[RELEASE] Tuya ZigBee Chlorine Meter 7 in 1
There is a new interesting device based on Tuya platform - Chlorine Meter !
AliExpress .us : (link)
AliExpress .com : (link)
AliExpress .kr : (link)
Apparently, the same device is available on Amazon combined with a Tuya Zigbee GW for double the price :
Amazon .com : (link)
Measures :
  • PH : test ranges: 0.0-14.0ph; Resolution: 0.1ph; Accuracy: ±0.1ph
  • CL : test ranges: 0.0-4.0mg/L; Resolution: 0.1mg/L; Accuracy: ±0.1mg/L
  • Salt : test ranges: 0-999ppm, 1000-9990ppm; Resolution: 1ppm, 10ppm; Accuracy: ±2% F.S
  • EC : test ranges: 0-2000us/c m , 2000-9990uS/c m,10.01- 19.99mS/c m; Resolution: 1uS/c m 10uS/c m 0.01mS/C M; Accuracy: ±2% F.S.
  • Total Dissolved Solids : test ranges: 0-999ppm,1000- 9990pp, Resolution: 1ppm 10ppm; Accuracy: ±2% F.S.
  • ORP : test ranges: -999mv ~+999mv; Resolution: 1mv; Accuracy:15mv
  • Temperature : test ranges: 0.0℃-50.0℃ 32.0℉-122.0℉; Resolution: 0.1℃/0.1℉; Accuracy: ±0.5℃
Update 09/07/2024:
It will be interesting if someone has also the WaterGuru Sense S2 Smart Pool Monitor , which is priced seven times (!) more expensive and can compare the results ...
Hubitat custom driver :
https://raw.githubusercontent.com/kkossev/Hubitat/development/Drivers/Tuya%20Zigbee%20Chlorine%20Meter/Tuya_Zigbee_Chlorine_Meter_lib_included.groovy
The driver is now available for installation via HPM, simply search for 'chlorine' :
A word of caution: I don't know if the measurements of this '7 in 1' device are accurate enough. I don't have one and I don't plan to buy one (and I don't think I'll have a pool anytime soon... :slight_smile: ).
As always, Amazon reviews are controversial. Experiment at your own risk.
Great, looking forward to this one. I don´t have a pool, but a hot tub. I will be putting in an order, let's see how fast I will receive the device.
Please update when you get this, I am curious about this for my hot tub as well.
You use chlorine or bromine in yours? I use bromine, but hoping the PH, TDS, and some other readings will be helpful even if I have to ignore chlorine.
I ordered this product. The seller hasn't shipped it yet, and I think it will arrive within 2 weeks.
Yes, will do. I use Chlorine now. Have used Bromine in the past but it didn't work as well.
I was looking for one of these a couple of years ago - obviously I was ahead of time!
Would definitely be interested in buying and testing the driver!
This product doesn't seem to be of good quality.
Device pairing info
Manufacturer: _TZE200_v1jqz5cy
Endpoint 01 application: 41
Endpoint 01 endpointId: 01
Endpoint 01 idAsInt: 1
Endpoint 01 inClusters: 0000,0004,0005,EF00
Endpoint 01 initialized: true
Endpoint 01 manufacturer: _TZE200_v1jqz5cy
Endpoint 01 model: TS0601
Endpoint 01 outClusters: 0019,000A
Endpoint 01 profileId: 0104
Endpoint 01 stage: 4
Summary
dev:1332024-08-30 03:59:05.437 PMinfoTuya Zigbee mmWave Sensor updated
dev:1332024-08-30 03:59:05.390 PMinfoscheduling health check every 240 minutes by Activity check method
dev:1332024-08-30 03:59:05.358 PMinfoTuya Zigbee mmWave Sensor driver version 3.2.4 2024/07/31 5:20 PM (TS0601 _TZE200_v1jqz5cy) (C-7 2.3.9.176)
dev:1332024-08-30 03:59:05.354 PMinfoTuya Zigbee mmWave Sensor updated()...
dev:1332024-08-30 03:59:02.775 PMinfoTuya Zigbee mmWave Sensor is now online!
dev:1332024-08-30 03:59:02.773 PMinfoTuya Zigbee mmWave Sensor healthStatus changed to online
dev:1332024-08-30 03:59:02.770 PMinfoTuya Zigbee mmWave Sensor tuyaVersion set to 1.0.1
dev:1332024-08-30 03:59:02.752 PMinfoTuya Zigbee mmWave Sensor device model TS0601 manufacturer _TZE200_v1jqz5cy was not found!
dev:1332024-08-30 03:59:02.749 PMinfoTuya Zigbee mmWave Sensor unknown model null manufacturer null
dev:1332024-08-30 03:59:02.579 PMinfoTuya Zigbee mmWave Sensor Updated to version 3.2.4 2024/07/31 5:20 PM (TS0601 _TZE200_v1jqz5cy) (C-7 2.3.9.176)
dev:1332024-08-30 03:59:02.440 PMinfoTuya Zigbee mmWave Sensor sent device configuration
dev:1332024-08-30 03:59:02.420 PMinfoTuya Zigbee mmWave Sensor configureDevice...
dev:1332024-08-30 03:59:02.418 PMinfoTuya Zigbee mmWave Sensor initializeDevice...
dev:1332024-08-30 03:59:02.410 PMinfoTuya Zigbee mmWave Sensor tuyaBlackMagic()...
dev:1332024-08-30 03:59:02.407 PMinfoTuya Zigbee mmWave Sensor configure()... cfgCtr=1
dev:1332024-08-30 03:59:02.290 PMinfoTuya Zigbee mmWave Sensor installed
dev:1332024-08-30 03:59:02.282 PMinfoTuya Zigbee mmWave Sensor installed()... instCtr=1
I am planning to help develop the driver and proceed with the return.
I told the seller that I would send the data, test it for one or two more days, and return it.
Ok,
Let’s try whatever we can in the next 2 days
I am conducting the test again in Tuya.
The sensor is not very accurate, but it seems to be useful for looking at the flow.
Do you have other sensors to compare with?
No, I don't have any other sensors to compare with.
There are some changes in the same water.
I tested it with water from tap water and water tanks in Korea.
PH7 is tap water. PH6 is water in a tank with fish.
As a result of testing twice in a not-too-distant period, the water in the tank had a PH of over 7.
The order of testing is tap water, water in a tank, and tap water.
@jw970065 this is the first version of the custom driver :
After installing it and manually assigning it to your device, select 'LOAD ALL DEFAULTS' in the Configure drop-down menu and click the button.
I don't know whether all the attributes will be reported automatically. If not, click on the Refresh() button and let me know what happens.
This is the data from the previous TUYA.
Summary
dev:1342024-08-31 12:27:19.520 AMdebug수질점검 키트 7 clearing the Status event
dev:1342024-08-31 12:26:20.325 AMwarnBLE_YL01 Tuya Zigbee Chlorine Meter standardParseTuyaCluster: unprocessed Tuya cluster command 11 data=[66, 33, 4F]
dev:1342024-08-31 12:26:20.245 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter parse: descMap = [raw:catchall: 0104 EF00 01 01 0040 00 F834 01 00 0000 11 01 66334F, profileId:0104, clusterId:EF00, clusterInt:61184, sourceEndpoint:01, destinationEndpoint:01, options:0040, messageType:00, dni:F834, isClusterSpecific:true, isManufacturerSpecific:false, manufacturerId:0000, command:11, direction:01, data:[66, 33, 4F]] description=catchall: 0104 EF00 01 01 0040 00 F834 01 00 0000 11 01 66334F
dev:1342024-08-31 12:26:20.154 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter Tuya check-in (AppVersion=1F)
dev:1342024-08-31 12:26:20.146 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter parse: descMap = [raw:F8340100001801002041E2FF201FE4FF2000, dni:F834, endpoint:01, cluster:0000, size:18, attrId:0001, encoding:20, command:0A, value:41, clusterInt:0, attrInt:1, additionalAttrs:[[value:1F, encoding:20, attrId:FFE2, consumedBytes:4, attrInt:65506], [value:00, encoding:20, attrId:FFE4, consumedBytes:4, attrInt:65508]]] description=read attr - raw: F8340100001801002041E2FF201FE4FF2000, dni: F834, endpoint: 01, cluster: 0000, size: 18, attrId: 0001, encoding: 20, command: 0A, value: 41E2FF201FE4FF2000
dev:1342024-08-31 12:26:19.489 AMinfoBLE_YL01 Tuya Zigbee Chlorine Meter updated
dev:1342024-08-31 12:26:19.487 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter sendZigbeeCommands: sent cmd=[null]
dev:1342024-08-31 12:26:19.483 AMwarnBLE_YL01 Tuya Zigbee Chlorine Meter sendZigbeeCommands it: no commands to send! it=null (cmd=[null])
dev:1342024-08-31 12:26:19.481 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: preference freeChlorineMin is not set (preferenceValue was null)
dev:1342024-08-31 12:26:19.478 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: foundMap = [dp:113, name:freeChlorineMin, type:decimal, rw:rw, min:0, max:15, scale:10, unit:mg/L, title:Free Chlorine minimal value]
dev:1342024-08-31 12:26:19.474 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: preference freeChlorineMax is not set (preferenceValue was null)
dev:1342024-08-31 12:26:19.472 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: foundMap = [dp:112, name:freeChlorineMax, type:decimal, rw:rw, min:0, max:15, scale:10, unit:mg/L, title:Free Chlorine maximal value]
dev:1342024-08-31 12:26:19.468 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: preference orpMmin is not set (preferenceValue was null)
dev:1342024-08-31 12:26:19.463 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: foundMap = [dp:111, name:orpMmin, type:decimal, rw:rw, min:0, max:1000, scale:1, unit:mV, title:Oxidation Reduction Potential minimal value]
dev:1342024-08-31 12:26:19.460 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: preference orpMmax is not set (preferenceValue was null)
dev:1342024-08-31 12:26:19.457 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: foundMap = [dp:110, name:orpMmax, type:decimal, rw:rw, min:0, max:1000, scale:1, unit:mV, title:Oxidation Reduction Potential maximal value]
dev:1342024-08-31 12:26:19.454 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: preference ecMmin is not set (preferenceValue was null)
dev:1342024-08-31 12:26:19.451 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: foundMap = [dp:109, name:ecMmin, type:decimal, rw:rw, min:0, max:100, scale:1, unit:µS/cm, title:Electrical Conductivity minimal value]
dev:1342024-08-31 12:26:19.446 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: preference ecMmax is not set (preferenceValue was null)
dev:1342024-08-31 12:26:19.443 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: foundMap = [dp:108, name:ecMmax, type:decimal, rw:rw, min:0, max:100, scale:1, unit:µS/cm, title:Electrical Conductivity maximal value]
dev:1342024-08-31 12:26:19.435 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: preference phMmin is not set (preferenceValue was null)
dev:1342024-08-31 12:26:19.433 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: foundMap = [dp:107, name:phMmin, type:decimal, rw:rw, min:0, max:20, scale:10, unit:pH, title:pH minimal value]
dev:1342024-08-31 12:26:19.427 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: preference phMmax is not set (preferenceValue was null)
dev:1342024-08-31 12:26:19.424 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: foundMap = [dp:106, name:phMmax, type:decimal, rw:rw, min:0, max:20, scale:10, unit:pH, title:pH maximal value]
dev:1342024-08-31 12:26:19.406 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter updateAllPreferences: preferences=[phMmax:106, phMmin:107, ecMmax:108, ecMmin:109, orpMmax:110, orpMmin:111, freeChlorineMax:112, freeChlorineMin:113]
dev:1342024-08-31 12:26:19.402 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter current state.deviceProfile=CHLORINE_METER_BLE_YL01, settings.forcedProfile=BLE_YL01 Tuya Zigbee Chlorine Meter, getProfileKey()=CHLORINE_METER_BLE_YL01
dev:1342024-08-31 12:26:19.391 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter customUpdated()
dev:1342024-08-31 12:26:19.389 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter deviceHealthCheck is scheduled every 240 minutes
dev:1342024-08-31 12:26:19.338 AMinfoscheduling health check every 240 minutes by Activity check method
dev:1342024-08-31 12:26:19.278 AMinfoBLE_YL01 Tuya Zigbee Chlorine Meter driver version 3.3.1 2024/08/30 5:40 PM (TS0601 _TZE200_v1jqz5cy) (C-7 2.3.9.176)
dev:1342024-08-31 12:26:19.274 AMinfoBLE_YL01 Tuya Zigbee Chlorine Meter updated()...
dev:1342024-08-31 12:26:16.711 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter received device model TS0601
dev:1342024-08-31 12:26:16.709 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter Basic cluster: ZCLVersion = 03
dev:1342024-08-31 12:26:16.703 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter received device manufacturer _TZE200_v1jqz5cy
dev:1342024-08-31 12:26:16.682 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter parse: descMap = [raw:F83401000068040042105F545A453230305F76316A717A3563790000002003010000204105000042065453303630310700003003FEFF003000, dni:F834, endpoint:01, cluster:0000, size:68, attrId:0004, encoding:42, command:01, value:_TZE200_v1jqz5cy, clusterInt:0, attrInt:4, additionalAttrs:[[value:03, encoding:20, attrId:0000, consumedBytes:4, attrInt:0], [value:41, encoding:20, attrId:0001, consumedBytes:4, attrInt:1], [value:TS0601, encoding:42, attrId:0005, consumedBytes:9, attrInt:5]]] description=read attr - raw: F83401000068040042105F545A453230305F76316A717A3563790000002003010000204105000042065453303630310700003003FEFF003000, dni: F834, endpoint: 01, cluster: 0000, size: 68, attrId: 0004, encoding: 42, command: 01, value: 105F545A453230305F76316A717A3563790000002003010000204105000042065453303630310700003003FEFF003000
dev:1342024-08-31 12:26:16.650 AMinfoBLE_YL01 Tuya Zigbee Chlorine Meter is now online!
dev:1342024-08-31 12:26:16.648 AMinfoBLE_YL01 Tuya Zigbee Chlorine Meter healthStatus changed to online
dev:1342024-08-31 12:26:16.639 AMinfoBLE_YL01 Tuya Zigbee Chlorine Meter tuyaVersion set to 1.0.1
dev:1342024-08-31 12:26:16.635 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter customInitEvents()
dev:1342024-08-31 12:26:16.633 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter customInitializeVars(false)
dev:1342024-08-31 12:26:16.626 AMdebugBLE_YL01 Tuya Zigbee Chlorine Meter initEventsDeviceProfile(false) for deviceProfile=CHLORINE_METER_BLE_YL01 DEVICE?.device?.powerSource=dc ps.isEmpty()=false
dev:1342024-08-31 12:26:16.622 AMinfoBLE_YL01 Tuya Zigbee Chlorine Meter device model TS0601 manufacturer _TZE200_v1jqz5cy was set to : deviceProfile=CHLORINE_METER_BLE_YL01 : deviceName=BLE_YL01 Tuya Zigbee Chlorine Meter
dev:1342024-08-31 12:26:16.603 AMdebugTuya Zigbee Chlorine Meter found exact match for model TS0601 manufacturer _TZE200_v1jqz5cy : profileName=CHLORINE_METER_BLE_YL01 deviceName =BLE_YL01 Tuya Zigbee Chlorine Meter
dev:1342024-08-31 12:26:16.586 AMdebugTuya Zigbee Chlorine Meter deviceProfileInitializeVars(false)
dev:1342024-08-31 12:26:16.553 AMdebugTuya Zigbee Chlorine Meter InitializeVars()... fullInit = false
dev:1342024-08-31 12:26:16.514 AMinfoTuya Zigbee Chlorine Meter Updated to version 3.3.1 2024/08/30 5:40 PM (TS0601 _TZE200_v1jqz5cy) (C-7 2.3.9.176)
dev:1342024-08-31 12:26:16.511 AMdebugTuya Zigbee Chlorine Meter checkDriverVersion: updating the settings from the current driver version null to the new version 3.3.1 2024/08/30 5:40 PM (TS0601 _TZE200_v1jqz5cy) (C-7 2.3.9.176)
dev:1342024-08-31 12:26:16.381 AMinfoTuya Zigbee Chlorine Meter sent device configuration
dev:1342024-08-31 12:26:16.379 AMdebugTuya Zigbee Chlorine Meter configure(): sent cmds = [he raw 0xF834 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200]
dev:1342024-08-31 12:26:16.377 AMdebugTuya Zigbee Chlorine Meter sendZigbeeCommands: sent cmd=[he raw 0xF834 1 0x01 0x0000 {10 00 00 04 00 00 00 01 00 05 00 07 00 FE FF}, delay 200]
dev:1342024-08-31 12:26:16.364 AMdebugTuya Zigbee Chlorine Meter configureDevice(): cmds=
dev:1342024-08-31 12:26:16.362 AMinfoTuya Zigbee Chlorine Meter configureDevice...
dev:1342024-08-31 12:26:16.361 AMdebugTuya Zigbee Chlorine Meter initializeDevice(): cmds=
dev:1342024-08-31 12:26:16.359 AMinfoTuya Zigbee Chlorine Meter initializeDevice...
dev:1342024-08-31 12:26:16.358 AMdebugTuya Zigbee Chlorine Meter aqaraBlackMagic() was SKIPPED
dev:1342024-08-31 12:26:16.353 AMinfoTuya Zigbee Chlorine Meter tuyaBlackMagic()...
dev:1342024-08-31 12:26:16.345 AMdebugTuya Zigbee Chlorine Meter configure(): settings: [txtEnable:true, logEnable:true, forcedProfile:null, advancedOptions:false]
dev:1342024-08-31 12:26:16.343 AMinfoTuya Zigbee Chlorine Meter configure()... cfgCtr=1
dev:1342024-08-31 12:26:16.157 AMinfoTuya Zigbee Chlorine Meter installed
dev:1342024-08-31 12:26:16.147 AMinfoTuya Zigbee Chlorine Meter installed()... instCtr=1
Show more...
You can send me the Debug logs in a DM to me, this driver will not be as easy to be made as the previous one .. :slight_smile:
How can I view debug logs?
I mean, the standard logs that you usually send .. when the Preferences 'Debug' option is on.
This is the manual that the seller secured and sent me.
