Sure. My code base is 0.1.29. Please see below:
Summary
- Home Assistant to Hubitat Integration
- Description:
- Allow control of HA devices.
- Required Information:
- Home Asisstant IP and Port number
- Home Assistant long term Access Token
- Features List:
- Licensing:
- Copyright 2021 Yves Mercier.
- Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
- in compliance with the License. You may obtain a copy of the License at: http://www.apache.org/licenses/LICENSE-2.0
- Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
- on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
- for the specific language governing permissions and limitations under the License.
- Version Control:
- 0.1.0 2021-02-05 Yves Mercier Orinal version
- 0.1.1 2021-02-06 Dan Ogorchock Added basic support for simple "Light" devices from Home Assistant using Hubitat Generic Component Dimmer driver
- 0.1.2 2021-02-06 tomw Added handling for some binary_sensor subtypes based on device_class
- 0.1.3 2021-02-06 Dan Ogorchock Bug Fixes
- 0.1.4 2021-02-06 Yves Mercier Added version number and import URL
- 0.1.5 2021-02-06 Dan Ogorchock Added support for Temperature and Humidity Sensors
- 0.1.6 2021-02-06 Dan Ogorchock Corrected open/closed for HA door events
- 0.1.7 2021-02-07 Dan Ogorchock Corrected open/closed for HA window, garage_door, and opening per @smarthomeprimer
- 0.1.8 2021-02-07 Dan Ogorchock Removed temperature and humidity workaround for missing device_class on some HA sensors.
This can be corrected on the HA side via the Customize entity feature to add the missing device_class.
- 0.1.9 2021-02-07 tomw More generic handling for "sensor" device_classes. Added voltage device_class to "sensor".
- 0.1.10 2021-02-07 Dan Ogorchock Refactored the translation from HA to HE to simplify the overall design
- 0.1.11 2021-02-07 Dan Ogorchock Completed refactoring of Dimmer Switch support
- 0.1.12 2021-02-08 Dan Ogorchock Fixed typo in log.info statement
- 0.1.13 2021-02-08 tomw Added "community" namespace support for component drivers. Added Pressure and Illuminance.
- 0.1.14 2021-02-10 Dan Ogorchock Added support for Fan devices (used Lutron Fan Controller as test device.)
- 0.1.15 2021-02-13 tomw Adjust websocket status handling to reconnect on both close and error conditions.
- 0.1.16 2021-02-14 tomw Revert 0.1.15
- 0.1.17 2021-02-14 Dan Ogorchock Improved webSocket reconnect logic
- 0.1.18 2021-02-14 tomw Avoid reconnect loop on initialize
- 0.1.19 2021-02-16 Yves Mercier Added Refresh handler
- 0.1.20 2021-02-16 Yves mercier Refactored webSocketStatus
- 0.1.21 2021-02-22 Yves mercier Reinstated CloseConnection command. Added connection status on device page.
- 0.1.22 2021-02-24 tomw Changes to support optional device filtering. For use with haDeviceBridgeConfiguration.groovy.
- 0.1.23 2021-02-25 Dan Ogorchock Switched from Exclude List to Include List
- 0.1.24 2021-03-07 Yves Mercier Added device label in event description
- 0.1.25 2021-03-18 Dan Ogorchock Updated for recent Hass Fan handling changes (use percentages to set speeds instead of deprecated speed names)
- 0.1.26 2021-04-02 DongHwan Suh Added partial support for Color temperature, RGB, RGBW lights
(Manually updating the device type to the corresponding one is required in Hubitat. Only statuses of level and switch are shown in Hubitat.)
- 0.1.27 2021-04-11 Yves Mercier Added option for secure connection
- 0.1.28 2021-04-14 Dan Ogorchock Improved Fan Device handling
- 0.1.29 2021-04-17 Dan Ogorchock Added support for Smoke Detector Binary Sensor
- Thank you(s):
import groovy.json.JsonSlurper
import groovy.json.JsonOutput
metadata {
definition (name: "HomeAssistant Hub Parent", namespace: "ymerj", author: "Yves Mercier", importUrl: "https://raw.githubusercontent.com/ymerj/HE-HA-control/main/HA%20parent.groovy") {
capability "Initialize"
// command "createChild", [[ name: "entity", type: "STRING", description: "HomeAssistant Entity ID" ]]
// command "removeChild", [[ name: "entity", type: "STRING", description: "HomeAssistant Entity ID" ]]
command "closeConnection"
// command "deleteAllChildDevices"
attribute "Connection", "string"
preferences {
input ("ip", "text", title: "IP", description: "HomeAssistant IP Address", required: true)
input ("port", "text", title: "Port", description: "HomeAssistant Port Number", required: true, defaultValue: "8123")
input ("token", "text", title: "Token", description: "HomeAssistant Long-Lived Access Token", required: true)
input ("secure", "bool", title: "Require secure connection (https)", defaultValue: false)
input ("logEnable", "bool", title: "Enable debug logging", defaultValue: true)
input ("txtEnable", "bool", title: "Enable description text logging", defaultValue: true)
def logsOff(){
log.warn("debug logging disabled...")
device.updateSetting("logEnable",[value:"false",type:"bool"])
def updated(){
log.info("updated...")
log.warn("debug logging is: ${logEnable == true}")
log.warn("description logging is: ${txtEnable == true}")
unschedule()
if (logEnable) runIn(1800,logsOff)
initialize()
def initialize() {
log.info("initializing...")
closeConnection()
state.id = 2
def connectionType = "ws"
if (secure) connectionType = "wss"
auth = '{"type":"auth","access_token":"' + "${token}" + '"}'
evenements = '{"id":1,"type":"subscribe_events","event_type":"state_changed"}'
try {
interfaces.webSocket.connect("${connectionType}://${ip}:${port}/api/websocket", ignoreSSLIssues: true)
interfaces.webSocket.sendMessage("${auth}")
interfaces.webSocket.sendMessage("${evenements}")
catch(e) {
log.error("initialize error: ${e.message}")
def uninstalled() {
log.info("uninstalled...")
closeConnection()
unschedule()
deleteAllChildDevices()
def webSocketStatus(String status){
if (logEnable) log.debug "webSocket ${status}"
if ((status == "status: closing") && (state.wasExpectedClose)) {
state.wasExpectedClose = false
sendEvent(name: "Connection", value: "Closed")
return
else if(status == 'status: open') {
log.info "websocket is open"
// success! reset reconnect delay
pauseExecution(1000)
state.reconnectDelay = 1
sendEvent(name: "Connection", value: "Open")
else {
log.warn "WebSocket error, reconnecting."
sendEvent(name: "Connection", value: "Reconnecting")
reconnectWebSocket()
def reconnectWebSocket() {
// first delay is 2 seconds, doubles every time
state.reconnectDelay = (state.reconnectDelay ?: 1) * 2
// don't let delay get too crazy, max it out at 10 minutes
if(state.reconnectDelay > 600) state.reconnectDelay = 600
//If the Home Assistant Hub is offline, give it some time before trying to reconnect
runIn(state.reconnectDelay, initialize)
if (logEnable) log.debug("parse(): description = ${description}")
def response = null;
try{
response = new groovy.json.JsonSlurper().parseText(description)
if (response.type != "event") return
def newVals = []
def entity = response?.event?.data?.entity_id
// check whether we have a parent, and search its includeList for devices to process
def includeList = getParent()?.includeList
if(includeList && !includeList?.contains(entity)) return
def domain = entity?.tokenize(".")?.getAt(0)
def device_class = response?.event?.data?.new_state?.attributes?.device_class
def friendly = response?.event?.data?.new_state?.attributes?.friendly_name
newVals << response?.event?.data?.new_state?.state
def mapping = null
if (logEnable) log.debug "parse: domain: ${domain}, device_class: ${device_class}, entity: ${entity}, newVals: ${newVals}, friendly: ${friendly}"
switch (domain) {
case "fan":
def speed = response?.event?.data?.new_state?.attributes?.speed
def percentage = response?.event?.data?.new_state?.attributes?.percentage
switch (percentage.toInteger()) {
case 0:
speed = "off"
break
case 25:
speed = "low"
break
case 50:
speed = "medium"
break
case 75:
speed = "medium-high"
break
case 100:
speed = "high"
default:
if (logEnable) log.info "Invalid fan percentage received - ${percentage}"
newVals += speed
newVals += percentage
mapping = translateDevices(domain, newVals, friendly)
if (mapping) updateChildDevice(mapping, entity, friendly)
break
case "switch":
break
case "light":
def level = response?.event?.data?.new_state?.attributes?.brightness
if (level) level = Math.round((level.toInteger() * 100 / 255))
newVals += level
if (!level) mapping.event.remove(1) //remove the level update since it is not provided with the HA 'off' event json data
break
case "binary_sensor":
case "sensor":
mapping = translateDevices(device_class, newVals, friendly)
break
case "climate":
def current_temperature = response?.event?.data?.new_state?.attributes?.current_temperature
def target_temperature = response?.event?.data?.new_state?.attributes?.temperature
def fan_mode = response?.event?.data?.new_state?.attributes?.fan_mode
def preset_mode = response?.event?.data?.new_state?.attributes?.preset_mode
def swing_mode = response?.event?.data?.new_state?.attributes?.swing_mode
newVals += current_temperature
newVals += target_temperature
newVals += fan_mode
newVals += preset_mode
newVals += swing_mode
break
default:
if (logEnable) log.info "No mapping exists for domain: ${domain}, device_class: ${device_class}. Please contact devs to have this added."
return
catch(e) {
log.error("Parsing error: ${e}")
return
def translateDevices(device_class, newVals, friendly)
def mapping =
door: [type: "Generic Component Contact Sensor", event: [[name: "contact", value: newVals[0] == "on" ? "open":"closed", descriptionText:"${friendly} is updated"]]],
fan: [type: "Generic Component Fan Control", event: [[name: "switch", value: newVals[0], descriptionText:"${friendly} was turn ${newVals[0]}"],[name: "speed", value: newVals[1], descriptionText:"${friendly} speed was set to ${newVals[1]}"],[name: "level", value: newVals[2], descriptionText:"${friendly} level was set to ${newVals[2]}"]]],
garage_door: [type: "Generic Component Contact Sensor", event: [[name: "contact", value: newVals[0] == "on" ? "open":"closed", descriptionText:"${friendly} is updated"]]],
humidity: [type: "Generic Component Humidity Sensor", event: [[name: "humidity", value: newVals[0], descriptionText:"${friendly} humidity is ${newVals[0]}"]]],
illuminance: [type: "Generic Component Illuminance Sensor", event: [[name: "illuminance", value: newVals[0], descriptionText:"${friendly} illuminance is ${newVals[0]}"]], namespace: "community"],
light: [type: "Generic Component Dimmer", event: [[name: "switch", value: newVals[0], descriptionText:"${friendly} was turn ${newVals[0]}"],[name: "level", value: newVals[1], descriptionText:"${friendly} level was set to ${newVals[1]}"]]],
moisture: [type: "Generic Component Water Sensor", event: [[name: "water", value: newVals[0] == "on" ? "wet":"dry", descriptionText:"${friendly} is updated"]]],
motion: [type: "Generic Component Motion Sensor", event: [[name: "motion", value: newVals[0] == "on" ? """active""":"""inactive""", descriptionText:"${friendly} is updated"]]],
opening: [type: "Generic Component Contact Sensor", event: [[name: "contact", value: newVals[0] == "on" ? "open":"closed", descriptionText:"${friendly} is updated"]]],
presence: [type: "Generic Component Presence Sensor", event: [[name: "presence", value: newVals[0] == "on" ? "present":"not present", descriptionText:"${friendly} is updated"]]],
pressure: [type: "Generic Component Pressure Sensor", event: [[name: "pressure", value: newVals[0], descriptionText:"${friendly} pressure is ${newVals[0]}"]], namespace: "community"],
smoke: [type: "Generic Component Smoke Detector", event: [[name: "smoke", value: newVals[0] == "on" ? "detected":"clear", descriptionText:"${friendly} is updated"]]],
switch: [type: "Generic Component Switch", event: [[name: "switch", value: newVals[0], descriptionText:"${friendly} was turn ${newVals[0]}"]]],
temperature: [type: "Generic Component Temperature Sensor", event: [[name: "temperature", value: newVals[0], descriptionText:"${friendly} temperature is ${newVals[0]}"]]],
voltage: [type: "Generic Component Voltage Sensor", event: [[name: "voltage", value: newVals[0], descriptionText:"${friendly} voltage is ${newVals[0]}"]]],
window: [type: "Generic Component Contact Sensor", event: [[name: "contact", value: newVals[0] == "on" ? "open":"closed", descriptionText:"${friendly} is updated"]]],
climate: [type: "Generic Component Thermostat", event: [[name: "thermostatMode", value: newVals[0], descriptionText: "${friendly} is set to ${newVals[0]}"],
[name: "temperature", value: newVals[1], descriptionText: "${friendly}'s current temperature is ${newVals[1]} degree"],
[name: "coolingSetpoint", value: newVals[2], descriptionText: "${friendly}'s cooling temperature is set to ${newVals[2]} degree"],
[name: "heatingSetpoint", value: newVals[2], descriptionText: "${friendly}'s heating temperature is set to ${newVals[2]} degree"],
[name: "thermostatFanMode", value: newVals[3], descriptionText: "${friendly}'s fan speed is set to ${newVals[3]}"],
[name: "presetMode", value: newVals[4], descriptionText: "${friendly}'s preset mode is set to ${newVals[4]}"],
[name: "swingMode", value: newVals[5], descriptionText: "${friendly}'s swing mode is set to ${newVals[5]}"],
[name: "thermostatSetpoint", value: newVals[2], descriptionText: "${friendly}'s temperature is set to ${newVals[2]} degree"]]]
return mapping[device_class]
def updateChildDevice(mapping, entity, friendly) {
def ch = createChild(mapping.type, entity, friendly, mapping.namespace)
if (!ch) {
log.warn "Child type: ${mapping.type} not created for entity: ${entity}"
return
else {
ch.parse(mapping.event)
def createChild(deviceType, entity, friendly, namespace = null)
def ch = getChildDevice("${device.id}-${entity}")
if (!ch){
if (logEnable) log.debug("Create child device ${device.id}-${entity}")
ch = addChildDevice(namespace ?: "hubitat", deviceType, "${device.id}-${entity}", [name: "${entity}", label: "${friendly}", isComponent: false])
return ch
def removeChild(entity){
String thisId = device.id
def ch = getChildDevice("${thisId}-${entity}")
if (ch) {deleteChildDevice("${thisId}-${entity}")}
def componentOn(ch){
if (logEnable) log.info("received on request from ${ch.label}")
state.id = state.id + 1
entity = ch.name
domain = entity.tokenize(".")[0]
if (!ch.currentValue("level")) {
messOn = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}"]])
else {
messOn = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}", brightness_pct: "${ch.currentValue("level")}"]])
if (logEnable) log.debug("messOn = ${messOn}")
interfaces.webSocket.sendMessage("${messOn}")
def componentOff(ch){
if (logEnable) log.info("received off request from ${ch.label}")
entity = ch.name
messOff = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_off", service_data: [entity_id: "${entity}"]])
if (logEnable) log.debug("messOff = ${messOff}")
interfaces.webSocket.sendMessage("${messOff}")
def componentSetLevel(ch, level, transition=1){
if (logEnable) log.info("received setLevel request from ${ch.label}")
if (level > 100) level = 100
if (level < 0) level = 0
//if a Fan device, special handling
if (ch.currentValue("speed")) {
switch (level.toInteger()) {
case 0:
componentSetSpeed(ch, "off")
break
case 1..25:
componentSetSpeed(ch, "low")
break
case 26..50:
componentSetSpeed(ch, "medium")
break
case 51..75:
componentSetSpeed(ch, "medium-high")
break
case 76..100:
componentSetSpeed(ch, "high")
break
default:
if (logEnable) log.info "No case defined for Fan setLevel(${level})"
else {
entity = ch.name
messLevel = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}", brightness_pct: "${level}", transition: "${transition}"]])
if (logEnable) log.debug("messLevel = ${messLevel}")
interfaces.webSocket.sendMessage("${messLevel}")
def componentSetColor(ch, color, transition=1){
if (logEnable) log.info("received setColor request from ${ch.label}")
entity = ch.name
convertedHue = Math.round(color.hue * 360/100)
messHSL = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}", brightness_pct: "${color.level}", hs_color: ["${convertedHue}", "${color.saturation}"], transition: "${transition}"]])
if (logEnable) log.debug("messHSL = ${messHSL}")
interfaces.webSocket.sendMessage("${messHSL}")
def componentSetColorTemperature(ch, colortemperature, transition=1){
if (logEnable) log.info("received setColorTemperature request from ${ch.label}")
entity = ch.name
messCT = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}", kelvin: "${colortemperature}", transition: "${transition}"]])
if (logEnable) log.debug("messCT = ${messCT}")
interfaces.webSocket.sendMessage("${messCT}")
def componentSetSpeed(ch, speed) {
if (logEnable) log.info("received setSpeed request from ${ch.label}, with speed = ${speed}")
int percentage = 0
entity = ch.name
switch (speed) {
case "on":
break
case "off":
break
case "low":
case "medium-low":
percentage = 25
break
case "auto":
case "medium":
percentage = 50
break
case "medium-high":
percentage = 75
break
case "high":
percentage = 100
break
default:
if (logEnable) log.info "No case defined for Fan setSpeed(${speed})"
if (percentage != 0) {
messOn = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}", percentage: "${percentage}"]])
def componentCycleSpeed(ch) {
def newSpeed = ""
switch (ch.currentValue("speed")) {
case "off":
speed = "low"
break
case "low":
case "medium-low":
speed = "medium"
break
case "medium":
break
case "medium-high":
speed = "high"
break
case "high":
speed = "off"
break
def componentRefresh(ch){
if (logEnable) log.info("received refresh request from ${ch.label}")
entity = ch.name
messUpd = JsonOutput.toJson([id: state.id, type: "call_service", domain: "homeassistant", service: "update_entity", service_data: [entity_id: "${entity}"]])
if (logEnable) log.debug("messUpd = ${messUpd}")
interfaces.webSocket.sendMessage("${messUpd}")
def componentSetThermostatMode(ch, thermostatmode){
if (logEnable) log.info("received setThermostatMode request from ${ch.label}")
entity = ch.name
messUpd = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "set_hvac_mode", service_data: [entity_id: "${entity}", hvac_mode: "${thermostatmode}"]])
def componentSetCoolingSetpoint(ch, temperature){
if (logEnable) log.info("received setCoolingSetpoint request from ${ch.label}")
entity = ch.name
messUpd = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "set_temperature", service_data: [entity_id: "${entity}", temperature: "${temperature}"]])
def componentSetHeatingSetpoint(ch, temperature){
if (logEnable) log.info("received setHeatingSetpoint request from ${ch.label}")
entity = ch.name
def componentsetThermostatFanMode(ch, fanmode){
if (logEnable) log.info("received fanmode request from ${ch.label}")
entity = ch.name
messUpd = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "set_fan_mode", service_data: [entity_id: "${entity}", fan_mode: "${fanmode}"]])
def componentsetPresetMode(ch, presetmode){
if (logEnable) log.info("received preset mode request from ${ch.label}")
entity = ch.name
messUpd = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "set_preset_mode", service_data: [entity_id: "${entity}", preset_mode: "${presetmode}"]])
def componentsetSwingMode(ch, swingmode){
if (logEnable) log.info("received swing mode request from ${ch.label}")
entity = ch.name
messUpd = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "set_swing_mode", service_data: [entity_id: "${entity}", swing_mode: "${swingmode}"]])
def closeConnection() {
if (logEnable) log.debug("Closing connection...")
state.wasExpectedClose = true
interfaces.webSocket.close()
def deleteAllChildDevices() {
log.info "Uninstalling all Child Devices"
getChildDevices().each {
deleteChildDevice(it.deviceNetworkId)
