[RELEASE] Hubitat Package Manager (HPM) -- HubitatCommunity
A v1.9.3 version has been pushed to HubitatCommunity,
  • improved displayHeader to include the Main Menu Option selected
  • refactored delete app to use new endpoint
I've created a Video that shows the step by step on an Empty hub. I wiped one of my hubs and show the Installation of Hubitat Package Manager and then using it for the first and second time.
HPM Installation - First Time Users
In order to save some space, the video moves at a rapid pace. Use the browser's speed control OR the Pause button on the playback.
Follow the Hubitat Package Manager installation instructions here for step-by-step:
https://hubitatpackagemanager.hubitatcommunity.com/installing.html
OR, use this Import URL:
https://bit.ly/3VfykH9
OR, this:
https://raw.githubusercontent.com/HubitatCommunity/hubitatpackagemanager/main/apps/Package_Manager.groovy
Hubitat Package Manager evens the playing field for Community code, Apps and Drivers with Built-In apps and drivers. Built-In Apps get "installed" by clicking "Add Built-In App" button on the Apps page. Similarly there's an "Add User App" button, but it shows only the list of App code that has been loaded onto the hub. HPM simplifies the process of loading code onto your hub, making it easy to find after clicking "Add User App".
Drivers are selected in a drop down list as Type in each device info page. They are sorted into built-in and User. Like Apps code, if the code isn't loaded into the hub, it won't be found in the drop down list. HPM simplifies adding driver code onto the hub.
Original topic:
Documentation has been created at:
HubitatPackageManager Documentation
Screenshot 2023-12-09 at 3.21.45 PM
Just tried the upgrade and get error
Thx
I believe you but this is what I got when I did the upgrade from Dominic's 1.8.2 to 1.8.3:
app:795 2022-05-28 10:24:31.203 am debug Updates complete
app:795 2022-05-28 10:24:24.435 am info  Upgrading Hubitat Package Manager
app:795 2022-05-28 10:24:24.060 am info  Downloading Hubitat Package Manager
app:795 2022-05-28 10:24:23.711 am debug Performing update
app:795 2022-05-28 10:24:21.371 am debug prefPkgVerifyUpdates
app:795 2022-05-28 10:24:19.911 am debug Updates available
app:795 2022-05-28 10:24:15.378 am debug Updates available
app:795 2022-05-28 10:24:14.440 am debug Updates found package for https://raw.githubusercontent.com/dcmeglio/hubitat-packagemanager/master/packageManifest.json -> null (force production: true)
app:795 2022-05-28 10:24:14.437 am debug Updates found for package https://raw.githubusercontent.com/dcmeglio/hubitat-packagemanager/master/packageManifest.json
app:795 2022-05-28 10:24:14.357 am info  Checking for updates for Hubitat Package Manager
app:795 2022-05-28 10:24:13.334 am info  Checking for updates for Honeywell Thermo Parent
app:795 2022-05-28 10:24:13.206 am debug Update chosen
I'm going to delete, go back to DMeglio 1.8.2 and try again...
It proceeds w update, one more error and several manifest errors
Those are in fact, manifest errors that the app owners should fix. The updated Master Manifest on HubitatCommunity has a corrected entry for one that I found and fixed. The other will need to be corrected by the owner.
I was not able to reproduce the error. Again, no disbelief, just recognizing I must be clicking differently :smiley:
An obvious 2nd option to upgrading is just Repair. That copies the same (1.8.3) HPM from either repo. :slight_smile:
Repair seems to be clean
FWIW, I got the same error on both my hubs as @starcom.
However, the update was applied. Also, to be complete in the information I've provided, I updated from your version 1.8.2A to 1.8.3.
Ah... 1.8.3.A might be the culprit, I did that upgrade test last night and didn't see that error. I can try it again though :slight_smile:
If you're feeling unsure, give Repair a shot, just to get back to: sure.
Just retested and got no error but the repos aren't in the same states when I do a delete-reinstall. Your copy is already "running" with an old list of Manifests. When I delete and reinstall, there are no manifests and so it picks up the 1.8.3 set. So.. no error.
I think the One/Two Punch of an Upgrade and/or a Repair will cover most situations.
Updated, seemed to go fine.
Same here, two hubs and both had the error. As far as I could determine I was upgrading from 1.8.2, and not 1.8.2A.
Simply FYI I got a different error when updating. My production hub is a C-7, and it updated fine. My C-5 dev hub, when an update was attempted, hung on Installing updates. Doing a repair of HPM went fine and fixed things on the C-5:
Both running 2.3.1.142, both started the update with HPM 1.8.2 from Dominick Meglio’s repository, both now at 1.8.3.
I got the same error as starcom did a repair and all seems fine. C-5 hub coming from 1.82.
There's a pattern, but most errors have different line numbers. I have to think it's HPM updating itself while it's running... (method performUpdates) is common to all the messages.
I think the pattern of doing a Repair after is probably best.
Updated for me with out any errors at all on both hubs.
C7 hub here and it failed (hung forever). But a repair seemed to set things right. Of note I am a Beta tester currently running: 2.3.2.118. I only share that for troubleshooting purposes not to disclose any Beta details...
Same. C7. HPM showed there was an update (for HPM), I've ran it and it's just stuck on the below screen for 10 minutes now:
If you see the
It won’t finish, just go to repair at that point.
My hub update also froze, but seems like the update was completed and now runung 1.8.3.
Error Log
app:32022-05-29 13:52:18.522 debugInstalling HPM Manifest
app:32022-05-29 13:52:18.217 debugGrabbing list of installed apps
app:32022-05-29 13:52:17.904 infoA new repository was added, https://raw.githubusercontent.com/GaryMilne/Hubitat-Tasmota/main/repository.json
app:32022-05-29 13:52:17.899 infoA new repository was added, https://raw.githubusercontent.com/danTapps/Hubitat/master/repository.json
app:32022-05-29 13:52:17.893 infoA new repository was added, https://raw.githubusercontent.com/Vyrolan/iAqualink-Hubitat/main/repository.json
app:32022-05-29 13:52:17.889 infoA new repository was added, https://raw.githubusercontent.com/dlaporte/Hubitat/main/ASH26/packageManifest.json
app:32022-05-29 13:52:17.878 infoA new repository was added, https://raw.githubusercontent.com/sky-nie/hubitat/main/repository.json
app:32022-05-29 13:52:17.457 debugRefreshing repository list
app:32022-05-29 13:44:07.149 errorjava.lang.NoClassDefFoundError: user_app_dcm_hpm_Hubitat_Package_Manager_99$_copyInstalledItemsToNewManifest_closure86 on line 3572 (method performUpdates)
app:32022-05-29 13:43:43.718 infoUpgrading Hubitat Package Manager
app:32022-05-29 13:43:43.273 infoDownloading Hubitat Package Manager
app:32022-05-29 13:43:42.593 debugPerforming update
app:32022-05-29 13:43:36.720 debugprefPkgVerifyUpdates
app:32022-05-29 13:43:34.998 debugUpdates available
app:32022-05-29 13:43:30.907 debugUpdates available
app:32022-05-29 13:43:12.396 debugUpdates available
My main hub HPM went smoothly:
Updates complete
The updates have been installed, click Done to continue.
Great work with transferring the HPM to HubitatCommunity repository @csteele , thank you very much!
Yeah I've done that - all up and running again now - thanks.
