while parsing description: read attr - raw: BC6301000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: BC63, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7892023-03-12 12:19:06.170 PMdebugWater parse: description is read attr - raw: BC6301000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: BC63, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7892023-03-12 12:19:06.155 PMinfoWater Water is closed (Refresh)
dev:7892023-03-12 12:19:06.104 PMdebugWater event [name:switch, value:off]
dev:7892023-03-12 12:19:06.101 PMdebugWater parse: description is read attr - raw: BC630100060A00001000, dni: BC63, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:7892023-03-12 12:19:05.738 PMinfoWater Received device announcement, data=[1C, 63, BC, D7, 36, 01, 60, 2B, D5, B3, 70, 8E] (Sequence Number:1C, Device network ID: BC63, Capability Information: 8E)
dev:7892023-03-12 12:19:05.734 PMdebugWater Desc Map: [raw:catchall: 0000 0013 00 00 0040 00 BC63 00 00 0000 00 00 1C63BCD73601602BD5B3708E, profileId:0000, clusterId:0013, clusterInt:19, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:BC63, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[1C, 63, BC, D7, 36, 01, 60, 2B, D5, B3, 70, 8E]]
dev:7892023-03-12 12:19:05.731 PMdebugWater parse: description is catchall: 0000 0013 00 00 0040 00 BC63 00 00 0000 00 00 1C63BCD73601602BD5B3708E
dev:7892023-03-12 12:19:05.689 PMdebugWater sendZigbeeCommands (cmd=[he raw 0xBC63 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0xBC63 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, null, zdo bind 0xBC63 0x01 0x01 6 {70B3D52B600136D7} {}, delay 2000, he cr 0xBC63 0x01 6 0 16 0 600 {}, delay 2000, he wattr 0xBC63 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:7892023-03-12 12:19:05.686 PMdebugWater setting powerOnBehaviour to last state (2)
dev:7892023-03-12 12:19:05.682 PMdebugWater sendZigbeeCommands (cmd=[he rattr 0xBC63 0x01 6 0 {}, delay 2000])
dev:7892023-03-12 12:19:05.649 PMtraceWater polling..
dev:7892023-03-12 12:19:05.648 PMdebugWater sending refresh() command...
dev:7892023-03-12 12:19:05.640 PMinfoWater configure()..
dev:7892023-03-12 12:18:59.594 PMinfoWater Water is closed (Refresh)
dev:7892023-03-12 12:18:59.564 PMdebugWater event [name:switch, value:off]
dev:7892023-03-12 12:18:59.561 PMdebugWater parse: description is read attr - raw: CF8F0100060A00001000, dni: CF8F, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 00
dev:7892023-03-12 12:18:59.548 PMdebugWater parseZHAcommand writeAttributeResponse cluster: 0000 status:86
dev:7892023-03-12 12:18:59.545 PMdebugWater Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 CF8F 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:CF8F, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:7892023-03-12 12:18:59.535 PMdebugWater parse: description is catchall: 0104 0000 01 01 0040 00 CF8F 00 00 0000 04 01 86DEFF
dev:7892023-03-12 12:18:59.522 PMdebugWater Model is : TS0001
dev:7892023-03-12 12:18:59.520 PMdebugWater Tuya check-in message (attribute 0001 reported: 64)
dev:7892023-03-12 12:18:59.519 PMdebugWater zclVersion is : 02
dev:7892023-03-12 12:18:59.518 PMdebugWater Manufacturer is : _TZ3000_5ucujjts
dev:7892023-03-12 12:18:59.511 PMdebugWater Desc Map: [raw:CF8F01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni:CF8F, endpoint:01, cluster:0000, size:64, attrId:0004, encoding:42, command:01, value:_TZ3000_5ucujjts, clusterInt:0, attrInt:4, additionalAttrs:[[value:02, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:64, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0001, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:7892023-03-12 12:18:59.503 PMwarnexception caught while parsing description: read attr - raw: CF8F01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: CF8F, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
Hi @hoffadg ,
Thank you for the detailed logs! I will have the time to analyze them later tonight or in the next days, but shortly:
- These warnings are normal, I will change the warning level to Debug in the next version. A lot of Tuys devices do not follow the ZCL specs and the exception is thrown from the HE inbuilt function. There is nothing important in these Zigbee messages and they are not a problem.
- I see some 'null' values which is a bug, but it shouldn't affect the on/off basic functionality as well.
- The most worrying are the info logs "Received device announcement". This means that the device leaves and rejoins the Zigbee network.... Not good.
My device has also stopped working after updating the driver.
Itās a GiEX TS0601 (_TZE200_sh1btabb). Tuya version 1.0.6.
I also moved it from the C4 I had been using to a C7 at the same time. When it didnāt work at first I assumed the change of hubs might have been the issue. So I deleted the device and re-paired again. The process seemed like it worked fine (as it did the first time), but the device doesnāt respond to the open or close commands, nor does the status update if I manually open or close the valve.
Here is a detailed log when the device was paired. Then I think I pressed the Configure button again.
dev:45652023-03-12 10:35:01.748 AMerrorjava.lang.NullPointerException: Cannot invoke method length() on null object on line 1136 (method sendIrrigationDuration)
dev:45652023-03-12 10:34:52.232 AMinfoFountain valve configure()..
dev:45652023-03-12 10:34:52.225 AMinfoDebug logging is false Description text logging is true
dev:45652023-03-12 10:34:52.224 AMinfoUpdating Fountain valve (Tuya Zigbee Irrigation Valve) model TS0601_GIEX_VALVE
dev:45652023-03-12 10:33:31.359 AMinfoFountain valve configure()..
dev:45652023-03-12 10:33:31.353 AMinfoDebug logging is false Description text logging is true
dev:45652023-03-12 10:33:31.352 AMinfoUpdating Fountain valve (Tuya Zigbee Irrigation Valve) model TS0601_GIEX_VALVE
dev:45652023-03-12 10:32:51.461 AMerrorjava.lang.NullPointerException: Cannot invoke method length() on null object on line 1136 (method sendIrrigationDuration)
dev:45652023-03-12 10:29:20.919 AMerrorjava.lang.NullPointerException: Cannot invoke method length() on null object on line 1136 (method sendIrrigationDuration)
dev:45652023-03-12 10:29:10.613 AMinfoFountain valve configure()..
dev:45652023-03-12 10:29:10.606 AMinfoDebug logging is false Description text logging is true
dev:45652023-03-12 10:29:10.605 AMinfoUpdating Fountain valve (Tuya Zigbee Irrigation Valve) model TS0601_GIEX_VALVE
dev:45652023-03-12 10:28:30.435 AMinfoFountain valve configure()..
dev:45652023-03-12 10:28:30.419 AMinfoDebug logging is false Description text logging is true
dev:45652023-03-12 10:28:30.418 AMinfoUpdating Fountain valve (Tuya Zigbee Irrigation Valve) model TS0601_GIEX_VALVE
dev:45652023-03-12 10:28:01.882 AMinfoTuya Zigbee Irrigation Valve Initialization finished
dev:45652023-03-12 10:27:59.243 AMdebugTuya Zigbee Irrigation Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6AD8 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6AD8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:45652023-03-12 10:27:59.241 AMdebugTuya Zigbee Irrigation Valve parse: description is catchall: 0104 EF00 01 01 0040 00 6AD8 00 00 0000 0B 01 0000
dev:45652023-03-12 10:27:59.133 AMdebugTuya Zigbee Irrigation Valve parseZHAcommand writeAttributeResponse cluster: 0000 status:00
dev:45652023-03-12 10:27:59.130 AMdebugTuya Zigbee Irrigation Valve Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 6AD8 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6AD8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:45652023-03-12 10:27:59.128 AMdebugTuya Zigbee Irrigation Valve parse: description is catchall: 0104 0000 01 01 0040 00 6AD8 00 00 0000 04 01 00
dev:45652023-03-12 10:27:59.059 AMdebugTuya Zigbee Irrigation Valve Model is : TS0601
dev:45652023-03-12 10:27:59.057 AMdebugTuya Zigbee Irrigation Valve Tuya check-in message (attribute 0001 reported: 46)
dev:45652023-03-12 10:27:59.056 AMdebugTuya Zigbee Irrigation Valve zclVersion is : 03
dev:45652023-03-12 10:27:59.054 AMdebugTuya Zigbee Irrigation Valve Manufacturer is : _TZE200_sh1btabb
dev:45652023-03-12 10:27:59.050 AMdebugTuya Zigbee Irrigation Valve Desc Map: [raw:6AD801000068040042105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000, dni:6AD8, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_sh1btabb, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:46, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:45652023-03-12 10:27:59.044 AMwarnexception caught while parsing description: read attr - raw: 6AD801000068040042105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000, dni: 6AD8, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000
dev:45652023-03-12 10:27:59.037 AMdebugTuya Zigbee Irrigation Valve parse: description is read attr - raw: 6AD801000068040042105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000, dni: 6AD8, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000
dev:45652023-03-12 10:27:58.851 AMdebugTuya Zigbee Irrigation Valve sendZigbeeCommands (cmd=[he raw 0x6AD8 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x6AD8 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, null, zdo bind 0x6AD8 0x01 0x01 6 {A4C1383F231B1177} {}, delay 2000, he cr 0x6AD8 0x01 6 0 16 0 600 {}, delay 2000, he wattr 0x6AD8 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:45652023-03-12 10:27:58.848 AMdebugTuya Zigbee Irrigation Valve setting powerOnBehaviour to last state (2)
dev:45652023-03-12 10:27:58.840 AMdebugTuya Zigbee Irrigation Valve sendZigbeeCommands (cmd=[he raw 0x6AD8 1 0x01 0x0001 {10 00 00 20 00}, delay 100, he raw 0x6AD8 1 0x01 0x0001 {10 00 00 21 00}, delay 200, he cmd 0x6AD8 0x01 0xEF00 0x00 {00020100}, delay 2000])
dev:45652023-03-12 10:27:58.809 AMtraceTuya Zigbee Irrigation Valve polling..
dev:45652023-03-12 10:27:58.808 AMdebugTuya Zigbee Irrigation Valve sending refresh() command...
dev:45652023-03-12 10:27:58.802 AMinfoTuya Zigbee Irrigation Valve configure()..
dev:45652023-03-12 10:27:58.801 AMinfoDebug logging will be automatically switched off after 24 hours
dev:45652023-03-12 10:27:58.775 AMinfoDebug logging is true Description text logging is true
dev:45652023-03-12 10:27:58.774 AMinfoUpdating null (Tuya Zigbee Irrigation Valve) model TS0601_GIEX_VALVE
dev:45652023-03-12 10:27:58.769 AMtrace destinationEP = 01
dev:45652023-03-12 10:27:58.768 AMtrace model = TS0601
dev:45652023-03-12 10:27:58.733 AMinfoTuya Zigbee Irrigation Valve all states and scheduled jobs cleared!
dev:45652023-03-12 10:27:58.731 AMinfoTuya Zigbee Irrigation Valve device model TS0601 manufacturer _TZE200_sh1btabb deviceName was set to Tuya Zigbee Irrigation Valve
dev:45652023-03-12 10:27:58.704 AMdebugTuya Zigbee Irrigation Valve FOUND exact match! deviceName =Tuya Zigbee Irrigation Valve profileName=TS0601_GIEX_VALVE for model TS0601 manufacturer _TZE200_sh1btabb
dev:45652023-03-12 10:27:58.695 AMinfoTuya Zigbee Irrigation Valve InitializeVars()... fullInit = true
dev:45652023-03-12 10:27:58.679 AMinfoTuya Zigbee Irrigation Valve Initialize()...
dev:45652023-03-12 10:27:54.394 AMdebugTuya Zigbee Irrigation Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 6AD8 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:6AD8, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:45652023-03-12 10:27:54.391 AMdebugTuya Zigbee Irrigation Valve parse: description is catchall: 0104 EF00 01 01 0040 00 6AD8 00 00 0000 0B 01 0000
dev:45652023-03-12 10:27:54.131 AMdebugTuya Zigbee Irrigation Valve Model is : TS0601
dev:45652023-03-12 10:27:54.129 AMdebugTuya Zigbee Irrigation Valve Tuya check-in message (attribute 0001 reported: 46)
dev:45652023-03-12 10:27:54.127 AMdebugTuya Zigbee Irrigation Valve zclVersion is : 03
dev:45652023-03-12 10:27:54.125 AMdebugTuya Zigbee Irrigation Valve Manufacturer is : _TZE200_sh1btabb
dev:45652023-03-12 10:27:54.119 AMdebugTuya Zigbee Irrigation Valve Desc Map: [raw:6AD801000068040042105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000, dni:6AD8, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_sh1btabb, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:46, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:45652023-03-12 10:27:54.096 AMwarnexception caught while parsing description: read attr - raw: 6AD801000068040042105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000, dni: 6AD8, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000
dev:45652023-03-12 10:27:54.083 AMdebugTuya Zigbee Irrigation Valve parse: description is read attr - raw: 6AD801000068040042105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000, dni: 6AD8, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000
dev:45652023-03-12 10:27:54.073 AMdebugTuya Zigbee Irrigation Valve Model is : TS0601
dev:45652023-03-12 10:27:54.070 AMdebugTuya Zigbee Irrigation Valve Tuya check-in message (attribute 0001 reported: 46)
dev:45652023-03-12 10:27:54.068 AMdebugTuya Zigbee Irrigation Valve zclVersion is : 03
dev:45652023-03-12 10:27:54.066 AMdebugTuya Zigbee Irrigation Valve Manufacturer is : _TZE200_sh1btabb
dev:45652023-03-12 10:27:54.050 AMdebugTuya Zigbee Irrigation Valve Desc Map: [raw:6AD801000068040042105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000, dni:6AD8, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_sh1btabb, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:46, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:45652023-03-12 10:27:54.042 AMwarnexception caught while parsing description: read attr - raw: 6AD801000068040042105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000, dni: 6AD8, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000
dev:45652023-03-12 10:27:54.025 AMdebugTuya Zigbee Irrigation Valve parse: description is read attr - raw: 6AD801000068040042105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000, dni: 6AD8, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F73683162746162620000002003010000204605000042065453303630310700003003FEFF003000
dev:45652023-03-12 10:27:53.996 AMinfoTuya Zigbee Irrigation Valve is online
dev:45652023-03-12 10:27:53.819 AMdebugTuya Zigbee Irrigation Valve sendZigbeeCommands (cmd=[he raw 0x6AD8 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x6AD8 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, null, zdo bind 0x6AD8 0x01 0x01 6 {A4C1383F231B1177} {}, delay 2000, he cr 0x6AD8 0x01 6 0 16 0 600 {}, delay 2000, he wattr 0x6AD8 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:45652023-03-12 10:27:53.810 AMdebugTuya Zigbee Irrigation Valve setting powerOnBehaviour to last state (2)
dev:45652023-03-12 10:27:53.778 AMdebugTuya Zigbee Irrigation Valve sendZigbeeCommands (cmd=[he raw 0x6AD8 1 0x01 0x0001 {10 00 00 20 00}, delay 100, he raw 0x6AD8 1 0x01 0x0001 {10 00 00 21 00}, delay 200, he cmd 0x6AD8 0x01 0xEF00 0x00 {00020100}, delay 2000])
dev:45652023-03-12 10:27:53.735 AMtraceTuya Zigbee Irrigation Valve polling..
dev:45652023-03-12 10:27:53.731 AMdebugTuya Zigbee Irrigation Valve sending refresh() command...
dev:45652023-03-12 10:27:53.723 AMinfoTuya Zigbee Irrigation Valve configure()..
dev:45652023-03-12 10:27:53.715 AMdebugcalling initialize() after 5 seconds...
dev:45652023-03-12 10:27:53.658 AMtrace destinationEP = 01
dev:45652023-03-12 10:27:53.657 AMtrace model = TS0601
dev:45652023-03-12 10:27:53.655 AMinfoTuya Zigbee Irrigation Valve tuyaVersion set to 1.0.6
dev:45652023-03-12 10:27:53.589 AMinfoTuya Zigbee Irrigation Valve all states and scheduled jobs cleared!
dev:45652023-03-12 10:27:53.586 AMinfoTuya Zigbee Irrigation Valve device model TS0601 manufacturer _TZE200_sh1btabb deviceName was set to Tuya Zigbee Irrigation Valve
dev:45652023-03-12 10:27:53.553 AMdebugTuya Zigbee Valve FOUND exact match! deviceName =Tuya Zigbee Irrigation Valve profileName=TS0601_GIEX_VALVE for model TS0601 manufacturer _TZE200_sh1btabb
dev:45652023-03-12 10:27:53.532 AMinfoTuya Zigbee Valve InitializeVars()... fullInit = true
dev:45652023-03-12 10:27:53.530 AMinfoTuya Zigbee Valve Installed()...
@hunt.darren thank you for the report! There was a bug introduced in the latest version for GiEX valves, now should be fixed in the dev. branch version 1.2.2
@hoffadg the new version also contains some other minor fixes. I have also added a counter showing how many times the devices has rejoined the Zigbee network. However, this will not solve the problem with your device. I think it may be one these [C-7] Zigbee devices that do not pair correctly in HE . Checking the logs, the pattern is that it stays connected for about 5..6 seconds and then leaves the network. Same device surely will work with the new C-8 hub, as it may require a Zigbee 3.0 coordinator only.
Interesting.. I was able to get it to work temporarily by doing the following:
- Pair the device as usual
- Without removing the device, attempt to re-pair. It says it found an existing device
- Now go to the existing device and I am able to open and close
- A few seconds later it no longer works and rejoinCtr increases
It does sound like the problem may be that it leaves the network and re-joins. I read through the other thread you sent me.. I guess there is no workaround for this (other than getting a C-8 hub)?
