You are among the minority of HE users who have problems keeping some Zigbee 3.0 devices connected to the C-8 Zigbee 3.0 hub.
Any recommendations to remedy this problem? My other Sylvania LED RGBW strips work as intended - yes, they are older Zigbee devices.
In a similar case, @bobbyD was able to help.
That button is for putting the sensor in pairing mode as far as I know. You don’t need to push it otherwise. The sensor is powered, so doesn’t need woken up.
Is it possible that you are holding the Linptech sensor button for too long, and it resets and goes into pairing mode (disconnecting from the hub )?
As said above, for mains/dc-powered devices there is no need to press the device button when you click on the 'Get Info' web page button.
The typical 'effect' of loosing the Zigbee connection with the 'Device' driver pre-assigned is that during the first seconds (30..60) after pairing the device will respond to the 'Get Info' command and you will see fingerprint logs every time you click on the button. Less than a minute later the device will stop responding.
The documentation with the sensor said press the button for 5 seconds to perform factory reset. That's what I did. I read through the link you shared - Zigbee pairing issues. I've changed the channel to 26 and also restarted the Zigbee radio. Let's see if that helps.
If not, @bobbyD ... is there anything else you can recommend?
26 is normally not a good Zigbee channel, you should usually be on 20 or 25 when you're at the upper end of the Zigbee channels (where most of us end up).
Channel 26 is transmission power limited in North America (and possibly elsewhere), and not supported by all devices
I chose 26 and I'm not going to change it again; but I understand 26 can be reduced power in some regions. @bobbyD suggested 23/24 being better. reasons why I won't be changing resulted in me having to 're pair' a dozen battery temperature sensors that didn't make the switch to a new channel. everything is stable again now.
Falls under the "if it ain't broke" clause.
But I wouldn't generally recommend 26, at least for folks in the US.
mine was a pairing fault that wasn't resolved till I changed channels; even if I choice of channel was dubious. being in Europe I'm not aware I was affected by the choice.
Next time try to just take the batteries out for a min, might save you time and effort having to repair sensors. I also don't recommend channel 26 in the US. Like you said, 23, 24, 25 have been better choices for many folks, including my own experience.
Must be... you are still here...
Got the replacement sensor from Amazon. That is reporting the motion accurately.
I did change the channel to 23 & have left it there.
@kkossev & @bobbyD ... the sensor is working as expected & it also shows up on the Zigbee device graph. Looks like I had received a broken sensor originally! Thanks for helping me troubleshoot it.
One additional Q - when I tried building a rule, this doesn't show up under presence sensors for me to use it as a trigger. It shows up only under motion sensors.
I've removed @kkossev 's driver before adding the replacement sensor and am using the default/built-in driver. Should I download and re-install @kkossev 's driver for it to show up as a presence sensor?
Just like any other mmWave sensor (or PIR sensor), it's only ever going to show motion.
Perhaps this will change sometime in the future, but for now, "Presence" is used for geofence-based away/home related stuff, e.g. your cell phone is a presence sensor.
Glad you got the unit replaced.
That, as Hydro noted, is how they are integrated into the hub, as motion sensors. Presence (as I think about it) tends to be person-specific, e.g., "Tom is home" and these sensors don't have that capability to ID specific people. Their Static Sensitivity capablity does allow them to monitor/confirm presence of someone w/out motion, but no ID of that person, so makes sense (to me, anyway) that overall they are identified as motion sensors.
I would recommend using the driver that is purpose-built for this device, links to it at the top of this topic, but best to install it from HPM. It will still show up as a motion sensor in your rules, and they solved my issues by being able to accurately report my wife's presence in the office when she sits not moving for many minutes. So my automations don't turn off the lights while she/anyone else is sitting in there sitting still.
Thanks. I'll play around with it to see if the default drivers will do the trick. My use case is similar - my wife sitting with a blanket covered and watching TV... so a motion sensor is useless. If the default drivers let it pickup the static sensitivity, I'll leave it the way it is and build rules around it. If not, I will download Krassimir's driver via HPM
They do. Motion doesn’t become inactive until static is inactive. I switched to the built in drivers for my 3 Linptech sensors and they have the same functionality.
My apologies if this sounds really stupid and for hijacking a post on a nother thread but what is Hubitat Package Manager and why do I need it? Also where in Hubitat can I see a map of my zigbee network?
Yeah, we don't want to re-route this topic to your questions as they are off-topic w/this thread.
Please ask HPM questions here:
And ask your questions about Zigbee maps here:
Read the first few posts in each topic and ask questions there.
If you need more help in general ask in the Get Help topic:
Thank you.
