Strange added 1 min delay, still showing true 1min later
I suspected it already, given the fact it stays so long Beta I guess it is not easy to solve the issues or there is no time/priority to look at the problem...
Ln 549 in speechOff still calls the state.motion and its going down that path
Edit created a completely clean version and its working now, must have been hanging onto motion sensor event
New version on GitHub...
2.1.9 - 05/31/20 - Adjustments to zone off handler and a few other little bits
Be sure to open each child app and hit 'done'
Updated to the latest child and driver from GitHub and currently on the most current version (2.0.2) of the parent.
Made sure to open each child app and click done as well.
The previous error I was seeing (and posted above) is no longer occurring, but it looks like a new one has taken its place.
Similar to before, everything still seems to be working properly and I'm getting the event text that I expect, just seeing this error in the logs.
Try,
Child:
2.2.0 - 05/31/20 - Chasing a bug in push handler
I don't suppose you have an ingenious workaround? 2 of mine aren't responding to the initial volume command even via the chromcast driver.
Could we send a blank txt then volume them message?
That seemed to have worked. No errors in the log anymore!
Thank you sir!
Hi all, so i've finally gotten round to playing with Follow Me - I installed it and setup child devices and then created a rule to send a message to active device if a switch was flipped. flipped the switch and hey presto devices in active zones played the message. I thought it had all gone too well!.
So I then added my follow me virtual device as a notification option to one of my existing rules and fired the rule and I got this: the bottom one being the Pushover notification that came through fine but the voice notiication through follow me never arrived and is showing null:
dev:622020-06-01 10:17:39.803 pm info Echo (v3.6.2.0) | SpeakCommand Sent | (null) | Runtime: (30 sec) | QueueItems: (0)
dev:622020-06-01 10:17:39.557 pm warn Echo (v3.6.2.0) | No Message sent with speak(null) command
dev:1642020-06-01 10:17:38.107 pm infoSending Message: Outside Lights on 09:34 PM Priority: 0 to Device: Josh
Is this because the message was created entirely of variables? i.e in rule manager the message is; %device% %value% %time%
Need to see a debug log of Follow Me receiving this message.
OK so I just triggered an event that is set up to use the Follow Me virtual device as the notification point, I also have this setup to use pushover, the notification came straight through on pushover but isn't playing through echospeaks on follow me. I'm probably doing something wrong I guess? But I also tested it with a simple rule that when a virtual switch is flicked it says "Hello", I flicked the switch and it works fine, so i'm wondering if maybe it's the fact that the message is generated through variables and not pure text or shouldn't that matter?
Here you go, does this help?:
dev:2732020-06-02 08:24:23.760 am infoFollow Me Driver has been Updated
dev:2732020-06-02 08:23:45.027 am debug
Bedroom | Speaking |
Dining Room | Active |
Kitchen | Active |
Living Room | Speaking |
dev:2732020-06-02 08:23:45.025 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 65 - Total Count: 362
dev:2732020-06-02 08:23:45.023 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 60 - Total Count: 297
dev:2732020-06-02 08:23:45.021 am debug
Bedroom | Active |
Kitchen | Active |
dev:2732020-06-02 08:23:45.011 am debugIn sendFollowMeSpeaker - tbl Count: 173 - line Count: 64 - Total Count: 237
dev:2732020-06-02 08:23:45.004 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 61 - Total Count: 173
dev:2732020-06-02 08:23:45.006 am debugIn sendFollowMeSpeaker - tbl Count: 296 - line Count: 65 - Total Count: 361
dev:2732020-06-02 08:23:44.984 am debugIn sendFollowMeSpeaker - tbl Count: 236 - line Count: 60 - Total Count: 296
dev:2732020-06-02 08:23:44.999 am debugIn sendFollowMeSpeaker - sName: Kitchen - sStatus: true
dev:2732020-06-02 08:23:44.989 am debug
Kitchen | Active |
Living Room | Active |
dev:2732020-06-02 08:23:44.960 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 64 - Total Count: 361
dev:2732020-06-02 08:23:44.982 am debugIn sendFollowMeSpeaker - tbl Count: 172 - line Count: 64 - Total Count: 236
dev:2732020-06-02 08:23:44.980 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 60 - Total Count: 172
dev:2732020-06-02 08:23:44.958 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 60 - Total Count: 297
dev:2732020-06-02 08:23:44.956 am debugIn sendFollowMeSpeaker - tbl Count: 173 - line Count: 64 - Total Count: 237
dev:2732020-06-02 08:23:44.955 am debugIn sendFollowMeSpeaker - sName: Bedroom - sStatus: true
dev:2732020-06-02 08:23:44.954 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 61 - Total Count: 173
dev:2732020-06-02 08:23:44.940 am debugIn sendFollowMeSpeaker - sName: Living Room - sStatus: true
dev:2732020-06-02 08:23:44.876 am debug
Kitchen | Active |
dev:2732020-06-02 08:23:44.875 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 65 - Total Count: 362
dev:2732020-06-02 08:23:44.872 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 60 - Total Count: 297
dev:2732020-06-02 08:23:44.870 am debugIn sendFollowMeSpeaker - tbl Count: 173 - line Count: 64 - Total Count: 237
dev:2732020-06-02 08:23:44.865 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 61 - Total Count: 173
dev:2732020-06-02 08:23:44.851 am debugIn sendFollowMeSpeaker - sName: Dining Room - sStatus: true
dev:2732020-06-02 08:23:36.331 am debug
Kitchen | Active |
dev:2732020-06-02 08:23:36.279 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 65 - Total Count: 362
dev:2732020-06-02 08:23:36.277 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 60 - Total Count: 297
dev:2732020-06-02 08:23:36.275 am debugIn sendFollowMeSpeaker - tbl Count: 173 - line Count: 64 - Total Count: 237
dev:2732020-06-02 08:23:36.272 am debug
Bedroom | Active |
Kitchen | Speaking |
dev:2732020-06-02 08:23:36.264 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 61 - Total Count: 173
dev:2732020-06-02 08:23:36.270 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 65 - Total Count: 362
dev:2732020-06-02 08:23:36.255 am debugIn sendFollowMeSpeaker - tbl Count: 236 - line Count: 61 - Total Count: 297
dev:2732020-06-02 08:23:36.253 am debugIn sendFollowMeSpeaker - tbl Count: 172 - line Count: 64 - Total Count: 236
dev:2732020-06-02 08:23:36.250 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 60 - Total Count: 172
dev:2732020-06-02 08:23:36.238 am debugIn sendFollowMeSpeaker - sName: Kitchen - sStatus: true
dev:2732020-06-02 08:23:36.229 am debugIn sendFollowMeSpeaker - sName: Bedroom - sStatus: true
dev:2732020-06-02 08:23:36.016 am debug
dev:2732020-06-02 08:23:36.014 am debugIn sendFollowMeSpeaker - tbl Count: 298 - line Count: 65 - Total Count: 363
dev:2732020-06-02 08:23:36.002 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 61 - Total Count: 298
dev:2732020-06-02 08:23:35.999 am debugIn sendFollowMeSpeaker - tbl Count: 173 - line Count: 64 - Total Count: 237
dev:2732020-06-02 08:23:35.997 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 61 - Total Count: 173
dev:2732020-06-02 08:23:35.984 am debug
dev:2732020-06-02 08:23:35.989 am debugIn sendFollowMeSpeaker - sName: Dining Room - sStatus: true
dev:2732020-06-02 08:23:35.981 am debugIn sendFollowMeSpeaker - tbl Count: 298 - line Count: 64 - Total Count: 362
dev:2732020-06-02 08:23:35.979 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 61 - Total Count: 298
dev:2732020-06-02 08:23:35.976 am debugIn sendFollowMeSpeaker - tbl Count: 173 - line Count: 64 - Total Count: 237
dev:2732020-06-02 08:23:35.974 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 61 - Total Count: 173
dev:2732020-06-02 08:23:35.965 am debugIn sendFollowMeSpeaker - sName: Living Room - sStatus: true
dev:2732020-06-02 08:23:33.249 am debug
dev:2732020-06-02 08:23:33.206 am debug
Kitchen | Active |
dev:2732020-06-02 08:23:33.227 am debugIn sendFollowMeSpeaker - tbl Count: 298 - line Count: 65 - Total Count: 363
dev:2732020-06-02 08:23:33.225 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 61 - Total Count: 298
dev:2732020-06-02 08:23:33.222 am debugIn sendFollowMeSpeaker - tbl Count: 173 - line Count: 64 - Total Count: 237
dev:2732020-06-02 08:23:33.204 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 65 - Total Count: 362
dev:2732020-06-02 08:23:33.199 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 61 - Total Count: 173
dev:2732020-06-02 08:23:33.180 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 60 - Total Count: 297
dev:2732020-06-02 08:23:33.166 am debugIn sendFollowMeSpeaker - tbl Count: 173 - line Count: 64 - Total Count: 237
dev:2732020-06-02 08:23:33.163 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 61 - Total Count: 173
dev:2732020-06-02 08:23:33.105 am debug
Bedroom | Active |
Dining Room | Speaking |
Kitchen | Active |
dev:2732020-06-02 08:23:33.111 am debugIn sendFollowMeSpeaker - sName: Living Room - sStatus: speaking
dev:2732020-06-02 08:23:33.111 am debugIn sendFollowMeSpeaker - sName: Kitchen - sStatus: speaking
dev:2732020-06-02 08:23:33.103 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 65 - Total Count: 362
dev:2732020-06-02 08:23:33.096 am debug
Kitchen | Active |
dev:2732020-06-02 08:23:33.100 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 60 - Total Count: 297
dev:2732020-06-02 08:23:33.097 am debugIn sendFollowMeSpeaker - tbl Count: 172 - line Count: 65 - Total Count: 237
dev:2732020-06-02 08:23:33.090 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 65 - Total Count: 362
dev:2732020-06-02 08:23:33.088 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 60 - Total Count: 297
dev:2732020-06-02 08:23:33.085 am debugIn sendFollowMeSpeaker - tbl Count: 173 - line Count: 64 - Total Count: 237
dev:2732020-06-02 08:23:33.083 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 61 - Total Count: 173
dev:2732020-06-02 08:23:33.079 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 60 - Total Count: 172
dev:2732020-06-02 08:23:33.062 am debugIn sendFollowMeSpeaker - sName: Bedroom - sStatus: speaking
dev:2732020-06-02 08:23:33.061 am debugIn sendFollowMeSpeaker - sName: Dining Room - sStatus: speaking
dev:2732020-06-02 08:23:32.662 am debugIn deviceNotification
dev:2732020-06-02 08:23:23.569 am debug
Bedroom | Active |
Kitchen | Active |
dev:2732020-06-02 08:23:23.548 am debugIn sendFollowMeSpeaker - tbl Count: 296 - line Count: 65 - Total Count: 361
dev:2732020-06-02 08:23:23.549 am debug
Bedroom | Active |
Kitchen | Active |
dev:2732020-06-02 08:23:23.544 am debugIn sendFollowMeSpeaker - tbl Count: 236 - line Count: 60 - Total Count: 296
dev:2732020-06-02 08:23:23.528 am debugIn sendFollowMeSpeaker - tbl Count: 172 - line Count: 64 - Total Count: 236
dev:2732020-06-02 08:23:23.526 am debug
Bedroom | Active |
dev:2732020-06-02 08:23:23.530 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 64 - Total Count: 361
dev:2732020-06-02 08:23:23.524 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 60 - Total Count: 172
dev:2732020-06-02 08:23:23.518 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 64 - Total Count: 361
dev:2732020-06-02 08:23:23.501 am debug
Kitchen | Active |
dev:2732020-06-02 08:23:23.515 am debugIn sendFollowMeSpeaker - tbl Count: 236 - line Count: 61 - Total Count: 297
dev:2732020-06-02 08:23:23.511 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 60 - Total Count: 297
dev:2732020-06-02 08:23:23.511 am debugIn sendFollowMeSpeaker - tbl Count: 172 - line Count: 64 - Total Count: 236
dev:2732020-06-02 08:23:23.448 am debugIn sendFollowMeSpeaker - tbl Count: 172 - line Count: 65 - Total Count: 237
dev:2732020-06-02 08:23:23.449 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 60 - Total Count: 172
dev:2732020-06-02 08:23:23.445 am debugIn sendFollowMeSpeaker - tbl Count: 297 - line Count: 64 - Total Count: 361
dev:2732020-06-02 08:23:23.444 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 60 - Total Count: 172
dev:2732020-06-02 08:23:23.441 am debugIn sendFollowMeSpeaker - tbl Count: 237 - line Count: 60 - Total Count: 297
dev:2732020-06-02 08:23:23.438 am debugIn sendFollowMeSpeaker - tbl Count: 173 - line Count: 64 - Total Count: 237
dev:2732020-06-02 08:23:23.438 am debugIn sendFollowMeSpeaker - sName: Dining Room - sStatus: speaking
dev:2732020-06-02 08:23:23.433 am debugIn sendFollowMeSpeaker - sName: Kitchen - sStatus: speaking
dev:2732020-06-02 08:23:23.431 am debugIn sendFollowMeSpeaker - sName: Living Room - sStatus: speaking
dev:2732020-06-02 08:23:23.414 am debugIn sendFollowMeSpeaker - tbl Count: 112 - line Count: 61 - Total Count: 173
dev:2732020-06-02 08:23:23.401 am debugIn sendFollowMeSpeaker - sName: Bedroom - sStatus: speaking
dev:2732020-06-02 08:23:22.970 am debugIn deviceNotification
Further to the above I had an existing rtule setup to send a notification through Echo Speaks when my daughter turns her TV on, I changed the rule to use the Follow Me Virtual Device instead of the direct echo speaks device. In the Follow me device setting it shows that it's speaking but nothing actually comes out of the speaker:
All the commands are hitting echo speaks with a null speech parameter:
Also I noticed the default speak switch in the child devices so I thought maybe that was it and turned them on in all child devices and tried it again but that didn't work
If I got into the Follow Me Virtual Device and type something into the text box and click speak it works fine, If I ficlk my virtual switch it says hello fine, it's just not running from the rules i've set.
I just tried it again from rule machine and it worked fine. Not sure what the issue was but the notification came through to the room we were in
Thanks for your help
The "Quiet Time" is not working in my situation
The volume is not changing in the quiet time
Or maybe I did something wrong
Anyone has that feature working?
hub settings:
driver:
child app
Soz another little bug, reset all data isnt clearing the speaker map, so if you change the name of a child app (or forget to set it to something meaningful) it dosnt purge the old name just adds another
Only have 4 child apps setup
I'll look into it
Just a note on this to others. Be careful if you use that toggle to create a virtual device from within a child app. Because IF you delete the original child app that created the devices....it then deletes the device. If you intend to create one device with many child apps. I suggest you go into devices and create a virtual devices and assign it the new follow me driver.
ask me how I know.
Yep, been there did that
