Is everyone getting tons of errors from Echo Speaks these days? I got the impression that you all were and they were harmless. But, I'm getting a lot of low memory errors so I'm looking at everything. Of note, Echo Speaks seems to work just fine. Examples in the past few minutes:
UGH! Yes, THAT'S WHAT I HAD RUNNING ON THAT OTHER RPi. I thought it wasn't doing anything. I shut it down a couple of weeks ago. Thanks @nh.schottfam! And @jtp10181 where's the patch to fix the playlist error? I'm getting those too.
It seems that the latest generation Echo Show 5 is being found as an unknown device. @tonesto7 can we get that device correctly added? Does anyone have this device working correctly?
I believe we were all under the impression, due to announcements from Heroku, that what previously was available for free, including the types of accounts that echo speaks relied on for cookie refresh, would require some monthly payment.
Maybe it’s possible to use Heroku in a way that stays below a threshold and avoids actually getting charged for usage?
I switched to a local cookie server last November when Heroku’s announced pricing changes went into effect, so I’m not sure.
Well, my Echo Speaks server is just gone. So I recreated it on a raspberry pi. I must be doing something wrong because while I did get a cookie this IP address shown below is WRONG. I don't even have a 10.x network at home. How do I set this to the correct IP address? I can't find that... The port is correct, but the IP is wrong. Should be 192.168.4.129 Thanks folks. Feel like an idiot here lately.
Guessing you deployed with docker? Docker uses its own internal bridge networking which messes with the IP detection. My guide shows how to override the IP detection and set it. [GUIDE] Echo Speaks Server on Docker (and alternates)
