v2.7.0 is out. Some minor code cleanup, but the major change is that the html attribute is always done using a template file stored on the hub. By default this will be hubInfoTemplate.res, but you have the option of using another file (or modifying the default one). If you turn on the Enable HTML attribute preference and the template file information is empty or the template doesn't exist on the hub, the driver will download the default template to the hub.
The default template uses HTML table elements to format the output, but, keeping in mind that you are limited to 1024 characters, you may use whatever HTML you wish. Attributes are inserted by delimiting them with <% %> , i.e. <%cpuPct%>. In addition to the 51 driver attributes, <%@date%> and <%@version%> are also available (current date and current driver version respectively).
A small app to help you generate templates is also at
