Hello Eric -
I noticed that my Inovelli Red Dimmer Switch is reporting non-zero power when all devices are off. This particular switch is in smart bulb mode and controls a circuit with Hue bulbs and a shelly dimmer controlling track lights.
I've bound the Inovelli to the track lights via hubitat apps and leave the hue bulbs to be controlled via hue integration.
When I turn on or dim either the hue bulbs or the track lights, I do see expected changes in power reported by the switch. But when everything is off (checked by multiple methods) the switch still reports between 8 and 13 W of power use. I can't think of anything that would continue drawing that much power with bulbs off.
You can put in some incandescent bulbs and turn the load to 100% Then put in the combined wattage of the bulbs and the voltage and then hit calibratePower.
You can use other bulbs and turn them up to 100% and add their wattage up as well, but higher wattage will likely result in a more accurate calibration.
Hi there - so I'm having a problem with a LZW31 Black series, Gen 1, running firmware 1.52. I have smartbulb mode enabled, but it seems to still turn off power to the bulb when turned off locally from the switch paddle. In hubitat, I have a button controller set up to turn off the bulbs via a Group (the bulbs are LIFX). However, when the switch is turned off the bulbs become unavailable to the app, suggesting it's actually turned off power.
Looking at the release notes for firmware 1.52 there seems to be a way to turn off the load by sending a basic set but that would be via z-wave. Can you try to update the firmware? There were changes made to smart bulb mode after 1.52.
Unfortunately I had to downgrade to 1.52 because Inovelli removed scene functionality in later firmware. (You explained this farther back in this thread - around January).
Hi - so I changed the code in the driver as above and power cycled the switch. (Pulled out the air gap, waited 30 sec, pushed back in). So far, seems to still be cutting off power. Do I need to do an exclude/include or factory reset or something?
Is there any indication of what is turning it off? Firmware 1.52 was supposed to have SBM except if a basicset on or basicset off is sent. In the driver we have basically disabled the ability to send those commands. I am curious what else would be turning it off. Can you check the logs to see what might be making it happen?
Edit: I can't remember how SBM worked on the gen 2, but do you possibly need to disable local control? I just read back that it is turning off locally for you.
I believe you had said a while back that I should not disable local control because then the paddle wouldn't work at all. I was never clear if disabling local control meant local control of the relay or local control of anything.
I am wondering now if in 1.52 SBM had fewer options. I think in 1.52 there was only an option to have SBM turned on or turned off. Can you try to change the SBM to "On/Off Only"? I think that version only supported that mode.
Hi,
I would like to know for inovelli plug driver (NZW37) I just switch from the built in driver to yours (hubitat hub) and I see that inside the driver you have multiple capability, including 'health check' and I would like to know if it supposed to give the current health staus (online-offline) of the device? I only see last activity and switch. I would like to use the status as trigger so just asking!
Also, is my child devices automatically update to your driver or it change nothing? I still see the generic switch component in teir setting?
Health check was carried over from SmartThings I believe. It doesn't work with this driver. The second question some child devices will not be compatible if you switch between drivers. You might have to delete them and then save preferences of the parent to recreate the proper ones.
I have a house full of NZW30 and NZW31 with and without scene (most with). They have been installed for years and for the most part work very well. some needing an occasional reboot.
I came looking for a way to disable debug logging because I notice its not an option in the drivers (using @ericm 's drivers not hubitat) . Weird thing is some switches dont send debug logs but some do, no idea why. I dont use child devices but I do use scene control button taps. Should I switch to the built in drivers? Do they have the debug toggle?
Also what was the last firmware update for these switches?
