The sensing ability to turn on the switch of this product is good. It reacts right away. However, compared to round ceiling type products, Off tends to be a little late. The ability to detect presence for a long time is also insufficient compared to ceiling sensors. However, this sensor has the advantage of being small and easy to attach to walls and ceilings.
Hey Guys, Lucky me finally got my TS0601 Ceiling mount device just got delivered ! In any event I have 2 questions:
What is the proper orientation for the cover? The cover has 2 different openings, 1 is a slot the other is a pinhole.
It appears there was a misstep or someone had a really bad hangover on the manufacturing line. And I want to be sure no components are missing or were damaged as someone cut through the plastic case with their teeth, a can opener, sawzall? Whatever it was it looks like crap.
Anyone else receive a device that looks like the photo?
Welcome to the club. @Rxich ! : )
I don’t have access to a PC at the moment and can’t see the picture very well, but it seems to me that there is only one sensor on the board, so position the bigger opening over the illuminance sensor.
Which model is this? Any reference to ‘fall detection’?
Probably what you see as a blank board is the silk mask over the mmWave antenna… let’s hope!
Thank you Krassimir. On the read it's stamped ZY-M100 and I believe I purchased from the link above.
Here's the product https://www.aliexpress.us/item/3256803919760969.html?spm=a2g0o.order_list.0.0.1fa91802DhHWyX&gatewayAdapt=glo2usa&_randl_shipto=US
The fingerprint matches the one below. I find it incredible the variety of these devices, while being advertised the same. Does the word "Tuya" in Chinese translate to random chaos?
fingerprint profileId:"0104", endpointId:"01", inClusters:"0000,0004,0005,EF00", outClusters:"0019,000A", model:"TS0601", manufacturer:"_TZE200_ztc6ggyl", deviceJoinName: "Tuya ZigBee Breath Presence Sensor ZY-M100"
It’s the same device that I have. I am pretty happy with the presence sensing performance, it keeps the living room lights on when I am laying still watching TV about 4.5 .. 5 meters from it. I have mounted it horizontally placed on top of , a cabinet at the other wall of the room, aimed to the couch.
What are doing? You should be working on new drivers🤪
It is working perfectly. Hopefully it will stay connected like many of my other Tuya devices. I'm amazed at the incredible variety of Zigbee devices Tuya sells. Tuya is really filling a huge void in affordable Zigbee devices. I am so tempted to get one of their hubs, but not sure if its of any benefit or what I could use it for? Maybe a very stable Zigbee mesh..
And Krassimir, Tuya needs to put you on their payroll. I'm fairly certain they have sold thousands more devices due to your drivers. Again a huge thank you !
@kkossev, is this driver supposed to work with the OWON ZigBee Occupancy Sensor OPS305?
I have one, and the driver seems to recognize the device, but it doesnt register any events?
Hi @parish99 ,
As I don't have this device I can not test it myself, but it was reported some months ago by another user that the driver works. Probably, something was changed since then.
Please enable de Debug logging and pair the device again to HE. Can you copy and paste the logs since the time the Zigbee pairing process started for this device?
Device Logs
dev:11722022-11-27 11:03:55.761 PMwarnOWON Unprocessed ZDO command: cluster=8001 command=00 attrId=null value=null data=[8B, 00, 9A, A5, D1, FE, FF, 2C, 6A, 3C, BC, 7C]
dev:11722022-11-27 11:03:55.758 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8001 00 00 0040 00 7CBC 00 00 0000 00 00 8B009AA5D1FEFF2C6A3CBC7C, profileId:0000, clusterId:8001, clusterInt:32769, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[8B, 00, 9A, A5, D1, FE, FF, 2C, 6A, 3C, BC, 7C]]
dev:11722022-11-27 11:03:11.800 PMinfoTuya Multi Sensor 4 In 1 Received bind response, data=[53, 8D] (Sequence Number:53, Status: Failure)
dev:11722022-11-27 11:03:11.798 PMdebugTuya Multi Sensor 4 In 1 parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 538D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[53, 8D]]
dev:11722022-11-27 11:03:11.653 PMinfoTuya Multi Sensor 4 In 1 Received bind response, data=[52, 8D] (Sequence Number:52, Status: Failure)
dev:11722022-11-27 11:03:11.651 PMdebugTuya Multi Sensor 4 In 1 parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 528D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[52, 8D]]
dev:11722022-11-27 11:03:11.398 PMinfoTuya Multi Sensor 4 In 1 Received bind response, data=[51, 8D] (Sequence Number:51, Status: Failure)
dev:11722022-11-27 11:03:11.395 PMdebugTuya Multi Sensor 4 In 1 parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 518D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[51, 8D]]
dev:11722022-11-27 11:03:11.101 PMdebugTuya Multi Sensor 4 In 1 write attribute response is FAILURE
dev:11722022-11-27 11:03:11.099 PMdebugTuya Multi Sensor 4 In 1 parse(OWON) descMap = [raw:catchall: 0104 0000 01 01 0040 00 7CBC 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:11722022-11-27 11:03:10.558 PMinfoTuya Multi Sensor 4 In 1 installed()
Zigbee Logs
OWON2022-11-27 23:03:55.834 profileId:0x0, clusterId:0x8001, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-61
Tuya Multi Sensor 4 In 12022-11-27 23:03:11.864 profileId:0x0, clusterId:0x8021, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-61
Tuya Multi Sensor 4 In 12022-11-27 23:03:11.662 profileId:0x0, clusterId:0x8021, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-61
Tuya Multi Sensor 4 In 12022-11-27 23:03:11.459 profileId:0x0, clusterId:0x8021, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-61
Tuya Multi Sensor 4 In 12022-11-27 23:03:11.055 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:255, lastHopRssi:-61
Tuya Multi Sensor 4 In 12022-11-27 23:03:10.853 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:255, lastHopRssi:-61
7CBC2022-11-27 23:03:10.449 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:255, lastHopRssi:-61
7CBC2022-11-27 23:03:10.347 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:255, lastHopRssi:-61
7CBC2022-11-27 23:03:10.245 profileId:0x104, clusterId:0x0, sourceEndpoint:1, destinationEndpoint:1 , groupId:0, lastHopLqi:255, lastHopRssi:-61
7CBC2022-11-27 23:03:10.044 profileId:0x0, clusterId:0x8004, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-61
7CBC2022-11-27 23:03:10.042 profileId:0x0, clusterId:0x8005, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-61
7CBC2022-11-27 23:03:09.940 profileId:0x0, clusterId:0x8005, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-61
7CBC2022-11-27 23:03:09.134 profileId:0x0, clusterId:0x13, sourceEndpoint:0, destinationEndpoint:0 , groupId:0, lastHopLqi:255, lastHopRssi:-62
During Device Configuration
dev:11722022-11-27 11:06:57.024 PMinfoOWON Initialization finished version=1.0.13 (Timestamp: 2022/09/25 8:48 PM)
dev:11722022-11-27 11:06:57.022 PMinfoOWON manufacturer = OWON
dev:11722022-11-27 11:06:55.716 PMinfoOWON reported Power source 04
dev:11722022-11-27 11:06:55.714 PMdebugOWON parse(OWON) descMap = [raw:7CBC0100001007003004FEFF86, dni:7CBC, endpoint:01, cluster:0000, size:10, attrId:0007, encoding:30, command:01, value:04, clusterInt:0, attrInt:7, additionalAttrs:[[status:86, attrId:FFFE, attrInt:65534]]]
dev:11722022-11-27 11:06:55.670 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 07 00 FE FF}, delay 200])
dev:11722022-11-27 11:06:55.668 PMdebugOWON refresh()...
dev:11722022-11-27 11:06:55.055 PMinfoOWON Received bind response, data=[68, 8D] (Sequence Number:68, Status: Failure)
dev:11722022-11-27 11:06:55.052 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 688D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[68, 8D]]
dev:11722022-11-27 11:06:55.040 PMinfoOWON preferencies updates are sent to the device...
dev:11722022-11-27 11:06:55.037 PMdebugOWON sendZigbeeCommands (cmd=[])
dev:11722022-11-27 11:06:55.035 PMdebugOWON sending the changed AdvancedOptions
dev:11722022-11-27 11:06:55.027 PMdebugOWON Config parameters changed! old=2424320913d37f1d813fbd new=2424320913d37f1d813fbd
dev:11722022-11-27 11:06:55.019 PMinfoOWON Debug logging is will be turned off after 24 hours
dev:11722022-11-27 11:06:54.991 PMinfoOWON Debug logging is true; Description text logging is true
dev:11722022-11-27 11:06:54.988 PMinfoOWON Updating OWON (Tuya Multi Sensor 4 In 1) model OCP305 manufacturer OWON
dev:11722022-11-27 11:06:54.807 PMinfoOWON Received bind response, data=[67, 8D] (Sequence Number:67, Status: Failure)
dev:11722022-11-27 11:06:54.805 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 678D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[67, 8D]]
dev:11722022-11-27 11:06:54.604 PMinfoOWON Received bind response, data=[66, 8D] (Sequence Number:66, Status: Failure)
dev:11722022-11-27 11:06:54.602 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 668D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[66, 8D]]
dev:11722022-11-27 11:06:54.203 PMdebugOWON write attribute response is FAILURE
dev:11722022-11-27 11:06:54.200 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0104 0000 01 01 0040 00 7CBC 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:11722022-11-27 11:06:54.067 PMinfoOWON Tuya device manufacturer is OWON
dev:11722022-11-27 11:06:54.062 PMdebugOWON parse(OWON) descMap = [raw:7CBC0100004C040042044F574F4E0000002003010000200105000042064F43503330350700003004FEFF86, dni:7CBC, endpoint:01, cluster:0000, size:4C, attrId:0004, encoding:42, command:01, value:OWON, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:01, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:OCP305, encoding:42, attrId:0005, consumedBytes:9, attrInt:5], [value:04, encoding:30, attrId:0007, consumedBytes:4, attrInt:7]]]
dev:11722022-11-27 11:06:54.046 PMinfoOWON is present
dev:11722022-11-27 11:06:53.953 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7CBC 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x7CBC 0x02 0x01 0x0402 {3C6A2CFFFED1A59A} {}, delay 200, zdo bind 0x7CBC 0x02 0x01 0x0405 {3C6A2CFFFED1A59A} {}, delay 200, zdo bind 0x7CBC 0x03 0x01 0x0400 {3C6A2CFFFED1A59A} {}])
dev:11722022-11-27 11:06:53.911 PMinfoOWON configure()..
dev:11722022-11-27 11:06:53.900 PMinfoOWON installed()
dev:11722022-11-27 11:06:53.898 PMdebugOWON state.hashStringPars = 2424320913d37f1d813fbd
dev:11722022-11-27 11:06:53.803 PMinfoOWON InitializeVars( fullInit = true )...
dev:11722022-11-27 11:06:53.777 PMinfoOWON Initialize( fullInit = true )...
dev:11722022-11-27 11:06:52.558 PMinfoOWON Received bind response, data=[63, 8D] (Sequence Number:63, Status: Failure)
dev:11722022-11-27 11:06:52.556 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 638D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[63, 8D]]
dev:11722022-11-27 11:06:52.358 PMinfoOWON Received bind response, data=[62, 8D] (Sequence Number:62, Status: Failure)
dev:11722022-11-27 11:06:52.356 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 628D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[62, 8D]]
dev:11722022-11-27 11:06:52.229 PMinfoOWON Received bind response, data=[61, 8D] (Sequence Number:61, Status: Failure)
dev:11722022-11-27 11:06:52.226 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 618D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[61, 8D]]
dev:11722022-11-27 11:06:51.746 PMdebugOWON write attribute response is FAILURE
dev:11722022-11-27 11:06:51.744 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0104 0000 01 01 0040 00 7CBC 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:11722022-11-27 11:06:51.561 PMinfoOWON Tuya device manufacturer is OWON
dev:11722022-11-27 11:06:51.556 PMdebugOWON parse(OWON) descMap = [raw:7CBC0100004C040042044F574F4E0000002003010000200105000042064F43503330350700003004FEFF86, dni:7CBC, endpoint:01, cluster:0000, size:4C, attrId:0004, encoding:42, command:01, value:OWON, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:01, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:OCP305, encoding:42, attrId:0005, consumedBytes:9, attrInt:5], [value:04, encoding:30, attrId:0007, consumedBytes:4, attrInt:7]]]
dev:11722022-11-27 11:06:51.500 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7CBC 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x7CBC 0x02 0x01 0x0402 {3C6A2CFFFED1A59A} {}, delay 200, zdo bind 0x7CBC 0x02 0x01 0x0405 {3C6A2CFFFED1A59A} {}, delay 200, zdo bind 0x7CBC 0x03 0x01 0x0400 {3C6A2CFFFED1A59A} {}])
dev:11722022-11-27 11:06:51.436 PMinfoOWON configure()..
dev:11722022-11-27 11:06:44.500 PMinfoOWON Initialization finished version=1.0.13 (Timestamp: 2022/09/25 8:48 PM)
dev:11722022-11-27 11:06:44.495 PMinfoOWON manufacturer = OWON
dev:11722022-11-27 11:06:43.308 PMinfoOWON reported Power source 04
dev:11722022-11-27 11:06:43.303 PMdebugOWON parse(OWON) descMap = [raw:7CBC0100001007003004FEFF86, dni:7CBC, endpoint:01, cluster:0000, size:10, attrId:0007, encoding:30, command:01, value:04, clusterInt:0, attrInt:7, additionalAttrs:[[status:86, attrId:FFFE, attrInt:65534]]]
dev:11722022-11-27 11:06:43.262 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 07 00 FE FF}, delay 200])
dev:11722022-11-27 11:06:43.260 PMdebugOWON refresh()...
dev:11722022-11-27 11:06:42.512 PMinfoOWON Received bind response, data=[5D, 8D] (Sequence Number:5D, Status: Failure)
dev:11722022-11-27 11:06:42.510 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 5D8D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[5D, 8D]]
dev:11722022-11-27 11:06:42.498 PMinfoOWON preferencies updates are sent to the device...
dev:11722022-11-27 11:06:42.496 PMdebugOWON sendZigbeeCommands (cmd=[])
dev:11722022-11-27 11:06:42.494 PMdebugOWON sending the changed AdvancedOptions
dev:11722022-11-27 11:06:42.486 PMdebugOWON Config parameters changed! old=2424320913d37f1d813fbd new=2424320913d37f1d813fbd
dev:11722022-11-27 11:06:42.481 PMinfoOWON Debug logging is will be turned off after 24 hours
dev:11722022-11-27 11:06:42.453 PMinfoOWON Debug logging is true; Description text logging is true
dev:11722022-11-27 11:06:42.450 PMinfoOWON Updating OWON (Tuya Multi Sensor 4 In 1) model OCP305 manufacturer OWON
dev:11722022-11-27 11:06:42.286 PMinfoOWON Received bind response, data=[5C, 8D] (Sequence Number:5C, Status: Failure)
dev:11722022-11-27 11:06:42.284 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 5C8D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[5C, 8D]]
dev:11722022-11-27 11:06:42.092 PMinfoOWON Received bind response, data=[5B, 8D] (Sequence Number:5B, Status: Failure)
dev:11722022-11-27 11:06:42.090 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 5B8D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[5B, 8D]]
dev:11722022-11-27 11:06:41.675 PMdebugOWON write attribute response is FAILURE
dev:11722022-11-27 11:06:41.673 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0104 0000 01 01 0040 00 7CBC 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:11722022-11-27 11:06:41.520 PMinfoOWON Tuya device manufacturer is OWON
dev:11722022-11-27 11:06:41.515 PMdebugOWON parse(OWON) descMap = [raw:7CBC0100004C040042044F574F4E0000002003010000200105000042064F43503330350700003004FEFF86, dni:7CBC, endpoint:01, cluster:0000, size:4C, attrId:0004, encoding:42, command:01, value:OWON, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:01, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:OCP305, encoding:42, attrId:0005, consumedBytes:9, attrInt:5], [value:04, encoding:30, attrId:0007, consumedBytes:4, attrInt:7]]]
dev:11722022-11-27 11:06:41.504 PMinfoOWON is present
dev:11722022-11-27 11:06:41.426 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7CBC 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x7CBC 0x02 0x01 0x0402 {3C6A2CFFFED1A59A} {}, delay 200, zdo bind 0x7CBC 0x02 0x01 0x0405 {3C6A2CFFFED1A59A} {}, delay 200, zdo bind 0x7CBC 0x03 0x01 0x0400 {3C6A2CFFFED1A59A} {}])
dev:11722022-11-27 11:06:41.385 PMinfoOWON configure()..
dev:11722022-11-27 11:06:41.381 PMinfoOWON installed()
dev:11722022-11-27 11:06:41.378 PMdebugOWON state.hashStringPars = 2424320913d37f1d813fbd
dev:11722022-11-27 11:06:41.282 PMinfoOWON InitializeVars( fullInit = true )...
dev:11722022-11-27 11:06:41.267 PMinfoOWON Initialize( fullInit = true )...
dev:11722022-11-27 11:06:39.125 PMinfoOWON Received bind response, data=[58, 8D] (Sequence Number:58, Status: Failure)
dev:11722022-11-27 11:06:39.123 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 588D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[58, 8D]]
dev:11722022-11-27 11:06:38.923 PMinfoOWON Received bind response, data=[57, 8D] (Sequence Number:57, Status: Failure)
dev:11722022-11-27 11:06:38.920 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 578D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[57, 8D]]
dev:11722022-11-27 11:06:38.721 PMinfoOWON Received bind response, data=[56, 8D] (Sequence Number:56, Status: Failure)
dev:11722022-11-27 11:06:38.719 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 568D, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[56, 8D]]
dev:11722022-11-27 11:06:38.320 PMdebugOWON write attribute response is FAILURE
dev:11722022-11-27 11:06:38.317 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0104 0000 01 01 0040 00 7CBC 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:11722022-11-27 11:06:38.186 PMinfoOWON Tuya device manufacturer is OWON
dev:11722022-11-27 11:06:38.180 PMdebugOWON parse(OWON) descMap = [raw:7CBC0100004C040042044F574F4E0000002003010000200105000042064F43503330350700003004FEFF86, dni:7CBC, endpoint:01, cluster:0000, size:4C, attrId:0004, encoding:42, command:01, value:OWON, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:01, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:OCP305, encoding:42, attrId:0005, consumedBytes:9, attrInt:5], [value:04, encoding:30, attrId:0007, consumedBytes:4, attrInt:7]]]
dev:11722022-11-27 11:06:38.068 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7CBC 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x7CBC 0x02 0x01 0x0402 {3C6A2CFFFED1A59A} {}, delay 200, zdo bind 0x7CBC 0x02 0x01 0x0405 {3C6A2CFFFED1A59A} {}, delay 200, zdo bind 0x7CBC 0x03 0x01 0x0400 {3C6A2CFFFED1A59A} {}])
dev:11722022-11-27 11:06:37.991 PMinfoOWON configure()..
What I see from the logs is that the binding command to the motion/occupancy cluster fails...
Will need more time to analyze what could be wrong.
Where did you purchase this device from? Last time I checked it was available for sale only directly from the manufacturer in China?
I think that I found and hopefully corrected the problem (binding to cluster 0x0406).
Please update the driver to the new dev.branch version 1.0.15 timeStamp 2022/11/28 7:48 AM and press the Configure or the Initialize button.
Is this device also supposed to report temperature and illuminance?
Making progress, motion now reports as active or inactive. Response time seems pretty slow compared to the aquara sitting next it.
dev:11722022-11-29 08:57:21.608 PMinfoOWON Motion reset to inactive after 49s
dev:11722022-11-29 08:57:21.605 PMdebugOWON parse(OWON) descMap = [raw:7CBC0104060800001800, dni:7CBC, endpoint:01, cluster:0406, size:08, attrId:0000, encoding:18, command:0A, value:00, clusterInt:1030, attrInt:0]
dev:11722022-11-29 08:56:32.459 PMinfoOWON Detected motion
dev:11722022-11-29 08:56:32.455 PMdebugOWON parse(OWON) descMap = [raw:7CBC0104060800001801, dni:7CBC, endpoint:01, cluster:0406, size:08, attrId:0000, encoding:18, command:0A, value:01, clusterInt:1030, attrInt:0]
dev:11722022-11-29 08:56:24.309 PMinfoOWON Motion reset to inactive after 116s
dev:11722022-11-29 08:56:24.306 PMdebugOWON parse(OWON) descMap = [raw:7CBC0104060800001800, dni:7CBC, endpoint:01, cluster:0406, size:08, attrId:0000, encoding:18, command:0A, value:00, clusterInt:1030, attrInt:0]
dev:11722022-11-29 08:55:27.075 PMinfoOWON Motion is active 59s
dev:11722022-11-29 08:55:27.072 PMdebugOWON parse(OWON) descMap = [raw:7CBC0104060800001801, dni:7CBC, endpoint:01, cluster:0406, size:08, attrId:0000, encoding:18, command:0A, value:01, clusterInt:1030, attrInt:0]
dev:11722022-11-29 08:55:13.692 PMinfoOWON preferencies updates are sent to the device...
dev:11722022-11-29 08:55:13.690 PMdebugOWON sendZigbeeCommands (cmd=[])
dev:11722022-11-29 08:55:13.689 PMdebugOWON sending the changed AdvancedOptions
dev:11722022-11-29 08:55:13.683 PMdebugOWON Config parameters changed! old=2424320913d37f1d813fbd new=2424320913d37f1d813fbd
dev:11722022-11-29 08:55:13.677 PMinfoOWON Debug logging is will be turned off after 24 hours
dev:11722022-11-29 08:55:13.631 PMinfoOWON Debug logging is true; Description text logging is true
dev:11722022-11-29 08:55:13.630 PMinfoOWON Updating OWON (Tuya Multi Sensor 4 In 1) model OCP305 manufacturer OWON
dev:11722022-11-29 08:55:10.687 PMinfoOWON Motion is active 42s
dev:11722022-11-29 08:55:10.683 PMdebugOWON parse(OWON) descMap = [raw:7CBC0104060800001881, dni:7CBC, endpoint:01, cluster:0406, size:08, attrId:0000, encoding:18, command:0A, value:81, clusterInt:1030, attrInt:0]
dev:11722022-11-29 08:54:51.907 PMinfoOWON preferencies updates are sent to the device...
dev:11722022-11-29 08:54:51.905 PMdebugOWON sendZigbeeCommands (cmd=[])
dev:11722022-11-29 08:54:51.904 PMdebugOWON sending the changed AdvancedOptions
dev:11722022-11-29 08:54:51.899 PMdebugOWON Config parameters changed! old=2424320913d37f1d813fbd new=2424320913d37f1d813fbd
dev:11722022-11-29 08:54:51.894 PMinfoOWON Debug logging is will be turned off after 24 hours
dev:11722022-11-29 08:54:51.836 PMinfoOWON Debug logging is true; Description text logging is true
dev:11722022-11-29 08:54:51.835 PMinfoOWON Updating OWON (Tuya Multi Sensor 4 In 1) model OCP305 manufacturer OWON
dev:11722022-11-29 08:54:28.353 PMinfoOWON Detected motion
dev:11722022-11-29 08:54:28.345 PMdebugOWON parse(OWON) descMap = [raw:7CBC0104060800001801, dni:7CBC, endpoint:01, cluster:0406, size:08, attrId:0000, encoding:18, command:0A, value:01, clusterInt:1030, attrInt:0]
dev:11722022-11-29 08:54:17.207 PMinfoOWON Initialization finished
version=1.0.15 (Timestamp: 2022/11/28 7:48 AM)
dev:11722022-11-29 08:54:17.206 PMinfoOWON manufacturer = OWON
dev:11722022-11-29 08:54:17.163 PMinfoOWON reported Power source 04
dev:11722022-11-29 08:54:17.160 PMdebugOWON parse(OWON) descMap = [raw:7CBC0100001007003004FEFF86, dni:7CBC, endpoint:01, cluster:0000, size:10, attrId:0007, encoding:30, command:01, value:04, clusterInt:0, attrInt:7, additionalAttrs:[[status:86, attrId:FFFE, attrInt:65534]]]
dev:11722022-11-29 08:54:17.118 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 07 00 FE FF}, delay 200])
dev:11722022-11-29 08:54:17.117 PMdebugOWON refresh()...
dev:11722022-11-29 08:54:15.199 PMinfoOWON preferencies updates are sent to the device...
dev:11722022-11-29 08:54:15.197 PMdebugOWON sendZigbeeCommands (cmd=[])
dev:11722022-11-29 08:54:15.196 PMdebugOWON sending the changed AdvancedOptions
dev:11722022-11-29 08:54:15.188 PMdebugOWON Config parameters changed! old=2424320913d37f1d813fbd new=2424320913d37f1d813fbd
dev:11722022-11-29 08:54:15.181 PMinfoOWON Debug logging is will be turned off after 24 hours
dev:11722022-11-29 08:54:15.155 PMinfoOWON Debug logging is true; Description text logging is true
dev:11722022-11-29 08:54:15.154 PMinfoOWON Updating OWON (Tuya Multi Sensor 4 In 1) model OCP305 manufacturer OWON
dev:11722022-11-29 08:54:14.775 PMinfoOWON Received bind response, data=[21, 00] (Sequence Number:21, Status: Success)
dev:11722022-11-29 08:54:14.772 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 2100, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[21, 00]]
dev:11722022-11-29 08:54:14.372 PMdebugOWON write attribute response is FAILURE
dev:11722022-11-29 08:54:14.369 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0104 0000 01 01 0040 00 7CBC 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:11722022-11-29 08:54:14.236 PMinfoOWON Tuya device manufacturer is OWON
dev:11722022-11-29 08:54:14.228 PMdebugOWON parse(OWON) descMap = [raw:7CBC0100004C040042044F574F4E0000002003010000200105000042064F43503330350700003004FEFF86, dni:7CBC, endpoint:01, cluster:0000, size:4C, attrId:0004, encoding:42, command:01, value:OWON, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:01, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:OCP305, encoding:42, attrId:0005, consumedBytes:9, attrInt:5], [value:04, encoding:30, attrId:0007, consumedBytes:4, attrInt:7]]]
dev:11722022-11-29 08:54:14.222 PMinfoOWON is present
dev:11722022-11-29 08:54:14.125 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7CBC 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x7CBC 0x01 0x01 0x0406 {3C6A2CFFFED1A59A} {}])
dev:11722022-11-29 08:54:14.085 PMinfoOWON configure()..
dev:11722022-11-29 08:54:14.079 PMinfoOWON installed()
dev:11722022-11-29 08:54:14.078 PMdebugOWON state.hashStringPars = 2424320913d37f1d813fbd
dev:11722022-11-29 08:54:13.985 PMinfoOWON InitializeVars( fullInit = true )...
dev:11722022-11-29 08:54:13.966 PMinfoOWON Initialize( fullInit = true )...
dev:11722022-11-29 08:54:11.518 PMinfoOWON Received bind response, data=[1E, 00] (Sequence Number:1E, Status: Success)
dev:11722022-11-29 08:54:11.514 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8021 00 00 0040 00 7CBC 00 00 0000 00 00 1E00, profileId:0000, clusterId:8021, clusterInt:32801, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[1E, 00]]
dev:11722022-11-29 08:54:11.114 PMdebugOWON write attribute response is FAILURE
dev:11722022-11-29 08:54:11.110 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0104 0000 01 01 0040 00 7CBC 00 00 0000 04 01 86DEFF, profileId:0104, clusterId:0000, clusterInt:0, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:04, direction:01, data:[86, DE, FF]]
dev:11722022-11-29 08:54:11.008 PMinfoOWON Tuya device manufacturer is OWON
dev:11722022-11-29 08:54:10.988 PMdebugOWON parse(OWON) descMap = [raw:7CBC0100004C040042044F574F4E0000002003010000200105000042064F43503330350700003004FEFF86, dni:7CBC, endpoint:01, cluster:0000, size:4C, attrId:0004, encoding:42, command:01, value:OWON, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:01, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:OCP305, encoding:42, attrId:0005, consumedBytes:9, attrInt:5], [value:04, encoding:30, attrId:0007, consumedBytes:4, attrInt:7]]]
dev:11722022-11-29 08:54:10.867 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7CBC 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x7CBC 0x01 0x01 0x0406 {3C6A2CFFFED1A59A} {}])
dev:11722022-11-29 08:54:10.823 PMinfoOWON configure()..
dev:11722022-11-29 08:54:09.869 PMwarnOWON Unprocessed ZDO command: cluster=8001 command=00 attrId=null value=null data=[A7, 00, 9A, A5, D1, FE, FF, 2C, 6A, 3C, BC, 7C]
dev:11722022-11-29 08:54:09.860 PMdebugOWON parse(OWON) descMap = [raw:catchall: 0000 8001 00 00 0040 00 7CBC 00 00 0000 00 00 A7009AA5D1FEFF2C6A3CBC7C, profileId:0000, clusterId:8001, clusterInt:32769, sourceEndpoint:00, destinationEndpoint:00, options:0040, messageType:00, dni:7CBC, isClusterSpecific:false, isManufacturerSpecific:false, manufacturerId:0000, command:00, direction:00, data:[A7, 00, 9A, A5, D1, FE, FF, 2C, 6A, 3C, BC, 7C]]
dev:11722022-11-29 08:54:09.852 PMinfoOWON is present
dev:11722022-11-29 08:53:39.145 PMinfoOWON Initialization finished
dev:11722022-11-29 08:53:39.145 PMinfoOWON manufacturer = OWON
dev:11722022-11-29 08:53:39.096 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 07 00 FE FF}, delay 200])
dev:11722022-11-29 08:53:39.095 PMdebugOWON refresh()...
dev:11722022-11-29 08:53:37.143 PMinfoOWON preferencies updates are sent to the device...
dev:11722022-11-29 08:53:37.142 PMdebugOWON sendZigbeeCommands (cmd=[])
dev:11722022-11-29 08:53:37.141 PMdebugOWON sending the changed AdvancedOptions
dev:11722022-11-29 08:53:37.135 PMdebugOWON Config parameters changed! old=2424320913d37f1d813fbd new=2424320913d37f1d813fbd
dev:11722022-11-29 08:53:37.128 PMinfoOWON Debug logging is will be turned off after 24 hours
dev:11722022-11-29 08:53:37.107 PMinfoOWON Debug logging is true; Description text logging is true
dev:11722022-11-29 08:53:37.106 PMinfoOWON Updating OWON (Tuya Multi Sensor 4 In 1) model OCP305 manufacturer OWON
dev:11722022-11-29 08:53:36.084 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7CBC 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x7CBC 0x01 0x01 0x0406 {3C6A2CFFFED1A59A} {}])
dev:11722022-11-29 08:53:36.053 PMinfoOWON configure()..
dev:11722022-11-29 08:53:36.047 PMinfoOWON installed()
dev:11722022-11-29 08:53:36.046 PMdebugOWON state.hashStringPars = 2424320913d37f1d813fbd
dev:11722022-11-29 08:53:35.965 PMinfoOWON InitializeVars( fullInit = true )...
dev:11722022-11-29 08:53:35.946 PMinfoOWON Initialize( fullInit = true )...
dev:11722022-11-29 08:53:30.907 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7CBC 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x7CBC 0x01 0x01 0x0406 {3C6A2CFFFED1A59A} {}])
dev:11722022-11-29 08:53:30.872 PMinfoOWON configure()..
dev:11722022-11-29 08:53:22.714 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200, he wattr 0x7CBC 0x01 0x0000 0xFFDE 0x20 {13} {}, delay 200, delay 200, zdo bind 0x7CBC 0x01 0x01 0x0406 {3C6A2CFFFED1A59A} {}])
dev:11722022-11-29 08:53:22.667 PMinfoOWON configure()..
dev:11722022-11-29 08:53:13.910 PMinfoOWON preferencies updates are sent to the device...
dev:11722022-11-29 08:53:13.908 PMdebugOWON sendZigbeeCommands (cmd=[])
dev:11722022-11-29 08:53:13.907 PMdebugOWON sending the changed AdvancedOptions
dev:11722022-11-29 08:53:13.899 PMdebugOWON Config parameters changed! old=2424320913d37f1d813fbd new=2424320913d37f1d813fbd
dev:11722022-11-29 08:53:13.892 PMinfoOWON Debug logging is will be turned off after 24 hours
dev:11722022-11-29 08:53:13.842 PMinfoOWON Debug logging is true; Description text logging is true
dev:11722022-11-29 08:53:13.841 PMinfoOWON Updating OWON (Tuya Multi Sensor 4 In 1) model OCP305 manufacturer OWON
dev:11722022-11-29 08:53:07.160 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 07 00 FE FF}, delay 200])
dev:11722022-11-29 08:53:07.159 PMdebugOWON refresh()...
dev:11722022-11-29 08:53:05.741 PMdebugOWON sendZigbeeCommands (cmd=[he raw 0x7CBC 1 0x01 0x0000 {10 00 00 07 00 FE FF}, delay 200])
dev:11722022-11-29 08:53:05.740 PMdebugOWON refresh()...
dev:11722022-11-29 08:52:11.807 PMinfoOWON Initialization finished
dev:11722022-11-29 08:52:11.806 PMinfoOWON manufacturer = OWON
dev:11722022-11-29 08:52:09.780 PMinfoOWON preferencies updates are sent to the device...
dev:11722022-11-29 08:52:09.778 PMdebugOWON sendZigbeeCommands (cmd=[])
dev:11722022-11-29 08:52:09.776 PMdebugOWON sending the changed AdvancedOptions
dev:11722022-11-29 08:52:09.769 PMdebugOWON Config parameters changed! old=2424320913d37f1d813fbd new=2424320913d37f1d813fbd
dev:11722022-11-29 08:52:09.760 PMinfoOWON Debug logging is will be turned off after 24 hours
dev:11722022-11-29 08:52:09.738 PMinfoOWON Debug logging is true; Description text logging is true
dev:11722022-11-29 08:52:09.736 PMinfoOWON Updating OWON (Tuya Multi Sensor 4 In 1) model OCP305 manufacturer OWON
dev:11722022-11-29 08:52:08.676 PMinfoOWON configure()..
dev:11722022-11-29 08:52:08.671 PMinfoOWON installed()
dev:11722022-11-29 08:52:08.550 PMinfoOWON InitializeVars( fullInit = true )...
dev:11722022-11-29 08:52:08.534 PMinfoOWON Initialize( fullInit = true )...
dev:11722022-11-29 08:52:04.292 PMinfoOWON configure()..
I wish I had been more closely following the forum when this thread started and everyone was bustling over radars. I really like the idea of them...all of you who got one are you still using it and what's the multi-month review?
Another question...most of the products recommended in this thread seem to be ceiling mount...I suppose I'm not terribly opposed to cutting random holes in my ceilings...but how in the heck are you guys getting power to them mounted in the ceiling?
I am and with great pleasure.
In my case, it's a bathroom ceiling with AC unit above the ceiling and ceiling light as well, so no problem to dd another main powered device.
Nice. Fortunate situation. I don’t think there’s a single room in my house where I could easily add a ceiling device. =( Definitely not in a way remotely close to building code compliant.
Which of the devices are you using?
Yes, I have two (different ones) and am actively using them both. I have the sinister black one and the wall mount one.
Work really well now I understand the parameters they operate under. The black one is limited range and not configurable, plus looks very creepy. The white wall mount one (same as the ceiling one people rave about) is good though - excellent range and tuneable. Both are 5v powered.
Will buy some more.
I am using this one:
https://www.aliexpress.com/item/1005004147995775.html?spm=a2g0o.order_list.order_list_main.32.5e13180244VLE6
No attic access? Definitely agree with the building code comment though. Since most of these are line voltage, they'd have to be put in a box (plus, in Illinois, the wires have to go through conduit)...
There's one that's 200VAC... that's an EXTRA hole for a accessible junction box to hold a voltage converter. Heck no.
ugh.
