I now have it all working. I removed all drivers and client, power cycled the hub, re-imported all code, power cycled unit again, input ID and secret, then connected, and now all seems to be working including the dashboard. Thanks for all the help and direction @srwhite and @Otto_Mation.
So now this is working very well with my main HE. I am also using HUBCONNECT and don't see all the weather attributes across the link. I've selected the netatmo devices in Hubinstance Client under Select Omnipurpose Sensors and they do appear to the Hubconnect Server end but only a subset of weather attributes. On the server they are using the HubConnect Omnipurpose Sensor.I had expected to see them all. What's supposed to be available across a HubConnect link?
Built in support is coming for these devices with HubConnect 2.0 which is currently in testing with the beta group. If you can hang in there for another week it should be available for release.
FWIW I've experienced the exact same behavior and error messages as @JDogg016. And I copied the device files from the same as he mentioned above. Is that correct?
EDIT: Here are my logs if it helps....
app:2302020-02-01 06:29:46.943 pm errorgroovy.lang.MissingMethodException: No signature of method: java.lang.String.call() is applicable for argument types: (java.util.HashMap) values: [[prefGroup:hcnetatmowx, title:Weather Stations & Devices]] Possible solutions: wait(), any(), wait(long), take(int), each(groovy.lang.Closure), any(groovy.lang.Closure) (mainPage)
app:2302020-02-01 06:29:23.617 pm infoNo devices are selected, skipping station refresh
That certainly looks like a bug in the hub UI. Nothing in the code calls mainPage with parameters yet that’s exactly what the logs show. The hub UI is trying to call a page with non-existent parameters.
Unfortunately I’m also unable to reproduce this issue at all so I don’t have any good advice to give. I tagged Bruce earlier but he hasn’t jumped in. I hope he can have some other suggestions.
Is your theory that clicking on href calls main()? I don't have a clue. This doesn't sound like a UI problem, but some obscure issue with the code. Corrupted db? Is this reproducible on any other hub?
I'm scratching my head as well. I have noticed some oddness with the UI/dynamic pages before an app in installed, specifically the first dynamic page called from the home page, before an app is installed seems to get "stuck"
For example.. mainPage -> connectPage, (user clicks Next) -> mainPage (user clicks any href) -> connectPage is called, regardless of the page in the href definition.
As far as this issue, I cannot reproduce it either. So far it's just JDogg I believe.
I can set you up with a Netatmo ID/Secret if you care to test.
