REVISIONS HISTORY:
- ver. 1.0.0 2022-04-16 - Inital test version
- ver. 1.0.1 2022-04-18 - IAS cluster multiple TS0202, TS0210 and RH3040 Motion Sensors fingerprints; ignore repeated motion inactive events
- ver. 1.0.2 2022-04-19 - setMotion command; state.HashStringPars; advancedOptions: ledEnable
- ver. 1.0.3 2022-05-05 - added '_TZE200_ztc6ggyl' 'Tuya ZigBee Breath Presence Sensor' ; Illuminance unit changed to 'lx'
- ver. 1.0.4 2022-05-06 - added isHumanPresenceSensorAIR(); isHumanPresenceSensorScene(); isHumanPresenceSensorFall(); convertTemperatureIfNeeded
- ver. 1.0.5 2022-06-11 - _TZE200_3towulqd +battery; 'Reset Motion to Inactive' made explicit option; sensitivity and keepTime for IAS sensors (TS0202-tested OK) and TS0601(not tested); capability "PowerSource" used as presence
- ver. 1.0.6 2022-07-10 - battery set to 0% and motion inactive when the device goes OFFLINE;
- ver. 1.0.7 2022-07-16 - _TZE200_ikvncluo (MOES) and _TZE200_lyetpprm radars; scale fadingTime and detectionDelay by 10; initialize() will resets to defaults; radar parameters update bug fix; removed unused states and attributes for radars
- ver. 1.0.8 2022-07-24 _TZE200_auin8mzr (HumanPresenceSensorAIR) unacknowledgedTime; setLEDMode; setDetectionMode commands and vSensitivity; oSensitivity, vacancyDelay preferences; _TZE200_9qayzqa8 (black sensor) Attributes: motionType; preferences: inductionTime; targetDistance.
- ver. 1.0.9 2022-08-11 kkossev - degrees Celsius symbol bug fix; added square black radar _TZE200_0u3bj3rc support, temperatureOffset bug fix; decimal/number type prferences bug fix
- ver 1.0.10 2022-08-15 - (dev. branch) - added Lux threshold parameter; square black radar LED configuration is resent back when device is powered on; round black PIR sensor powerSource is set to DC; added OWNON OCP305 Presence Sensor
- ver. 1.0.11 2022-08-22 - IAS devices initialization improvements; presence threshold increased to 4 hours; 3in1 exceptions bug fixes; 3in1 and 4in1 exceptions bug fixes;
- ver. 1.0.12 2022-09-05 - added _TZE200_wukb7rhc MOES radar
- ver. 1.0.13 2022-09-14 - added _TZE200_jva8ink8 AUBESS radar; 2-in-1 Sensitivity setting bug fix
- ver. 1.0.14 2022-10-31 - added Bond motion sensor ZX-BS-J11W fingerprint for tests
- ver. 1.0.15 2022-12-03 - OWON 0x0406 cluster binding; added _TZE204_ztc6ggyl _TZE200_ar0slwnd _TZE200_sfiy5tfs _TZE200_mrf6vtua (was wrongly 3in1) mmWave radards;
- ver. 1.1.0 2022-12-25 - SetPar() command; added 'Send Event when parameters change' option; code cleanup; added _TZE200_holel4dk; added 4-in-1 _TZ3210_rxqls8v0, _TZ3000_6ygjfyll, _TZ3210_wuhzzfqg
- ver. 1.1.1 2023-01-07 - illuminance event bug fix; fadingTime minimum value 0.5; SetPar command shows in the UI the list of all possible parameters; _TZ3000_6ygjfyll bug fix;
- ver. 1.2.0 2023-02-06- healthStatus; supressed repetative Radar detection delay and Radar fading time Info messages in the logs; logsOff missed when hub is restarted bug fix; capability 'Health Check'; _TZE200_3towulqd (2in1) new firmware versions fix for motion and battery %;
- ver. 1.2.1 2023-02-10 - reverted the unsuccessful changes made in the latest 1.2.0 version for _TZE200_3towulqd (2in1); added _TZE200_v6ossqfy as BlackSquareRadar; removed the wrongly added TUYATEC T/H sensor...
- ver. 1.2.2 2023-03-18 - typo in a log transaction fixed; added TS0202 _TZ3000_kmh5qpmb as a 3-in-1 type device'; added _TZE200_xpq2rzhq radar; bug fix in setMotion()
- ver. 1.3.0 2023-03-22 kkossev -'_TYST11_7hfcudw5' moved to 3-in-1 group; added deviceProfiles; fixed initializaiton missing on the first pairing; added batteryVoltage; added tuyaVersion; added delayed battery event; removed state.lastBattery; caught sensitivity par exception; fixed forcedProfile was not set automatically on Initialize;
- ver. 1.3.1 2023-03-29 - added 'invertMotion' option; 4in1 (Fantem) Refresh Tuya Magic; invertMotion is set to true by default for _TZE200_3towulqd;
- ver. 1.3.2 2023-04-17 - 4-in-1 parameter for adjusting the reporting time; supressed debug logs when ignoreDistance is flipped on; 'Send Event when parameters change' parameter is removed (events are always sent when there is a change); fadingTime and detectionDelay change was not logged and not sent as an event;
- ver. 1.3.3 2023-05-14 - code cleanup; added TS0202 _TZ3210_cwamkvua [Motion Sensor and Scene Switch]; added _TZE204_sooucan5 radar in a new TS0601_YXZBRB58_RADAR group (for tests); added reportingTime4in1 to setPar command options;
- ver. 1.3.4 2023-05-19 - added _TZE204_sxm7l9xa mmWave radar to TS0601_YXZBRB58_RADAR group; isRadar() bug fix;
- ver. 1.3.5 2023-05-28 - fixes for _TZE200_lu01t0zlTS0601_RADAR_MIR-TY-FALL mmWave radar (only the basic Motion and radarSensitivity is supported for now).
ver. 1.3.6 2023-06-25 - chatty radars excessive debug logging bug fix. - ver. 1.3.7 2023-07-19 - fixes for _TZE204_sooucan5; moved _TZE204_sxm7l9xa to a new Device Profile TS0601_SXM7L9XA_RADAR; added TS0202 _TZ3040_bb6xaihh _TZ3040_wqmtjsyk;
- ver. 1.4.0 2023-08-06 - added new TS0225 _TZE200_hl0ss9oa 24GHz radar (TS0225_HL0SS9OA_RADAR); added basic support for the new TS0601 _TZE204_sbyx0lm6 radar w/ relay; added Hive MOT003; added sendCommand; added TS0202 _TZ3040_6ygjfyll
- ver. 1.4.1 2023-08-14 - TS0225_HL0SS9OA_RADAR ignoring ZCL illuminance and IAS motion reports; added radarAlarmMode, radarAlarmVolume, radarAlarmTime, Radar Static Detection Minimum Distance; added TS0225_AWARHUSB_RADAR TS0225_EGNGMRZH_RADAR
- ver. 1.4.2 2023-08-15 - 'Tuya Motion Sensor and Scene Switch' driver clone (Button capabilities enabled)
- ver. 1.4.3 2023-08-17 - TS0225 _TZ3218_awarhusb device profile changed to TS0225_LINPTECH_RADAR; cluster 0xE002 parser; added TS0601 _TZE204_ijxvkhd0 to TS0601_IJXVKHD0_RADAR; added _TZE204_dtzziy1e, _TZE200_ypprdwsl _TZE204_xsm7l9xa; YXZBRB58 radar illuminance and fadingTime bug fixes; added new TS0225_2AAELWXK_RADAR profile
- ver. 1.4.4 2023-08-18 - Method too large: Script1.processTuyaCluster ...
TS0225_LINPTECH_RADAR: myParseDescriptionAsMap & swapOctets(); deleteAllCurrentStates(); TS0225_2AAELWXK_RADAR preferences configuration and commands; added Illuminance correction coefficient; code cleanup - ver. 1.5.0 2023-08-27 - added TS0601 _TZE204_yensya2c radar; refactoring: deviceProfilesV2: tuyaDPs; unknownDPs; added _TZE204_clrdrnya; _TZE204_mhxn2jso; 2in1: _TZE200_1ibpyhdc, _TZE200_bh3n6gk8; added TS0202 _TZ3000_jmrgyl7o _TZ3000_hktqahrq _TZ3000_kmh5qpmb _TZ3040_usvkzkyn; added TS0601 _TZE204_kapvnnlk new device profile TS0601_KAPVNNLK_RADAR
- ver. 1.5.1 2023-09-09 - _TZE204_kapvnnlk fingerprint and DPs correction; added 2AAELWXK preferences; TS0225_LINPTECH_RADAR known preferences using E002 cluster
- ver. 1.5.2 2023-09-14 - TS0601_IJXVKHD0_RADAR ignore dp1 dp2; Distance logs changed to Debug; Refresh() updates driver version;
- ver. 1.5.3 2023-09-30 kkossev - humanMotionState re-enabled for TS0225_HL0SS9OA_RADAR; tuyaVersion is updated on Refresh; LINPTECH: added existance_time event; illuminance parsing exception changed to debug level; leave_time changed to fadingTime; fadingTime configuration
- ver. 1.6.0 2023-10-08 - (dev. branch) major refactoring of the preferences input; all preference settings are reset to defaults when changing device profile; added 'all' attribute; present state 'motionStarted' in a human-readable form. setPar and sendCommand major refactoring +parameters changed from enum to string; TS0601_KAPVNNLK_RADAR parameters support;
- ver. 1.6.1 2023-10-12 kkossev - (dev. branch) TS0601_KAPVNNLK_RADAR TS0225_HL0SS9OA_RADAR TS0225_2AAELWXK_RADAR TS0601_RADAR_MIR-HE200-TY TS0601_YXZBRB58_RADAR TS0601_SXM7L9XA_RADAR TS0601_IJXVKHD0_RADAR TS0601_YENSYA2C_RADAR TS0601_SBYX0LM6_RADAR TS0601_PIR_AIR TS0601_PIR_PRESENCE refactoring; radar enum preferences;
- ver. 1.6.2 2023-10-14 - (dev. branch) LINPTECH preferences changed to enum type; enum preferences - set defaultValue; TS0601_PIR_PRESENCE - preference inductionTime changed to fadingTime, humanMotionState sent as event; TS0225_2AAELWXK_RADAR - preferences setting; _TZE204_ijxvkhd0 fixes; Linptech fixes; added radarAlarmMode radarAlarmVolume;
- ver. 1.6.3 2023-10-15 - (dev. branch) setPar() and preferences updates bug fixes; automatic fix for preferences which type was changed between the versions, including bool;
- ver. 1.6.4 2023-10-18 - (dev. branch) added TS0601 _TZE204_e5m9c5hl to SXM7L9XA profile; added a bunch of new manufacturers to SBYX0LM6 profile;
- ver. 1.6.5 2023-10-23 - (dev. branch) bugfix: setPar decimal values for enum types; added SONOFF_SNZB-06P_RADAR; added SIHAS_USM-300Z_4_IN_1; added SONOFF_MOTION_IAS; TS0202_MOTION_SWITCH _TZ3210_cwamkvua refactoring; luxThreshold hardcoded to 0 and not configurable!; do not try to input preferences of a type bool; TS0601_2IN1 refactoring; added keepTime and sensitivity attributes for PIR sensors; added _TZE200_ppuj1vem 3-in-1; TS0601_3IN1 refactoring; added _TZ3210_0aqbrnts 4in1;
- ver. 1.6.6 2023-11-02 - _TZE204_ijxvkhd0 staticDetectionSensitivity bug fix; SONOFF radar clusters binding; assign profile UNKNOWN for unknown devices; SONOFF radar cluster FC11 attr 2001 processing as occupancy; TS0601_IJXVKHD0_RADAR sensitivity as number; number type pars are scalled also!; _TZE204_ijxvkhd0 sensitivity settings changes; added preProc function; TS0601_IJXVKHD0_RADAR - removed multiplying by 10
- ver. 1.6.7 2023-11-09 - divideBy10 fix for TS0601_IJXVKHD0_RADAR; added new TS0202_MOTION_IAS_CONFIGURABLE group
- ver. 1.6.8 2023-11-20 kkossev - SONOFF SNZB-06P RADAR bug fixes; added radarSensitivity and fadingTime preferences; update parameters for Tuya radars bug fix;
- ver. 1.7.0 2024-01-14 kkossev - Groovy linting; added TS0225_O7OE4N9A_RADAR TS0225 _TZFED8_o7oe4n9a for tests; TS0601 _TZE200_3towulqd new fingerprint @JdThomas24
- ver. 1.8.0 2024-03-23 kkossev - more Groovy linting; fixed 'This driver requires HE version 2.2.7 (May 2021) or newer!' bug; device.latestState('battery') exception bug fixes;
- ver. 1.8.1 2024-04-16 kkossev - tuyaDPs list of maps bug fixes; added _TZE204_kyhbrfyl; added smallMotionDetectionSensitivity;
- ver. 1.9.0 2024-05-06 - deprecated all radars except Linptech;
- ver. 1.9.1 2024-05-25 - preferences are not sent for depricated devices.
- ver. 1.9.2 2024-06-15 - deviceProfile drop-down list bug fix; added quickRef link to GitHub WiKi page for PIR sensors;
- ver. 3.2.0 2024-05-26 - first version, based on the mmWave radar driver code : depricated Linptech; added TS0202 add _TYZB01_vwqnz1sn;
- ver. 3.2.1 2024-05-31 - commonLib ver 3.2.1 allignment; tested 2In1 _TZE200_3towulqd ; new device profile group 'RH3040_TUYATEC'; SiHAS;
- ver. 3.2.2 2024-07-05 - created motionLib; restored 'all' attribute
- ver. 3.2.3 2024-07-27 - added Sonoff SNZB-03P
- ver. 3.3.0 2024-08-30 - main branch release.
- ver. 3.3.1 2024-10-26 - added TS0601 _TZE200_f1pvdgoh into a new device profile group 'TS0601_2IN1_MYQ_ZMS03'
- ver. 3.3.2 2024-11-30 - added Azoula Zigbee 4 in 1 Multi Sensor model:'HK-SENSOR-4IN1-A', manufacturer:'Sunricher' into SIHAS group
- ver. 3.3.3 2025-01-29 - TS0601 _TZE200_ppuj1vem moved to 'TS0601_2IN1_MYQ_ZMS03' deviceProfile @ltdonjohnson
- ver. 3.4.0 2025-03-03 - added customConfigureDevice(); SNZB-03 configuration bug fixes; added SNZB-03P device profile;
- ver. 3.4.1 2025-03-29 - added custom configuration function for Espressif @ilkeraktuna
- ver. 3.5.0 2025-04-08 - urgent fix for java.lang.CloneNotSupportedException
- ver. 3.5.1 2025-04-25 - HE platfrom version 2.4.1.x decimal preferences range patch/workaround.
- ver. 3.5.2 2025-07-14 - bug fix: 'sendDelayedBatteryEvent' exception
The development branch version that contains the latest additions and bug fixes can be manually downloaded from here: https://raw.githubusercontent.com/kkossev/Hubitat/development/Drivers/Tuya%20Multi%20Sensor%204%20In%201/Tuya%20Multi%20Sensor%204%20In%201.groovy
An archive containing older driver versions is available here .
