<@version%>
did not work, but <%@version%>
did
Having the name of the template file currently in use published as an attribute would be handy so that it would be listed under "Current States".
<@version%>
did
Thanks for catching my typo. Template filename is in the preferences section of the driver, are you wanting to have it available for use in a rule or something else?
Anything I can set in a device I want to be able to read back from the device.
I don't have an immediate need to read any of the preferences (e.g. the template file name),
but I'm less likely to develop that need if I can't read them. If the device publishes its
full internal state, I might find a way to use it.
Let me think on that one a bit. The data is certainly there and available internal to the driver so the question is, is there already a construct that makes that data available externally.
Thank you for your kind consideration of this idea. Indeed, a general mechanism to know the internal state of the driver would be ideal. I should be able to know the internal state in sufficient detail that I could detect a change in any of the preferences.
When people ask "Why do you want that - nobody wants that." I think of this quote: "Most people, if they counted how many people swam across the river, would never think about building bridges." - Ronald Altman
