Android Auto port is awesome!!
I have waited some time for a solution like this to come along. Thanks so much for making it happen!
Here are some notes....
Is there any way to remove items from showing? I know I can sort all of the less used devices to the end, but there must be a way to shorten the list and only include certain items
Is there any way to group items into folders? Or rooms?
Google has this 'tabbed' UI which I'm actually using but only if your car supports version 6 (which I subsequently learned is still in 'alpha' so it's probably not supported by any cars yet..)
I had a whole tabbed UI setup in HD+ where you could change the tab names and icons too.. but removed it when I realized it wouldn't be used by any cars today. I'll re-add it if/when it's supported.
I'm not sure how you can tell which version API your car supports.. I do log it in the app though
This is a great dashboard! Thank you so much for developing it. I finally was able to get rid of my Samsung SmartThings with the Android auto addition. And the geolocation really is very consistent and works accurately. This is as really been a great important tool for habitat. Great work, excellent job, and thank you.
This is the first I'm reading about coolwalk. Is it just a matter of updating the phone or do you have to update something in the car too? From what I can see I have to get into the beta version of the AA app.
Anyway, if there's something I can or need to do to support it - I will try!
From what i understand the apps need to be updated to support the new interface. I do not know what exactly is required. Coolwalk has mostly rolled out to the public. Im not in the beta and it shows up in my car.
Mostly minor changes for Android Auto -- some crashes that I've seen reported. I still haven't tested this in an actual car yet so feel free to pass along any thoughts/ideas. I'll look more into crosswalk if there's something I can do there.
The other change is showing a little asterisk when any commands are sent after touching a button (push/hold/double-tap).. it should go away after a few seconds. Hopefully that'll help a bit.
Quick question... is it worth starting a new Hubitat thread just for HD+ Android Auto support? I keep forgetting how large this thread is and while it's great for me (1 place to look) I imagine it's pretty crappy finding stuff for anyone else.
Seems like Android Auto support is something that only a handful of users are interested in so maybe it's worth it's own place...
Unless I hear otherwise why this isn't a good idea I'll just create a new thread and link it here
Here's a dedicated Android Auto thread for HD+ -- no worries if you post here too but I might try to reply in the other thread just to have 1 place to reference things.
Sounds like it's sorta workish so you probably have the format for the stream right. I don't have one of those so...... But. Mine will do that if I don't set the frame rate down to about 4fps. If that helps and you don't like the slow frame rate you can experiment with raising it back up. This is assuming that your camera has that option. Let us know that results.
Have you tried downloading the RTSP Demo app to see whether it plays in that? Joe posted a link to it way up the page (January I think). The RTSP video in HD+ is based on that code.
Lots of Android Auto changes ((discussed more in the AA thread)
Improved Life360 support
Life360+
If you use Life360, I made several changes to the embedded map. I also refactored the Hubitat "Life360 with States" app (called Life360+) to improve what can be done in this app. Life360+ isn't available yet in HPM but either one should still work.
I have a Reolink outdoor camera (RLC-410W) and live streaming works. I do use the lower quality version (_sub URL below). I'll try the higher quality version later to see if that works too.. I think it did though.
Hi @jpage4500, Cool app! I just started playing with it and one thing I cannot find, and it may not even exist, is a way to change the text color for different states, is there? i.e. for some tiles I use a green background to indicate an OK state and the white text gets a little washed out and I would make that black. No biggie if that customization doesn't exist I just wanted to make sure I didn't miss that setting somewhere. Thanks again for a great app.
Hi, you can change the text color for some device types - such as the ones that show text as the primary value. But, nothing for the device name or status text. Is that what you're wondering about?
Yea, the Name and Status text color; in your screenshot it would be the 'May 09' and 'Tuesday'. Out of the 4300+ posts I did finally see a post from Sep21 that indicated that this text is not customizable. And it sounds like that is still true. Like I mentioned, not a biggie, just making sure I didn't miss it. Thanks again.
I have the Reolink doorbell too and I get a good video feed in the video tile on my phone using rtsp://user:password1@10.0.1.34:554. I have also set the doorbell up for ONVIF and use this to get visitor events (instead of using the chime) https://community.hubitat.com/t/reolink-doorbell-receiving-visitor-events-in-hubitat/118573. BUT I have tried on 2 tablets, one running Android 5 which just shows "Decoder Init Failed", and the other running Android 9 which just shows "Reconnecting". I don't know why.
On a slightly different subject... can the video tile support 2-way audio (and does rtsp support it). I know that the ONVIF feed from the doorbell supports 2-way audio. I'm trying to find a way of talking to the person who pressed the doorbell from inside HD+.
