I had a feature request unless I missed this in the app. Is it possible to add the capability to pause a child app? I'm in the middle of migrating this to a new hub and I don't want to remove from my old hub until I've tested and comfortable with the performance on the new hub.
All Apps have a Disable option:
Click the grey X and make it red.
A Disable column appears.
Disable the App(s) you need.
Perfect. No matter how simple it is every day I learn something new in Hubitat.
Hi all, the apps works great, thanks @csteele! Just an FYI for anyone with the same use case. I just came across an anomaly,
I have a situation where I have 2 virtual switches being monitored in the same child. In one situation I am triggering them at the exact same time, the app would schedule 2 events but only 1 switch would turn off. After a little testing it looks like when both 'on' events happen simultaneously only 1 device gets auto off'd. I changed my rule to turn on switch #1, wait 1s, then turn on switch #2. In this case they both worked fine. Because they're virtual I believe that both will literally be set at exactly the same time causing the anomaly. Physical devices will never have this scenario so the issue probably has not been seen before.
Is it possible to eliminate all these debug messages in my log? As far as I know I have debug logging turned off in the app.
Turn debug on. Click Done.
Turn Debug Off. Click Done.
Go into the child App and click the gear at the top right. You should see this:
That did it - thanks.
New version released to correct this typo. HPM is updated also.
Thanks ill give it a go.
Hi - thanks for the work on this app. I installed it and everything was working except the master switch. When the master switch is OFF, the job activates and shows me the green status, but once its time for the lights to turn off it skips that. But when the master switch is ON the job is restricted '[-]' and does not activate.
I noticed in the code line 167 the if statement seems reversed, unless I am not understanding how the master switch is supposed to be used. I updated the if statement and replace on with off and everything seems to work correctly.
// Call off(), or on() if inverted, on all relevant devices and remove them from offList
if (!master || master.latestValue("switch") == "**on**") {
invert ? deviceList*.on() : deviceList*.off()
} else {
if (debugOutput) log.debug "Skipping actions because MasterSwitch '${master?.displayName}' is **Off**"
I seem to be getting an error while trying to add this driver... New to HE and Came from ST-- When we originally added drivers os i am privy to the process.
Are you adding this to apps code or driver code? This is an app, so should be added to apps code.
As a new HE user, I strongly suggest that you install HPM first, and then use that to install this app (along with lots of other useful community developed apps and drivers). Installing via HPM is simple and fast, and makes updating equally as easy.
