I haven't used this driver in a loooong time but wanted to play around with it and see what was new. These custom commands are great! I can now send my nest cams to my nest hubs when HE receives motion!
[CC]show front door camera on living room display
Unfortunately, "[CC]stop living room display" doesn't seem to work. Anybody find a command that stops the stream?
I know this isn't a great option, but I believe the stop command from the Chromecast Beta implementation works correctly still. I'm having the same problem with Cast-web-api at the moment. I think google did something with the stop command.
Yeah, I know....it works when you say it to your GH but for some reason the Assistant SDK doesn't like "stop" anymore. I don't know why, I just know it's affecting Cast-Web-API as well, which makes me think it's not just an AR problem but a Assistant SDK problem. But i could be totally wrong...it's just an idea.
Okay...i don't know what I am doing wrong but I cannot get PM2 to work. I ran the assistant-relay installer fine but after I run sudo npm install pm2 -g install and the try to do pm2 startup, i get -bash: pm2: command not found. I am following @ogiewon's instructions to the letter and it just will not work.
UDPATE: Never mind, it's Cast-web-API-CLI screwing with it. It uses PM2 for it's new native process management. Unfortunately that locks out PM2 for anything else to use! Lovely. UGH!
As @Ryan780 said, something changed with the Assistant SDK. I used to be able to use [CC] stop streaming, but that won’t work from Google Assistant Relay or Cast Web API now. But I can confirm that the Chromecast Integration (beta) does indeed stop the stream with the custom action stop()
I said I suspected that....and only after he reported having the same problem in Assistant Relay that I'm having with cast-web-api's stop command. But, if you read the whole post I said i might be completely wrong. Please don't quote me so inaccurately.
Just a suggestion. Personally I use cronjobs to start my node servers at startup of my pi. I figure if something is repeatedly crashing I want to know about it. Not just keep restarting it.
Plus I just find those service programs to be annoying and not very intuitive.
Hey @ogiewon I am at page 25 from the .docx instructions document but when typing the command pm2 startup it will show as command not found. As I understand from the previous command in my screen the pm2 was succesfully installed right? so am I missing something ??
when doing the steps from page 23 from the .doc document yes I heard the “Assistant relay is now setup and running for aldo" but now if I do some tests by typing some text in the boxes and then pushing the button, there is no sound and in the logs this is the error:
