Sure here is the node server. Just backup your assistant.js file and replace with this. Fair warning I take no responsibility if something breaks. Towards the end of the file are a few lines you need to modify.
var heUri = '/apps/api/2832/trigger/setGlobalVariable=test2:' + gaResponse + '?access_token=461f117c-95ad-4d52-8136-12345678789'
this line needs to be modified with your accesstoken and the name of the global variable you want to set. Also the app id for your RM trigger.
Also just below this line you need to set the ip of your hubitat hub.
Let me know how you get on
const async = require('async');
const GoogleAssistant = require('google-assistant');
const FileReader = require('wav').Reader;
const FileWriter = require('wav').FileWriter;
//const wavFileInfo = require('wav-file-info');
const terminalImage = require('terminal-image');
const path = require('path');
const fs = require("fs");
var tou8 = require('buffer-to-uint8array');
var http = require("http");
const defaultAudio = false;
let returnAudio;
let gConfig;
var playbackWriter = new FileWriter('server/playback.wav', {
sampleRate: 24000,
channels: 1
const inputFiles = [
`${path.resolve(__dirname, 'broadcast.wav')}`,
`${path.resolve(__dirname, 'response.wav')}`
var self = module.exports = {
setupAssistant: function() {
return new Promise((resolve, reject) => {
let users = []
async.forEachOfLimit(global.config.users, 1, function(i, k, cb){
let auth = i;
users.push(k)
global.config.assistants[k] = new GoogleAssistant(i)
let assistant = global.config.assistants[k];
assistant.on('ready', () => cb());
assistant.on('error', (e) => {
console.log(`❌ Assistant Error when activating user ${k}. Trying next user ❌ \n`);
return cb();
}, function(err){
if(err) return reject(err.message);
(async() => {
console.log(await terminalImage.file('./icon.png'))
console.log(`Assistant Relay is now setup and running for${users.map(u => ` ${u}`)} \n`)
console.log(`You can now visit ${global.config.baseUrl} in a browser, or send POST requests to it`);
if (!global.config.muteStartup) {
self.sendTextInput('broadcast Assistant Relay is now setup and running')
resolve()
sendTextInput: function(text, n, converse) {
console.log(`Received command ${text} \n`);
if(converse) returnAudio = true;
// set the conversation query to text
global.config.conversation.textQuery = text;
const assistant = self.setUser(n)
assistant.start(global.config.conversation, (conversation) => {
return self.startConversation(conversation)
.then((data) => {
resolve(data)
.catch((err) => {
reject(err)
sendAudioInput: function() {
let raw = []
const assistant = self.setUser('greg');
fs.readFile(`${path.resolve(__dirname, 'response.wav')}`, (err, file) => {
if(err) console.log(err)
return self.startConversation(conversation, file)
.then((data) => {
console.log(data)
//resolve(data)
.catch((err) => {
console.log(err)
//reject(err)
startConversation: function(conversation, file) {
let response = {};
const fileStream = self.outputFileStream();
conversation.write(file)
conversation
.on('audio-data', data => {
fileStream.write(data)
// set a random parameter on audio url to prevent caching
response.audio = `http://${global.config.baseUrl}/audio?v=${Math.floor(Math.random() * 100)}`
.on('response', (text) => {
if (text) { sendReq(text)
console.log(`Google Assistant: ${text} \n`)
response.response = text;
if(returnAudio) {
self.sendTextInput(`broadcast ${text}`, null, gConfig);
returnAudio = false;
//dit it here
.on('end-of-utterance', () => {
console.log("Done speaking")
.on('transcription', (data) => {
console.log(data)
.on('volume-percent', percent => {
console.log(`Volume has been set to ${percent} \n`)
response.volume = `New Volume Percent is ${percent}`;
.on('device-action', action => {
console.log(`Device Action: ${action} \n`)
response.action = `Device Action is ${action}`;
.on('ended', (error, continueConversation) => {
if (error) {
console.log('Conversation Ended Error:', error);
response.success = false;
reject(response)
} else if (continueConversation) {
response.success = true;
console.log('Continue the conversation... somehow \n');
conversation.end();
resolve();
} else {
console.log('Conversation Complete \n');
fileStream.end()
//self.joinAudio();
conversation.end();
resolve(response);
.on('error', (error) => {
console.log(`Something went wrong: ${error}`)
response.error = error;
reject(response)
setUser: function(n) {
// set default assistant to first user
assistant = Object.keys(global.config.assistants)[0];
assistant = global.config.assistants[`${assistant}`];
// check to see if user passed exists
if(n) {
const users = Object.keys(global.config.users);
if(!users.includes(n.toLowerCase())) {
console.log(`User not found, using ${Object.keys(global.config.assistants)[0]} \n`)
} else {
n = n.toLowerCase();
console.log(`User specified was ${n} \n`)
assistant = global.config.assistants[`${n}`]
} else {
console.log(`No user specified, using ${Object.keys(global.config.assistants)[0]} \n`)
return assistant;
outputFileStream: function() {
return new FileWriter(path.resolve(__dirname, 'response.wav'), {
sampleRate: global.config.conversation.audio.sampleRateOut,
channels: 1
joinAudio: function() {
if(!inputFiles.length) {
playbackWriter.end("done");
return;
currentFile = inputFiles.shift()
let stream = fs.createReadStream(currentFile);
stream.pipe(playbackWriter, {end: false});
stream.on('end', () => {
console.log(currentFile, "appended")
self.joinAudio()
function sendReq(text){
//console.log (text)
var gaResponse = text.replace(/\?/g, "")
var gaResponse = gaResponse.replace(/\:/g, "")
var uriencode = encodeURI(heUri)
console.log ("uri: " + uriencode)
var options = {
hostname: '192.168.1.129',
//port: 80,
path: uriencode,
method: 'GET',
headers: {
'Content-Type': 'application/xml',
var req = http.request(options, function(res) {
console.log('Status: ' + res.statusCode);
console.log('Headers: ' + JSON.stringify(res.headers));
res.setEncoding('utf8');
res.on('data', function (body) {
console.log('Body: ' + body);
req.on('error', function(e) {
console.log('problem with request: ' + e.message);
req.end();
