It seems like I'm getting an occasional inaccurate report from the mobile app that is triggering away when we are well within the Home fence (of 5990 ft radius).
On mobile, the app has location permission with precise location. Mobile App Location Configuration has default settings (including do not send a location if the accuracy is greater than 492).
@dnickel this is the reason you are seeing a lot of "0 speed" locations. Android's locator engine dictates the source of the location. If it's from GPS, then it can supply a speed. Possibly also from cellular triangularization. The ones based on nearby wifi access points come with zero speed.
Those are auto-populated when your phone reports a location. Can you open the HE app and check the member status table at the top to see if their last report is current? And then check the HE logs when you trigger a location update from the mobile app by pushing the up arrow?
I took the startup of the application as, as soon as it opens this is not the case its when the app requests to use google maps so you have to go though all the setup process then the fingerprint appears.
Yup, that surprised me too, take it if I fresh install windows it will change tho?
If you clear notifications for a device and then hit save you get an error. The clearing of notification settings for the device(s) does appear to be retained, so the error is just a UI issue.
Below - notification settings have been cleared via Clear Settings button for this phone device.
Hitting Save when I cleared settings seemed reasonable since Save works when you enter notification settings. But obviously not required. Hitting Done to leave the page works normally.
I might have found an edge case issue that caused the hub to crash. I'm on a C5 running 2.3.8.125 & own tracks driver version 1.7.33
We had an extended Internet outage of approximately 8 hours today. Someone accidentally cut a major fiber optic cable.
About 3 hours into the outage my bride and I left for the day. The Internet was up when we got home about 5 hours later but the hub had crashed. Green light but nothing was working. I had to log into 8081 and reboot. When I looked at the logs the last things recorded were from my own tracks device.
Device 2838 is my own tracks device and 5 is the HE dashboard. The funny thing is my wife's phone didn't generate any errors and she was with me all day. I'm on Android and she uses the unholy iPhone.
It's set at 300. I suspected the "calls" had piled up. If that is what crashed the hub then any lengthy outage is going to be a problem. Not that they happen often but are unpredictable. Would the calls stop if the device is disabled? Maybe I could set something up in RM to disable the driver when cloud connection is lost
