OK thanks.
Have just installed this on my C-4 and enabled temp, cpu, free memory but nothing is populating. This is from the eror logs:
Try hitting Configure.
Sorry, should have mentioned i have numerous times..
Has been since installed yesterday. Let it run, still nothing
Can try removing and re-installing?
Do you see a scheduled job for poll
I didnt...Then i saw an option for Hub Security so i enabled that and can now see values for the 3 items.
I assume this is now correct in the scheduled section?
I still have these errors in the logs!
Those errors are the ones you had ~14 hours ago, they’ll eventually fall off the logs. You should be good now, but I’m going to poke around and see if I can find a way to generate a message if you have hub security turned on but haven’t given the driver the credentials it needs.
Yes sorry - didnt even read the dates - my apologies!!
No worries, glad i figured it out.
A notice would be good as i forgot i even had hub security enabled
Cheers
v2.7.2 includes a new attribute (securityInUse) and will log an error if Hub Security is enabled but credentials haven’t been supplied for the driver.
Just updated and now getting Java warnings.
dev:20982022-09-18 12:43:21.257 pmwarnjava.lang.NullPointerException: Cannot get property 'baseModel' on null object
dev:20982022-09-18 12:38:20.968 pmwarnjava.lang.NullPointerException: Cannot get property 'baseModel' on null object
dev:20982022-09-17 04:35:34.554 pmtraceHub Information Driver 2.7.1 initialized
Ignore the version, that was yesterday. I just confirmed that pushing the "Configure" button will reliably give you this warning:
dev:20982022-09-18 12:57:52.563 pmwarnjava.lang.NullPointerException: Cannot get property 'baseModel' on null object
Strange… I’ll take a look, have never seen that come back null. What hub model and version of HE firmware are you running?
Hi Jean, I’m seeing the same thing on both of my C-5’s running 2.3.3.117 which is the latest beta version.
With or without security?
2.3.3.117
Rev C-7
Wasn't thinking that it could be related to the Beta.
No security. We don't need no stinkin' security.
Do you see an attribute for securityInUse?
Yes: * securityInUse : false
Note: will be offline a while now in case you need more info. Sorry about that.
Without security
No worries, but the fact that you got the attribute says it eventually went through. Wonder if I have a timing issue.
Edit: Pushed up 2.7.3 to handle the null return better. Still gives a warning, but handles it in the code instead of the JVM.
