I noticed my hub firmware was out of date so I updated that and tried to re-pair. Still no response to open/close but I do see now the RxCtr is 3.
Here is the full log from the point I paired up until I attempted to send open/close several times.
dev:7842023-03-12 10:19:30.288 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 1 {}, delay 2000])
dev:7842023-03-12 10:19:30.287 AMdebugWater Main Valve open()... sent cmds=[he cmd 0x780E 0x01 6 1 {}, delay 2000]
dev:7842023-03-12 10:19:28.614 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:19:28.612 AMdebugWater Main Valve close()... sent cmds=[he cmd 0x780E 0x01 6 0 {}, delay 2000]
dev:7842023-03-12 10:19:23.179 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 1 {}, delay 2000])
dev:7842023-03-12 10:19:23.177 AMdebugWater Main Valve open()... sent cmds=[he cmd 0x780E 0x01 6 1 {}, delay 2000]
dev:7842023-03-12 10:19:20.807 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:19:20.806 AMdebugWater Main Valve close()... sent cmds=[he cmd 0x780E 0x01 6 0 {}, delay 2000]
dev:7842023-03-12 10:19:14.891 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:19:14.890 AMdebugWater Main Valve close()... sent cmds=[he cmd 0x780E 0x01 6 0 {}, delay 2000]
dev:7842023-03-12 10:19:10.091 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 1 {}, delay 2000])
dev:7842023-03-12 10:19:10.090 AMdebugWater Main Valve open()... sent cmds=[he cmd 0x780E 0x01 6 1 {}, delay 2000]
dev:7842023-03-12 10:19:00.937 AMdebugWater Main Valve sendZigbeeCommands (cmd=[he cmd 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:19:00.935 AMdebugWater Main Valve close()... sent cmds=[he cmd 0x780E 0x01 6 0 {}, delay 2000]
dev:7842023-03-12 10:18:42.355 AMinfoTuya Zigbee Valve Initialization finished
dev:7842023-03-12 10:18:39.603 AMdebugTuya Zigbee Valve parseZHAcommand writeAttributeResponse cluster: 0000 status:86
dev:7842023-03-12 10:18:39.598 AMdebugTuya Zigbee Valve Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 780E 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:780E, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:7842023-03-12 10:18:39.595 AMdebugTuya Zigbee Valve parse: description is catchall: 0104 0000 01 01 0040 00 780E 00 00 0000 04 01 86DEFF
dev:7842023-03-12 10:18:39.567 AMdebugTuya Zigbee Valve Model is : TS0001
dev:7842023-03-12 10:18:39.565 AMdebugTuya Zigbee Valve Tuya check-in message (attribute 0001 reported: 64)
dev:7842023-03-12 10:18:39.564 AMdebugTuya Zigbee Valve zclVersion is : 02
dev:7842023-03-12 10:18:39.560 AMdebugTuya Zigbee Valve Manufacturer is : _TZ3000_5ucujjts
dev:7842023-03-12 10:18:39.500 AMdebugTuya Zigbee Valve Desc Map: [raw:780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni:780E, endpoint:01, cluster:0000, size:64, attrId:0004, encoding:42, command:01, value:_TZ3000_5ucujjts, clusterInt:0, attrInt:4, additionalAttrs:[[value:02, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:64, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0001, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:7842023-03-12 10:18:39.491 AMwarnexception caught while parsing description: read attr - raw: 780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: 780E, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7842023-03-12 10:18:39.481 AMdebugTuya Zigbee Valve parse: description is read attr - raw: 780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: 780E, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7842023-03-12 10:18:39.442 AMinfoTuya Zigbee Valve Tuya Zigbee Valve is open (Refresh)
dev:7842023-03-12 10:18:39.409 AMdebugTuya Zigbee Valve Valve state changed from unknown to open
dev:7842023-03-12 10:18:39.408 AMdebugTuya Zigbee Valve event [name:switch, value:on]
dev:7842023-03-12 10:18:39.404 AMdebugTuya Zigbee Valve parse: description is read attr - raw: 780E0100060A00001001, dni: 780E, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01
dev:7842023-03-12 10:18:39.312 AMdebugTuya Zigbee Valve sendZigbeeCommands (cmd=[he raw 0x780E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x780E 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, null, zdo bind 0x780E 0x01 0x01 6 {70B3D52B600136D7} {}, delay 2000, he cr 0x780E 0x01 6 0 16 0 600 {}, delay 2000, he wattr 0x780E 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:7842023-03-12 10:18:39.310 AMdebugTuya Zigbee Valve settings.batteryReporting = null
dev:7842023-03-12 10:18:39.307 AMdebugTuya Zigbee Valve setting powerOnBehaviour to last state (2)
dev:7842023-03-12 10:18:39.298 AMdebugTuya Zigbee Valve sendZigbeeCommands (cmd=[he rattr 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:18:39.266 AMtraceTuya Zigbee Valve polling..
dev:7842023-03-12 10:18:39.265 AMdebugTuya Zigbee Valve sending refresh() command...
dev:7842023-03-12 10:18:39.258 AMinfoTuya Zigbee Valve configure()..
dev:7842023-03-12 10:18:39.256 AMinfoDebug logging will be automatically switched off after 24 hours
dev:7842023-03-12 10:18:39.223 AMinfoDebug logging is true Description text logging is true
dev:7842023-03-12 10:18:39.221 AMinfoUpdating null (Tuya Zigbee Valve) model UNKNOWN
dev:7842023-03-12 10:18:39.212 AMtrace destinationEP = 01
dev:7842023-03-12 10:18:39.211 AMtrace model = TS0001
dev:7842023-03-12 10:18:39.161 AMinfoTuya Zigbee Valve all states and scheduled jobs cleared!
dev:7842023-03-12 10:18:39.159 AMwarnTuya Zigbee Valve device model TS0001 manufacturer _TZ3000_5ucujjts was not found!
dev:7842023-03-12 10:18:39.156 AMwarnTuya Zigbee Valve unknown model TS0001 manufacturer _TZ3000_5ucujjts
dev:7842023-03-12 10:18:39.131 AMinfoTuya Zigbee Valve InitializeVars()... fullInit = true
dev:7842023-03-12 10:18:39.103 AMinfoTuya Zigbee Valve Initialize()...
dev:7842023-03-12 10:18:34.652 AMdebugTuya Zigbee Valve parseZHAcommand writeAttributeResponse cluster: 0000 status:86
dev:7842023-03-12 10:18:34.642 AMdebugTuya Zigbee Valve Desc Map: [raw:catchall: 0104 0000 01 01 0040 00 780E 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:780E, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:7842023-03-12 10:18:34.637 AMdebugTuya Zigbee Valve parse: description is catchall: 0104 0000 01 01 0040 00 780E 00 00 0000 04 01 86DEFF
dev:7842023-03-12 10:18:34.614 AMdebugTuya Zigbee Valve Model is : TS0001
dev:7842023-03-12 10:18:34.611 AMdebugTuya Zigbee Valve Tuya check-in message (attribute 0001 reported: 64)
dev:7842023-03-12 10:18:34.609 AMdebugTuya Zigbee Valve zclVersion is : 02
dev:7842023-03-12 10:18:34.606 AMdebugTuya Zigbee Valve Manufacturer is : _TZ3000_5ucujjts
dev:7842023-03-12 10:18:34.566 AMdebugTuya Zigbee Valve Desc Map: [raw:780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni:780E, endpoint:01, cluster:0000, size:64, attrId:0004, encoding:42, command:01, value:_TZ3000_5ucujjts, clusterInt:0, attrInt:4, additionalAttrs:[[value:02, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:64, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0001, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]]
dev:7842023-03-12 10:18:34.554 AMwarnexception caught while parsing description: read attr - raw: 780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: 780E, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7842023-03-12 10:18:34.528 AMdebugTuya Zigbee Valve parse: description is read attr - raw: 780E01000064040042105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86, dni: 780E, endpoint: 01, cluster: 0000, size: 64, attrId: 0004, encoding: 42, command: 01, value: 105F545A333030305F357563756A6A74730000002002010000206405000042065453303030310700003001FEFF86
dev:7842023-03-12 10:18:34.488 AMinfoTuya Zigbee Valve Tuya Zigbee Valve is open (Refresh)
dev:7842023-03-12 10:18:34.454 AMdebugTuya Zigbee Valve Valve state changed from unknown to open
dev:7842023-03-12 10:18:34.447 AMdebugTuya Zigbee Valve event [name:switch, value:on]
dev:7842023-03-12 10:18:34.436 AMdebugTuya Zigbee Valve parse: description is read attr - raw: 780E0100060A00001001, dni: 780E, endpoint: 01, cluster: 0006, size: 0A, attrId: 0000, encoding: 10, command: 01, value: 01
dev:7842023-03-12 10:18:34.434 AMinfoTuya Zigbee Valve is online
dev:7842023-03-12 10:18:34.335 AMdebugTuya Zigbee Valve sendZigbeeCommands (cmd=[he raw 0x780E 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 150, he wattr 0x780E 0x01 0x0000 0xFFDE 0x20 {0D} {}, delay 50, null, zdo bind 0x780E 0x01 0x01 6 {70B3D52B600136D7} {}, delay 2000, he cr 0x780E 0x01 6 0 16 0 600 {}, delay 2000, he wattr 0x780E 0x01 0xE001 0xD010 0x30 {02} {}, delay 251])
dev:7842023-03-12 10:18:34.333 AMdebugTuya Zigbee Valve settings.batteryReporting = null
dev:7842023-03-12 10:18:34.321 AMdebugTuya Zigbee Valve setting powerOnBehaviour to last state (2)
dev:7842023-03-12 10:18:34.246 AMdebugTuya Zigbee Valve sendZigbeeCommands (cmd=[he rattr 0x780E 0x01 6 0 {}, delay 2000])
dev:7842023-03-12 10:18:34.207 AMtraceTuya Zigbee Valve polling..
dev:7842023-03-12 10:18:34.205 AMdebugTuya Zigbee Valve sending refresh() command...
dev:7842023-03-12 10:18:34.127 AMinfoTuya Zigbee Valve configure()..
dev:7842023-03-12 10:18:34.117 AMdebugcalling initialize() after 5 seconds...
dev:7842023-03-12 10:18:34.070 AMtrace destinationEP = 01
dev:7842023-03-12 10:18:34.068 AMtrace model = TS0001
dev:7842023-03-12 10:18:34.066 AMinfoTuya Zigbee Valve tuyaVersion set to 1.2.4
dev:7842023-03-12 10:18:33.970 AMinfoTuya Zigbee Valve all states and scheduled jobs cleared!
dev:7842023-03-12 10:18:33.963 AMwarnTuya Zigbee Valve device model TS0001 manufacturer _TZ3000_5ucujjts was not found!
dev:7842023-03-12 10:18:33.960 AMwarnTuya Zigbee Valve unknown model TS0001 manufacturer _TZ3000_5ucujjts
dev:7842023-03-12 10:18:33.922 AMinfoTuya Zigbee Valve InitializeVars()... fullInit = true
dev:7842023-03-12 10:18:33.911 AMinfoTuya Zigbee Valve Installed()...
