So it seems there are multiple threads pertaining to my issue but as one of these apps is a Built-In I thought it was ok to tap the staff for a comment. @bobbyD
Is this an issue with Life360 and therefore unsolvable?
Places drop-down is empty during a re-install of Life360+, Life360 with States and the Life360 Connector (HE). I have tried all the suggestions.
I'm new to Hubitat and experimenting with presence detection. After reading up on the forum I installed Life360 on my phone (Galaxy S9+, Android 10) and followed the steps on the Life360 Connector wiki page.
I have succesfully added my credentials and can choose the correct 'Circle'. However, the dropdown for 'Place' stays empty, although in the app on my phone I've setup 'Home' and 'Work'.
Am I overlooking something?
Are you on the paid or free version of Life360? The free version does not support places other than Home and you’d need to add them in manually into Life360 w/states. The paid version should populate your dropdown if you were authenticated.
I have a Home location set which is where it says I am now.
I tried to restore 2 backups and both kept the CPU at 90%+
I had to soft reset and restore a backup to get back to normal.
After the soft reset my previous Life360 with States now crashes. I deleted the app and tried the built-in Connector and Life360+; everything fails to login to Life360 now.
I'll check the Community for any hints.
OMG!!!!
It's not my frigin registered name it's my phone number with +1
Now it wants a Place bu…
Addendum
Oddly I log in to Life360 fine but I get some nasty logs:
app:1583 2023-05-10 20:45:42.444warn Unable to get token for life360 authorization.
app:1583 2023-05-10 20:45:42.440error getToken Error:[errorMessage:Invalid login and password. Please try again, status:403, url:/v3/oauth2/token.json]
app:1583 2023-05-10 20:45:41.092error setWebhook Error:[errorMessage:Unauthorized, status:401, url:/v3/circles/null/webhook.json]
app:1583 2023-05-10 20:45:40.651error clearWebhook Error:[errorMessage:Unauthorized, status:401, url:/v3/circles/null/webhook.json]
app:1583 2023-05-10 20:45:40.166info initialize
dev:2076 2023-05-10 20:45:40.159warn installed...
app:1583 2023-05-10 20:45:40.120info Installing refresh button
system
Closed
May 10, 2024, 3:49am
3
