[RELEASE] Hub Information Driver
I'm getting this in the logs (C-5 Hub) with the latest version (security on): [Interestingly - no issues on the C-7 Hub]...
dev:13942022-09-18 07:16:04.547 pm warngroovy.json.JsonException: Unable to determine the current character, it is not a string, number, array, or object
The current character read is '<' with an int value of 60
line number 1
index number 0
dev:13942022-09-18 07:06:03.795 pm warngroovy.json.JsonException: Unable to determine the current character, it is not a string, number, array, or object
line number 1
index number 0
dev:13942022-09-18 06:56:03.170 pm warngroovy.json.JsonException: Unable to determine the current character, it is not a string, number, array, or object
line number 1
index number 0
dev:13942022-09-18 06:46:02.413 pm warngroovy.json.JsonException: Unable to determine the current character, it is not a string, number, array, or object
line number 1
index number 0
Also seeing this on a C7
Yes. Same error here, every five minutes:
[dev:99](https://hubitat.local/logs?device=99#pastdev99)2022-09-18 21:40:27.920 [warn] groovy.json.JsonException: Unable to determine the current character, it is not a string, number, array, or object
line number 1
index number 0
Hubitat C-7 / 2.3.2.141
Hub Info Version 2.7.2
That one is due to a timing issue (driver making a call before the hub is ready). v2.7.4 (out now) should eliminate that error message.
It does now for the C7, not available for models prior.
No worries, I had to stop and think about it too.
Here's the latest from 2.7.4 on a C7 w/2.3.3.117 (beta) Thanks again for your work on this and your many other contributions to the Hubitat community.
dev:20982022-09-19 05:42:14.147 amerrorgroovy.lang.MissingMethodException: No signature of method: java.lang.NullPointerException.indexOf() is applicable for argument types: (java.lang.String) values: [Unable to determine the current character,] Possible solutions: inject(groovy.lang.Closure), findIndexOf(groovy.lang.Closure) on line 931 (method getHub2)
More readable?
Same here on all my hubs.
New errors with 2.7.4:
[dev:99] 2022-09-19 06:42:40.575 [error] groovy.lang.MissingMethodException: No signature of method: groovy.json.JsonException.indexOf() is applicable for argument types: (java.lang.String) values: [Unable to determine the current character,]
I definitely shouldn't try to put in a small patch while half asleep, missed that big time... Sorry about that, v2.7.5 now out
Hi @thebearmay,
I'm on latest version but still getting the same message (C7 -> 2.3.2.141; securityInUse : false):
dev:14732022-09-19 14:29:11.901 warnjava.lang.NullPointerException: Cannot get property 'baseModel' on null object
dev:14732022-09-19 14:29:11.808 traceHub Information Driver 2.7.5 initialized
dev:14732022-09-19 14:28:56.623 warnjava.lang.NullPointerException: Cannot get property 'baseModel' on null object
Frustrating as I can't duplicate... back to poking and guessing...
Edit: v.2.7.6 should squash this once and for all...
Still the same:
dev:14732022-09-19 17:35:10.792 warnjava.lang.NullPointerException: Cannot get property 'baseModel' on null object
dev:14732022-09-19 17:35:10.689 traceHub Information Driver 2.7.6 initialized
dev:14732022-09-19 17:35:08.884 warnjava.lang.NullPointerException: Cannot get property 'baseModel' on null object
Argh.... That feeling when you smash a bug only to find out that you exposed one that has been setting dormant. Let's try this again v2.7.7
Hey @thebearmay thanks for your persistence in chasing this down and particularly for your responsiveness and immediate fixes!
Error message is gone after the 2.7.7. update.
Thank you very much.
Agreed. Hub Information v2.7.7 is a winner. No errors now. Thanks!
I updated my HE to 2.3.3.121, then to 2.3.3.122, and somewhere along the way my HID preferences got reset to defaults and the default hubInfoTemplate.res file content got replaced with a single word null (which made my html output also null). My custom .res file was still there and still correct, so I re-entered my own file name as well as my other preferences and now things are back to normal. I didn't expect that an HE update would reset HID.
That is odd, and sounds like some minor database corruption. Resetting your preferences should have corrected that from the driver’s perspective.
@thebearmay looks like 2.3.3.123 has broken Hub Info's html tile on one of my C7's (but not the other). Is there an easy way to fix this?
Screen Shot 2022-09-28 at 9.44.08 am
