I was not using Life360 with States previously because of the frequent refresh interval so I'm jumping on board with your version now.
I've installed in HPM, signed in and new devices were installed. I've exposed them in Maker instance. The devices appear on my dashboard but as generic sensors. I don't see Life360 as a device type to change them to. Did I miss something?
HPM takes a few to pick up new packages using the search. Using the "tags" option forces HPM to go pull the app lists from GitHub where the search relies on some caching that it does periodically (something like every 15 minutes if I recall correctly).
Okay. Found it and installed it.
I am currently home, and the device indicates that I am Present.
However, the icon on HD+ still indicates that I am not present.
Not sure how to troubleshoot this.
Also, how do I get the map icon for the Dashboard?
I had to update HD+ to detect the new Life360+ app. I submitted the update yesterday and Google is usually pretty fast to push them but in this case they've still reviewing it.. probably because I have some Android Auto changes in it which they want to be extra careful.
I replaced the Life360 w/states with the new driver but I don't get any states and the Refresh has a log entry: dev:20722023-05-10 10:12:16.407errorjava.lang.NullPointerException: Cannot invoke method refresh() on null object on line 153 (method updated)
I get this if I enter my credentials again: app:15662023-05-10 10:19:56.201errorLife360 initializeLife360Connection, error: groovyx.net.http.HttpResponseException: status code: 403, reason phrase: Forbidden
I changed my password and still the same thing.
Hi @jpage4500 ,
Found the app in HPM and installed - worked fine.
The app created 5 devices, one for each Life360 member - OK
The log in getting an update every 30 seconds even when the data is not changed (enable logging is ON- is this expected?
hmm.. good question. I didn't do much to the 'app' driver but it's possible I removed something that broke it. I did re-install the app yesterday and it worked FWIW.
I do see 1 area in the app code that might be an issue so I just changed it.. I think it had to do with using an existing device instead of letting the app create the child devices for you.
I removed and reinstalled app/driver package and same thing. Must be a me thing with the process.
You mention child but I see none. App created no child devices. App info also says - No Child Devices
Install the app via HPM.
Run the app and put in my name and password - hit Next
I get a blank screen with Remove or Done - I hit Done
I looked in the Devices page to see if a device under my User Name was created; didn't see anything so I created a new Virtual Device and used your driver.
The new device shows what I expect but no state data.
What part the of process an I doing consistently wrong?
I get the same error in the logs: dev:20732023-05-10 15:25:24.276errorjava.lang.NullPointerException: Cannot invoke method refresh() on null object on line 153 (method updated) app:15672023-05-10 15:33:55.462errorLife360 initializeLife360Connection, error: groovyx.net.http.HttpResponseException: status code: 403, reason phrase: Forbidden
The only thing I can think of is maybe OAUTH isn't enabled for this app. I'm not sure how that works with HPM -- I was hoping it was automatic though. In the past, you had to enable it under Apps section. I didn't do anything but it's "enabled" in this screenshot
Did it again but I don't get the 3 following screens, no Circle, Home or User.
Just the empty screen with Done after my name and password.
Does it do some sort of validation after the first screen? I can log into Life360 just fine.
Hmmmm
Just tried to go back to Life360 with States and I can't get that app to work now, same empty screens after the inital login. WTF.
Been using it for years.
I get Login failed from the built-in Life360 Connector so I dunno. Will have to delete my account and retry that way. Strange it works fine on my cell phone.
Nope, recreating my account won't let me add the app either.
Going to restore my last backup and see if my old Life360 comes back.
PS Tried Enabling Oauth in the App code but that didn;t help. BPTWorld ver didn't have it enabled
I have a Home location set which is where it says I am now.
I tried to restore 2 backups and both kept the CPU at 90%+
I had to soft reset and restore a backup to get back to normal.
After the soft reset my previous Life360 with States now crashes. I deleted the app and tried the built-in Connector and Life360+; everything fails to login to Life360 now.
I'll check the Community for any hints.
OMG!!!!
It's not my frigin registered name it's my phone number with +1
Now it wants a Place but I have to figure out where that is as there is nothing in the dropdown box.
I have a Place in the Android app called Home. I tried the Export Places button but it says No Places.
Created a Place called Work but still no entries.
@jpage4500 I see you had this same problem. Tried Life360 with States and my email but still no Places. You mention I needed to login to the website but I can't see anywhere to add or modfiy the account.
Did I get it right. If I install this driver it won't affect life360 drivers that I'm at the moment using. So it creates just another life360 devices to play with and test how it works?
Hi @jpage4500 ,
I am using this app with the built in dashboard app.
I see the device page contain a state variable for Presence:
When displaying this device on the dashboard I can display all attributes but the Presence state variable is not available for display. Can the state variable be an attribute as well?
Or am I missing another option to display its value on the dashboard?
