Hi. I haven't been able to get big talker to work in HE.
Getting this error on the Sonos
2019-04-05 04:19:36.019 pm [error](http://10.0.1.45/device/edit/186)groovy.lang.MissingMethodException: No signature of method: sonosDriver.playTrackAndRestore() is applicable for argument types: (java.lang.String, java.lang.String, java.lang.Integer) values: [http://10.0.1.45/tts/d7db226e72cde5a18ed909bf1b4147c8.mp3, 6, ...] Possible solutions: playTrackAndRestore(java.lang.Object), playTrackAndRestore(java.lang.Object, java.lang.Object) (playTrackAndRestore)
I have music player selected in BT as the speech mode.
if I click on status in the BT app I get this error in the BT logs 2019-04-05 04:20:03.607 pm [error](http://10.0.1.45/installedapp/configure/256)java.lang.StringIndexOutOfBoundsException: String index out of range: 16 on line 3290 (pageStatus)
It sounds like the HE Sonos driver doesn't support the following call
playTrackAndRestore(uri, duration, volume)
Hubitat doesn't publish their drivers for public view so I can't look at it to see what playTrackAndRestore() supports, something I commonly did under the ST platform to learn how to handle various drivers and find commonalities.
There have been many questions about HE's playTrackAndRestore() function. I don't see a clear answer of the usage of it and the developer documentation doesn't list it.
We are shooting into the wind on this it seems. The HE implementation doesn't seem to match the same parameters that were supported under ST. This is one of the reasons I've pretty much gone silent. There's a lot of code in BT and not much guidance for what I've been custom to know as basic functions under the ST platform (until they changed their entire developer model). I've updated/streamlined a lot of the code in my unpublished version but I don't really have time to support it upon release or much desire given the lack of docs to follow to minimize issues so it's pretty stale right now.
NEW RELEASE - 4/6/2019
2.0.8.5 Parent and Child Apps
Use at your own risk! There have been a lot of changes since the last release, I'm sure I forgot to document some.
Cosmetic adjustments to the 'About' section of the start page, inclusion of app version status
Ability to change app mode from 'musicPlayer' to 'speechSynthesis' or vice versa. CAUTION: selected speech devices may need to be re-selected at the Configuration Defaults page as well as any overrides selected within each event
Modified 'Debug logging' switch to auto-disable after 30 minutes. If the switch is enabled, debug logging is enabled for up to 30 minutes. Visiting the Configuration Defaults page anytime during/after that extends the debug logging period unless the switch is toggled to off which ends debug logging immediately.
Weather code migration from WeatherUnderground ST/HE platform API to directly use Weather.gov API(US weather only) based on hub GPS lat/long location, supports %weatherxxxx% vars, where xxxx = current, today, tonight, tomorrow
Attempt to resolve issues with playTrackAndResume/playTrackAndRestore calls in Hubitat (particularly with Sonos devices; I don't have a Sonos, so I can't test it)
If you do not mind, please turn on debug logging in the Configure Defaults page (it will only stay active for 30 minutes, afterwhich for further debug logging, you'll need to toggle debug logging off and back on again).
Launch the logs in a new tab, then use TalkNow or cause an event to occur that should cause BigTalker to send speech through your Sonos.
I honestly do not know. It's on the list of supported capabilities so I added it. Any device that you have that supports that capability should show up under this event type.
Once I can get a solid Hubitat musicPlayer (Sonos, etc) implementation I plan to add a lot more of the supported capabilities. Much of the codebase has been modified to make adding these more streamlined.
If anyone else has a Sonos and wishes to also test a beta to resolve BigTalker/Sonos issues, please PM me.
(Actually if you have any musicPlayer device, I also need to make sure the Sonos adjustments to BigTalker didn't break other musicPlayer device functionality within BigTalker as well).
I'll test 2.0.8.5 with my Google Home Mini tonight when I get home as it's been working great for me.
In fact yesterday I implemented hourly announcements and it was shortly followed by my wife saying "do we really need to have timely reminders every hour now ??" he he
I'm using SpeechSynthesis via the Google Home Mini and I couldn't wait. I jumped in from work and updated both Parent and Child and it appears to be working.
If you experience issues, please go to the BigTalker parent app > Configure Defaults and toggle Debug Logging ON (if it's on, turn it off and back on), Open logs in another tab, produce the issue, copy/paste the logs and send to me in a PM.
Thanks for the PM'd logs. I'll check them out tonight and get back to you. Yes, weather has worked for me. It uses only Weather.gov data based on your hub location so it is US only at this time.
I found a huge bug in BigTalker2 that has existed since 2.0.0.
This bug would have prevented new event groups (child apps) from speaking for the configured events initially, until you went back into the event group and event type and made an edit/saved.
The bug is due to the child app missing a call for initialize() and thus subscribe() upon each initial install. It's called only when updated() is called.
This is resolved in the latest beta (among several other bugs found along the way) if anyone wants to try the beta and PM me feedback.
The Beta installs under a different user app name. It uses BigTalker2-Parent-DEV and BigTalker2-Child-DEV.
I am working on detecting available commands for configured speech devices as, specifically with musicPlayer, I'm finding that they do not all support the same commands or command structures. Once I have that implemented, I suspect speech will be more reliable with various speaker drivers.
If you run into a problem, please go into the parent app > Configure Defaults and toggle "Debug Logging" to On, if it's already on, it's only active for 30 minutes and simply going back into the Configure Defaults page will reactivate it for another 30 minutes (or until you toggle the switch off). Open logging, reproduce the issue and then PM me the logs.
