Thanks for the quick response!
I have imported the latest driver code.
Do you remember what was the automatic deviceProfile selection when you first installed it?
I don't recall but I do know it did not work right way until I changed the profile manually. Then I was able to control open/close.
Sorry for the screenshot.. Laziness on my part
dev:7952023-03-26 12:00:39.232 PMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 12:00:39.228 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 01 01 00040101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, 04, 01, 01, 00, 01, 01]]
dev:7952023-03-26 12:00:39.225 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 01 01 00040101000101
dev:7952023-03-26 12:00:39.194 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:7952023-03-26 12:00:39.192 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 00 00 0000 0B 01 0000
dev:7952023-03-26 12:00:39.113 PMdebugMain Water Valve sendZigbeeCommands (cmd=[he cmd 0x533D 0x01 0xEF00 0x00 {54040101000101} {}, delay 200])
dev:7952023-03-26 12:00:39.112 PMdebugMain Water Valve open()... sent cmds=[he cmd 0x533D 0x01 0xEF00 0x00 {54040101000101} {}, delay 200]
dev:7952023-03-26 12:00:39.089 PMtraceMain Water Valve sendTuyaCommand = [he cmd 0x533D 0x01 0xEF00 0x00 {54040101000101} {}, delay 200]
dev:7952023-03-26 12:00:37.050 PMtraceMain Water Valve Tuya cluster cmd=01 value=0 ()
dev:7952023-03-26 12:00:37.046 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 00]]
dev:7952023-03-26 12:00:37.044 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000100
dev:7952023-03-26 12:00:34.301 PMtraceMain Water Valve Tuya cluster cmd=01 value=0 ()
dev:7952023-03-26 12:00:34.298 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 00]]
dev:7952023-03-26 12:00:34.296 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000100
dev:7952023-03-26 12:00:25.137 PMtraceMain Water Valve Tuya cluster cmd=01 value=0 ()
dev:7952023-03-26 12:00:25.133 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 01 01 00C20101000100, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:01, direction:01, data:[00, C2, 01, 01, 00, 01, 00]]
dev:7952023-03-26 12:00:25.131 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 01 01 00C20101000100
dev:7952023-03-26 12:00:25.117 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 00 00 0000 0B 01 0000, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:0B, direction:01, data:[00, 00]]
dev:7952023-03-26 12:00:25.114 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 00 00 0000 0B 01 0000
dev:7952023-03-26 12:00:24.997 PMdebugMain Water Valve sendZigbeeCommands (cmd=[he cmd 0x533D 0x01 0xEF00 0x00 {51C20101000100} {}, delay 200])
dev:7952023-03-26 12:00:24.995 PMdebugMain Water Valve close()... sent cmds=[he cmd 0x533D 0x01 0xEF00 0x00 {51C20101000100} {}, delay 200]
dev:7952023-03-26 12:00:24.945 PMtraceMain Water Valve sendTuyaCommand = [he cmd 0x533D 0x01 0xEF00 0x00 {51C20101000100} {}, delay 200]
dev:7952023-03-26 12:00:24.561 PMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 12:00:24.557 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 12:00:24.555 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 12:00:21.815 PMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 12:00:21.811 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 12:00:21.809 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 12:00:19.066 PMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 12:00:19.063 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 12:00:19.060 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 12:00:16.313 PMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 12:00:16.310 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 12:00:16.308 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 12:00:13.563 PMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 12:00:13.559 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 12:00:13.557 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 12:00:10.818 PMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 12:00:10.815 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 12:00:10.812 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 12:00:08.063 PMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 12:00:08.060 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 12:00:08.057 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 12:00:05.314 PMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 12:00:05.311 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 12:00:05.308 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 12:00:02.564 PMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 12:00:02.560 PMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 12:00:02.558 PMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 12:00:00.829 PMtraceMain Water Valve polling..
dev:7952023-03-26 12:00:00.826 PMdebugMain Water Valve sending refresh() command...
dev:7952023-03-26 11:59:59.813 AMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 11:59:59.809 AMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 11:59:59.807 AMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 11:59:58.181 AMdebugMain Water Valve parseZHAcommand writeAttributeResponse cluster: E001 status:86
dev:7952023-03-26 11:59:58.178 AMdebugMain Water Valve Desc Map: [raw:catchall: 0104 E001 01 01 0040 00 533D 00 00 0000 04 01 8610D0, profileId:0104, clusterId:E001, clusterInt:57345, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, 10, D0]]
dev:7952023-03-26 11:59:58.175 AMdebugMain Water Valve parse: description is catchall: 0104 E001 01 01 0040 00 533D 00 00 0000 04 01 8610D0
dev:7952023-03-26 11:59:58.165 AMdebugMain Water Valve parseZHAcommand writeAttributeResponse cluster: 0000 status:00
dev:7952023-03-26 11:59:58.162 AMdebugMain Water Valve Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 533D 00 00 0000 04 01 00, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[00]]
dev:7952023-03-26 11:59:58.160 AMdebugMain Water Valve parse: description is catchall: 0104 0000 01 01 0040 00 533D 00 00 0000 04 01 00
dev:7952023-03-26 11:59:57.992 AMdebugMain Water Valve Model is : TS0601
dev:7952023-03-26 11:59:57.990 AMdebugMain Water Valve Tuya check-in message (attribute 0001 reported: 46)
dev:7952023-03-26 11:59:57.989 AMdebugMain Water Valve zclVersion is : 03
dev:7952023-03-26 11:59:57.987 AMdebugMain Water Valve Manufacturer is : _TZE200_d0ypnbvn
dev:7952023-03-26 11:59:57.983 AMdebugMain Water Valve Desc Map: [raw:533D01000068040042105F545A453230305F643079706E62766E0000002003010000204605000042065453303630310700003001FEFF003000, dni:533D, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_d0ypnbvn, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:46, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:7952023-03-26 11:59:57.976 AMdebugMain Water Valve exception caught while parsing description: read attr - raw: 533D01000068040042105F545A453230305F643079706E62766E0000002003010000204605000042065453303630310700003001FEFF003000, dni: 533D, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F643079706E62766E0000002003010000204605000042065453303630310700003001FEFF003000
dev:7952023-03-26 11:59:57.968 AMdebugMain Water Valve parse: description is read attr - raw: 533D01000068040042105F545A453230305F643079706E62766E0000002003010000204605000042065453303630310700003001FEFF003000, dni: 533D, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F643079706E62766E0000002003010000204605000042065453303630310700003001FEFF003000
dev:7952023-03-26 11:59:57.828 AMdebugMain Water Valve sendZigbeeCommands (cmd=[he raw 0x533D 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x533D 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, he wattr 0x533D 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:7952023-03-26 11:59:57.794 AMdebugMain Water Valve setting powerOnBehaviour to last state (2)
dev:7952023-03-26 11:59:57.773 AMinfoMain Water Valve configure()..
dev:7952023-03-26 11:59:57.772 AMinfoDebug logging will be automatically switched off after 24 hours
dev:7952023-03-26 11:59:57.740 AMinfoDebug logging is true Description text logging is true
dev:7952023-03-26 11:59:57.739 AMinfoUpdating Main Water Valve (Tuya Zigbee Valve) model TS0601_VALVE_ONOFF
dev:7952023-03-26 11:59:57.116 AMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 11:59:57.112 AMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 11:59:57.110 AMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 11:59:54.313 AMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 11:59:54.310 AMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 11:59:54.308 AMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 11:59:51.564 AMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 11:59:51.560 AMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 11:59:51.558 AMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 11:59:48.816 AMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 11:59:48.813 AMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 11:59:48.810 AMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 11:59:46.065 AMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 11:59:46.061 AMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 11:59:46.059 AMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 11:59:43.317 AMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 11:59:43.313 AMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 11:59:43.311 AMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
dev:7952023-03-26 11:59:40.585 AMtraceMain Water Valve Tuya cluster cmd=01 value=1 ()
dev:7952023-03-26 11:59:40.581 AMdebugMain Water Valve Desc Map: [raw:catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:533D, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:02, direction:01, data:[00, 00, 01, 01, 00, 01, 01]]
dev:7952023-03-26 11:59:40.578 AMdebugMain Water Valve parse: description is catchall: 0104 EF00 01 01 0040 00 533D 01 00 0000 02 01 00000101000101
