To add locks to the integration:
In the "Home Assistant Device Bridge" app, line 84 should be:
if(["fan", "switch", "light", "binary_sensor", "sensor", "device_tracker", "cover","lock"].contains(domain))
For the "HomeAssistant Hub Parent" driver
* Home Assistant to Hubitat Integration
* Description:
* Allow control of HA devices.
* Required Information:
* Home Asisstant IP and Port number
* Home Assistant long term Access Token
* Features List:
* Licensing:
* Copyright 2021 Yves Mercier.
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at: http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Version Control:
* 0.1.0 2021-02-05 Yves Mercier Orinal version
* 0.1.1 2021-02-06 Dan Ogorchock Added basic support for simple "Light" devices from Home Assistant using Hubitat Generic Component Dimmer driver
* 0.1.2 2021-02-06 tomw Added handling for some binary_sensor subtypes based on device_class
* 0.1.3 2021-02-06 Dan Ogorchock Bug Fixes
* 0.1.4 2021-02-06 Yves Mercier Added version number and import URL
* 0.1.5 2021-02-06 Dan Ogorchock Added support for Temperature and Humidity Sensors
* 0.1.6 2021-02-06 Dan Ogorchock Corrected open/closed for HA door events
* 0.1.7 2021-02-07 Dan Ogorchock Corrected open/closed for HA window, garage_door, and opening per @smarthomeprimer
* 0.1.8 2021-02-07 Dan Ogorchock Removed temperature and humidity workaround for missing device_class on some HA sensors.
* This can be corrected on the HA side via the Customize entity feature to add the missing device_class.
* 0.1.9 2021-02-07 tomw More generic handling for "sensor" device_classes. Added voltage device_class to "sensor".
* 0.1.10 2021-02-07 Dan Ogorchock Refactored the translation from HA to HE to simplify the overall design
* 0.1.11 2021-02-07 Dan Ogorchock Completed refactoring of Dimmer Switch support
* 0.1.12 2021-02-08 Dan Ogorchock Fixed typo in log.info statement
* 0.1.13 2021-02-08 tomw Added "community" namespace support for component drivers. Added Pressure and Illuminance.
* 0.1.14 2021-02-10 Dan Ogorchock Added support for Fan devices (used Lutron Fan Controller as test device.)
* 0.1.15 2021-02-13 tomw Adjust websocket status handling to reconnect on both close and error conditions.
* 0.1.16 2021-02-14 tomw Revert 0.1.15
* 0.1.17 2021-02-14 Dan Ogorchock Improved webSocket reconnect logic
* 0.1.18 2021-02-14 tomw Avoid reconnect loop on initialize
* 0.1.19 2021-02-16 Yves Mercier Added Refresh handler
* 0.1.20 2021-02-16 Yves mercier Refactored webSocketStatus
* 0.1.21 2021-02-22 Yves mercier Reinstated CloseConnection command. Added connection status on device page.
* 0.1.22 2021-02-24 tomw Changes to support optional device filtering. For use with haDeviceBridgeConfiguration.groovy.
* 0.1.23 2021-02-25 Dan Ogorchock Switched from Exclude List to Include List
* 0.1.24 2021-03-07 Yves Mercier Added device label in event description
* 0.1.25 2021-03-18 Dan Ogorchock Updated for recent Hass Fan handling changes (use percentages to set speeds instead of deprecated speed names)
* 0.1.26 2021-04-02 DongHwan Suh Added partial support for Color temperature, RGB, RGBW lights
* (Manually updating the device type to the corresponding one is required in Hubitat. Only statuses of level and switch are shown in Hubitat.)
* 0.1.27 2021-04-11 Yves Mercier Added option for secure connection
* 0.1.28 2021-04-14 Dan Ogorchock Improved Fan Device handling
* 0.1.29 2021-04-17 Dan Ogorchock Added support for Smoke Detector Binary Sensor
* 0.1.30 2021-08-10 tomw Added support for device_tracker as Presence Sensor
* 0.1.31 2021-09-23 tomw Added support for Power sensor
* 0.1.33 2021-09-28 tomw Added support for cover as Garage Door Opener
* Thank you(s):
import groovy.json.JsonSlurper
import groovy.json.JsonOutput
metadata {
definition (name: "HomeAssistant Hub Parent", namespace: "ymerj", author: "Yves Mercier", importUrl: "https://raw.githubusercontent.com/ymerj/HE-HA-control/main/HA%20parent.groovy") {
capability "Initialize"
// command "createChild", [[ name: "entity", type: "STRING", description: "HomeAssistant Entity ID" ]]
// command "removeChild", [[ name: "entity", type: "STRING", description: "HomeAssistant Entity ID" ]]
command "closeConnection"
// command "deleteAllChildDevices"
attribute "Connection", "string"
preferences {
input ("ip", "text", title: "IP", description: "HomeAssistant IP Address", required: true)
input ("port", "text", title: "Port", description: "HomeAssistant Port Number", required: true, defaultValue: "8123")
input ("token", "text", title: "Token", description: "HomeAssistant Long-Lived Access Token", required: true)
input ("secure", "bool", title: "Require secure connection (https)", defaultValue: false)
input ("logEnable", "bool", title: "Enable debug logging", defaultValue: true)
input ("txtEnable", "bool", title: "Enable description text logging", defaultValue: true)
def logsOff(){
log.warn("debug logging disabled...")
device.updateSetting("logEnable",[value:"false",type:"bool"])
def updated(){
log.info("updated...")
log.warn("debug logging is: ${logEnable == true}")
log.warn("description logging is: ${txtEnable == true}")
unschedule()
if (logEnable) runIn(1800,logsOff)
initialize()
def initialize() {
log.info("initializing...")
closeConnection()
state.id = 2
def connectionType = "ws"
if (secure) connectionType = "wss"
auth = '{"type":"auth","access_token":"' + "${token}" + '"}'
evenements = '{"id":1,"type":"subscribe_events","event_type":"state_changed"}'
try {
interfaces.webSocket.connect("${connectionType}://${ip}:${port}/api/websocket", ignoreSSLIssues: true)
interfaces.webSocket.sendMessage("${auth}")
interfaces.webSocket.sendMessage("${evenements}")
catch(e) {
log.error("initialize error: ${e.message}")
def uninstalled() {
log.info("uninstalled...")
closeConnection()
unschedule()
deleteAllChildDevices()
def webSocketStatus(String status){
if (logEnable) log.debug "webSocket ${status}"
if ((status == "status: closing") && (state.wasExpectedClose)) {
state.wasExpectedClose = false
sendEvent(name: "Connection", value: "Closed")
return
else if(status == 'status: open') {
log.info "websocket is open"
// success! reset reconnect delay
pauseExecution(1000)
state.reconnectDelay = 1
sendEvent(name: "Connection", value: "Open")
else {
log.warn "WebSocket error, reconnecting."
sendEvent(name: "Connection", value: "Reconnecting")
reconnectWebSocket()
def reconnectWebSocket() {
// first delay is 2 seconds, doubles every time
state.reconnectDelay = (state.reconnectDelay ?: 1) * 2
// don't let delay get too crazy, max it out at 10 minutes
if(state.reconnectDelay > 600) state.reconnectDelay = 600
//If the Home Assistant Hub is offline, give it some time before trying to reconnect
runIn(state.reconnectDelay, initialize)
if (logEnable) log.debug("parse(): description = ${description}")
def response = null;
try{
response = new groovy.json.JsonSlurper().parseText(description)
if (response.type != "event") return
def newVals = []
def entity = response?.event?.data?.entity_id
// check whether we have a parent, and search its includeList for devices to process
def includeList = getParent()?.includeList
if(includeList && !includeList?.contains(entity)) return
def domain = entity?.tokenize(".")?.getAt(0)
def device_class = response?.event?.data?.new_state?.attributes?.device_class
def friendly = response?.event?.data?.new_state?.attributes?.friendly_name
newVals << response?.event?.data?.new_state?.state
def mapping = null
if (logEnable) log.debug "parse: domain: ${domain}, device_class: ${device_class}, entity: ${entity}, newVals: ${newVals}, friendly: ${friendly}"
switch (domain) {
case "fan":
def speed = response?.event?.data?.new_state?.attributes?.speed
def percentage = response?.event?.data?.new_state?.attributes?.percentage
switch (percentage.toInteger()) {
case 0:
speed = "off"
break
case 25:
speed = "low"
break
case 50:
speed = "medium"
break
case 75:
speed = "medium-high"
break
case 100:
speed = "high"
default:
if (logEnable) log.info "Invalid fan percentage received - ${percentage}"
newVals += speed
newVals += percentage
mapping = translateDevices(domain, newVals, friendly)
if (mapping) updateChildDevice(mapping, entity, friendly)
break
case "cover":
if(!(["garage"].contains(device_class)))
// only support "garage" device_class for "cover" domain
return
case "lock":
case "device_tracker":
case "switch":
break
case "light":
def level = response?.event?.data?.new_state?.attributes?.brightness
if (level) level = Math.round((level.toInteger() * 100 / 255))
newVals += level
if (!level) mapping.event.remove(1) //remove the level update since it is not provided with the HA 'off' event json data
break
case "binary_sensor":
case "sensor":
mapping = translateDevices(device_class, newVals, friendly)
break
default:
if (logEnable) log.info "No mapping exists for domain: ${domain}, device_class: ${device_class}. Please contact devs to have this added."
return
catch(e) {
log.error("Parsing error: ${e}")
return
def translateDevices(device_class, newVals, friendly)
def mapping =
door: [type: "Generic Component Contact Sensor", event: [[name: "contact", value: newVals[0] == "on" ? "open":"closed", descriptionText:"${friendly} is updated"]]],
fan: [type: "Generic Component Fan Control", event: [[name: "switch", value: newVals[0], descriptionText:"${friendly} was turn ${newVals[0]}"],[name: "speed", value: newVals[1], descriptionText:"${friendly} speed was set to ${newVals[1]}"],[name: "level", value: newVals[2], descriptionText:"${friendly} level was set to ${newVals[2]}"]]],
garage_door: [type: "Generic Component Contact Sensor", event: [[name: "contact", value: newVals[0] == "on" ? "open":"closed", descriptionText:"${friendly} is updated"]]],
humidity: [type: "Generic Component Humidity Sensor", event: [[name: "humidity", value: newVals[0], descriptionText:"${friendly} humidity is ${newVals[0]}"]]],
illuminance: [type: "Generic Component Illuminance Sensor", event: [[name: "illuminance", value: newVals[0], descriptionText:"${friendly} illuminance is ${newVals[0]}"]], namespace: "community"],
light: [type: "Generic Component Dimmer", event: [[name: "switch", value: newVals[0], descriptionText:"${friendly} was turn ${newVals[0]}"],[name: "level", value: newVals[1], descriptionText:"${friendly} level was set to ${newVals[1]}"]]],
moisture: [type: "Generic Component Water Sensor", event: [[name: "water", value: newVals[0] == "on" ? "wet":"dry", descriptionText:"${friendly} is updated"]]],
motion: [type: "Generic Component Motion Sensor", event: [[name: "motion", value: newVals[0] == "on" ? """active""":"""inactive""", descriptionText:"${friendly} is updated"]]],
opening: [type: "Generic Component Contact Sensor", event: [[name: "contact", value: newVals[0] == "on" ? "open":"closed", descriptionText:"${friendly} is updated"]]],
power: [type: "Generic Component Power Meter", event: [[name: "power", value: newVals[0], descriptionText:"${friendly} power is ${newVals[0]}"]]],
presence: [type: "Generic Component Presence Sensor", event: [[name: "presence", value: newVals[0] == "on" ? "present":"not present", descriptionText:"${friendly} is updated"]], namespace: "community"],
pressure: [type: "Generic Component Pressure Sensor", event: [[name: "pressure", value: newVals[0], descriptionText:"${friendly} pressure is ${newVals[0]}"]], namespace: "community"],
smoke: [type: "Generic Component Smoke Detector", event: [[name: "smoke", value: newVals[0] == "on" ? "detected":"clear", descriptionText:"${friendly} is updated"]]],
switch: [type: "Generic Component Switch", event: [[name: "switch", value: newVals[0], descriptionText:"${friendly} was turn ${newVals[0]}"]]],
temperature: [type: "Generic Component Temperature Sensor", event: [[name: "temperature", value: newVals[0], descriptionText:"${friendly} temperature is ${newVals[0]}"]]],
voltage: [type: "Generic Component Voltage Sensor", event: [[name: "voltage", value: newVals[0], descriptionText:"${friendly} voltage is ${newVals[0]}"]]],
window: [type: "Generic Component Contact Sensor", event: [[name: "contact", value: newVals[0] == "on" ? "open":"closed", descriptionText:"${friendly} is updated"]]],
device_tracker: [type: "Generic Component Presence Sensor", event: [[name: "presence", value: newVals[0] == "home" ? "present":"not present", descriptionText:"${friendly} is updated"]], namespace: "community"],
cover: [type: "Generic Component Garage Door Control", event: [[name: "door", value: newVals[0] ?: "unknown", descriptionText:"${friendly} was turn ${newVals[0]}"]], namespace: "community"],
lock: [type: "Generic Component Lock", event: [[name: "lock", value: newVals[0] ?: "unknown", descriptionText:"${friendly} was turn ${newVals[0]}"]]]
return mapping[device_class]
def updateChildDevice(mapping, entity, friendly) {
def ch = createChild(mapping.type, entity, friendly, mapping.namespace)
if (!ch) {
log.warn "Child type: ${mapping.type} not created for entity: ${entity}"
return
else {
ch.parse(mapping.event)
def createChild(deviceType, entity, friendly, namespace = null)
def ch = getChildDevice("${device.id}-${entity}")
if (!ch) ch = addChildDevice(namespace ?: "hubitat", deviceType, "${device.id}-${entity}", [name: "${entity}", label: "${friendly}", isComponent: false])
return ch
def removeChild(entity){
String thisId = device.id
def ch = getChildDevice("${thisId}-${entity}")
if (ch) {deleteChildDevice("${thisId}-${entity}")}
def componentOn(ch){
if (logEnable) log.info("received on request from ${ch.label}")
state.id = state.id + 1
entity = ch.name
domain = entity.tokenize(".")[0]
if (!ch.currentValue("level")) {
messOn = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}"]])
else {
messOn = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}", brightness_pct: "${ch.currentValue("level")}"]])
if (logEnable) log.debug("messOn = ${messOn}")
interfaces.webSocket.sendMessage("${messOn}")
def componentOff(ch){
if (logEnable) log.info("received off request from ${ch.label}")
entity = ch.name
messOff = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_off", service_data: [entity_id: "${entity}"]])
if (logEnable) log.debug("messOff = ${messOff}")
interfaces.webSocket.sendMessage("${messOff}")
def componentSetLevel(ch, level, transition=1){
if (logEnable) log.info("received setLevel request from ${ch.label}")
if (level > 100) level = 100
if (level < 0) level = 0
//if a Fan device, special handling
if (ch.currentValue("speed")) {
switch (level.toInteger()) {
case 0:
componentSetSpeed(ch, "off")
break
case 1..25:
componentSetSpeed(ch, "low")
break
case 26..50:
componentSetSpeed(ch, "medium")
break
case 51..75:
componentSetSpeed(ch, "medium-high")
break
case 76..100:
componentSetSpeed(ch, "high")
break
default:
if (logEnable) log.info "No case defined for Fan setLevel(${level})"
else {
entity = ch.name
messLevel = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}", brightness_pct: "${level}", transition: "${transition}"]])
if (logEnable) log.debug("messLevel = ${messLevel}")
interfaces.webSocket.sendMessage("${messLevel}")
def componentSetColor(ch, color, transition=1){
if (logEnable) log.info("received setColor request from ${ch.label}")
entity = ch.name
convertedHue = Math.round(color.hue * 360/100)
messHSL = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}", brightness_pct: "${color.level}", hs_color: ["${convertedHue}", "${color.saturation}"], transition: "${transition}"]])
if (logEnable) log.debug("messHSL = ${messHSL}")
interfaces.webSocket.sendMessage("${messHSL}")
def componentSetColorTemperature(ch, colortemperature, transition=1){
if (logEnable) log.info("received setColorTemperature request from ${ch.label}")
entity = ch.name
messCT = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}", kelvin: "${colortemperature}", transition: "${transition}"]])
if (logEnable) log.debug("messCT = ${messCT}")
interfaces.webSocket.sendMessage("${messCT}")
def componentSetSpeed(ch, speed) {
if (logEnable) log.info("received setSpeed request from ${ch.label}, with speed = ${speed}")
int percentage = 0
entity = ch.name
switch (speed) {
case "on":
break
case "off":
break
case "low":
case "medium-low":
percentage = 25
break
case "auto":
case "medium":
percentage = 50
break
case "medium-high":
percentage = 75
break
case "high":
percentage = 100
break
default:
if (logEnable) log.info "No case defined for Fan setSpeed(${speed})"
if (percentage != 0) {
messOn = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: "turn_on", service_data: [entity_id: "${entity}", percentage: "${percentage}"]])
def componentCycleSpeed(ch) {
def newSpeed = ""
switch (ch.currentValue("speed")) {
case "off":
speed = "low"
break
case "low":
case "medium-low":
speed = "medium"
break
case "medium":
break
case "medium-high":
speed = "high"
break
case "high":
speed = "off"
break
void componentClose(ch) {
operateCover(ch, "close")
void componentOpen(ch) {
operateCover(ch, "open")
void operateCover(ch, op)
if (logEnable) log.info("received ${op} request from ${ch.label}")
entity = ch.name
messOff = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: (op == "open") ? "open_cover" : "close_cover", service_data: [entity_id: "${entity}"]])
void componentLock(ch) {
operateLock(ch, "lock")
void componentUnlock(ch) {
operateLock(ch, "unlock")
void operateLock(ch, op)
entity = ch.name
messOff = JsonOutput.toJson([id: state.id, type: "call_service", domain: "${domain}", service: (op == "unlock") ? "unlock" : "lock", service_data: [entity_id: "${entity}"]])
def componentRefresh(ch){
if (logEnable) log.info("received refresh request from ${ch.label}")
entity = ch.name
messUpd = JsonOutput.toJson([id: state.id, type: "call_service", domain: "homeassistant", service: "update_entity", service_data: [entity_id: "${entity}"]])
if (logEnable) log.debug("messUpd = ${messUpd}")
interfaces.webSocket.sendMessage("${messUpd}")
def closeConnection() {
if (logEnable) log.debug("Closing connection...")
state.wasExpectedClose = true
interfaces.webSocket.close()
def deleteAllChildDevices() {
log.info "Uninstalling all Child Devices"
getChildDevices().each {
deleteChildDevice(it.deviceNetworkId)
As I said, this code works, but I'm not a coder. Perhaps @tomw or @ogiewon could review and comment.
