Summary
dev:64092023-03-02 07:04:52.023 AMdebugAcccccccc (0x06B) unknown parameter, value: 3
dev:64092023-03-02 07:04:52.022 AMdebugAcccccccc (0x6A) unknown parameter, value: 1
dev:64092023-03-02 07:04:52.020 AMinfoAcccccccc approach_distance is medium (1)
dev:64092023-03-02 07:04:52.014 AMdebugAcccccccc unknown tag=68 dataType 0x20 rawValue=0
dev:64092023-03-02 07:04:52.008 AMinfoAcccccccc monitoring_mode is undirected (0 )
dev:64092023-03-02 07:04:52.006 AMinfoAcccccccc (tag 0x66) sensitivity is high (3)
dev:64092023-03-02 07:04:51.996 AMinfoAcccccccc Motion is active 47548s
dev:64092023-03-02 07:04:51.995 AMinfoAcccccccc presence is present
dev:64092023-03-02 07:04:51.992 AMinfoAcccccccc (0x65) presence is present (1)
dev:64092023-03-02 07:04:51.991 AMdebugAcccccccc unknown tag=12 dataType 0x20 rawValue=0
dev:64092023-03-02 07:04:51.990 AMdebugAcccccccc unknown tag=10 dataType 0x20 rawValue=1
dev:64092023-03-02 07:04:51.988 AMdebugAcccccccc unknown tag=0C dataType 0x20 rawValue=20
dev:64092023-03-02 07:04:51.987 AMdebugParent NWK is 03C5
dev:64092023-03-02 07:04:51.986 AMdebugAcccccccc unknown tag=08 dataType 0x21 rawValue=310
dev:64092023-03-02 07:04:51.985 AMdebugRSSI is 5 ? db
dev:64092023-03-02 07:04:51.984 AMdebugdecodeAqaraStruct len = 92 valueHex = 2D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003
dev:64092023-03-02 07:04:51.980 AMdebugAcccccccc parse: Desc Map: [raw:E26401FCC062F700412D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, dni:E264, endpoint:01, cluster:FCC0, size:62, attrId:00F7, encoding:41, command:0A, value:03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, clusterInt:64704, attrInt:247]
dev:64092023-03-02 07:04:51.973 AMdebugAcccccccc parse: description is read attr - raw: E26401FCC062F700412D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, dni: E264, endpoint: 01, cluster: FCC0, size: 62, attrId: 00F7, encoding: 41, command: 0A, value: 2D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003
dev:64092023-03-02 06:59:44.857 AMdebugAcccccccc (0x06B) unknown parameter, value: 3
dev:64092023-03-02 06:59:44.856 AMdebugAcccccccc (0x6A) unknown parameter, value: 1
dev:64092023-03-02 06:59:44.854 AMinfoAcccccccc approach_distance is medium (1)
dev:64092023-03-02 06:59:44.849 AMdebugAcccccccc unknown tag=68 dataType 0x20 rawValue=0
dev:64092023-03-02 06:59:44.844 AMinfoAcccccccc monitoring_mode is undirected (0 )
dev:64092023-03-02 06:59:44.810 AMinfoAcccccccc (tag 0x66) sensitivity is high (3)
dev:64092023-03-02 06:59:44.802 AMinfoAcccccccc Motion is active 47241s
dev:64092023-03-02 06:59:44.800 AMinfoAcccccccc presence is present
dev:64092023-03-02 06:59:44.798 AMinfoAcccccccc (0x65) presence is present (1)
dev:64092023-03-02 06:59:44.797 AMdebugAcccccccc unknown tag=12 dataType 0x20 rawValue=0
dev:64092023-03-02 06:59:44.796 AMdebugAcccccccc unknown tag=10 dataType 0x20 rawValue=1
dev:64092023-03-02 06:59:44.794 AMdebugAcccccccc unknown tag=0C dataType 0x20 rawValue=20
dev:64092023-03-02 06:59:44.793 AMdebugParent NWK is 03C5
dev:64092023-03-02 06:59:44.792 AMdebugAcccccccc unknown tag=08 dataType 0x21 rawValue=310
dev:64092023-03-02 06:59:44.791 AMdebugRSSI is 5 ? db
dev:64092023-03-02 06:59:44.790 AMdebugdecodeAqaraStruct len = 92 valueHex = 2D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003
dev:64092023-03-02 06:59:44.787 AMdebugAcccccccc parse: Desc Map: [raw:E26401FCC062F700412D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, dni:E264, endpoint:01, cluster:FCC0, size:62, attrId:00F7, encoding:41, command:0A, value:03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, clusterInt:64704, attrInt:247]
dev:64092023-03-02 06:59:44.779 AMdebugAcccccccc parse: description is read attr - raw: E26401FCC062F700412D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, dni: E264, endpoint: 01, cluster: FCC0, size: 62, attrId: 00F7, encoding: 41, command: 0A, value: 2D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003
dev:64092023-03-02 06:54:26.579 AMdebugAcccccccc (0x06B) unknown parameter, value: 3
dev:64092023-03-02 06:54:26.577 AMdebugAcccccccc (0x6A) unknown parameter, value: 1
dev:64092023-03-02 06:54:26.576 AMinfoAcccccccc approach_distance is medium (1)
dev:64092023-03-02 06:54:26.571 AMdebugAcccccccc unknown tag=68 dataType 0x20 rawValue=0
dev:64092023-03-02 06:54:26.565 AMinfoAcccccccc monitoring_mode is undirected (0 )
dev:64092023-03-02 06:54:26.564 AMinfoAcccccccc (tag 0x66) sensitivity is high (3)
dev:64092023-03-02 06:54:26.554 AMinfoAcccccccc Motion is active 46923s
dev:64092023-03-02 06:54:26.552 AMinfoAcccccccc presence is present
dev:64092023-03-02 06:54:26.550 AMinfoAcccccccc (0x65) presence is present (1)
dev:64092023-03-02 06:54:26.549 AMdebugAcccccccc unknown tag=12 dataType 0x20 rawValue=0
dev:64092023-03-02 06:54:26.547 AMdebugAcccccccc unknown tag=10 dataType 0x20 rawValue=1
dev:64092023-03-02 06:54:26.546 AMdebugAcccccccc unknown tag=0C dataType 0x20 rawValue=20
dev:64092023-03-02 06:54:26.545 AMdebugParent NWK is 03C5
dev:64092023-03-02 06:54:26.544 AMdebugAcccccccc unknown tag=08 dataType 0x21 rawValue=310
dev:64092023-03-02 06:54:26.543 AMdebugRSSI is 5 ? db
dev:64092023-03-02 06:54:26.541 AMdebugdecodeAqaraStruct len = 92 valueHex = 2D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003
dev:64092023-03-02 06:54:26.538 AMdebugAcccccccc parse: Desc Map: [raw:E26401FCC062F700412D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, dni:E264, endpoint:01, cluster:FCC0, size:62, attrId:00F7, encoding:41, command:0A, value:03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, clusterInt:64704, attrInt:247]
dev:64092023-03-02 06:54:26.532 AMdebugAcccccccc parse: description is read attr - raw: E26401FCC062F700412D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, dni: E264, endpoint: 01, cluster: FCC0, size: 62, attrId: 00F7, encoding: 41, command: 0A, value: 2D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003
dev:64092023-03-02 06:52:24.200 AMdebugAcccccccc pollPresence()
dev:64092023-03-02 06:49:09.339 AMdebugAcccccccc (0x06B) unknown parameter, value: 3
dev:64092023-03-02 06:49:09.338 AMdebugAcccccccc (0x6A) unknown parameter, value: 1
dev:64092023-03-02 06:49:09.336 AMinfoAcccccccc approach_distance is medium (1)
dev:64092023-03-02 06:49:09.331 AMdebugAcccccccc unknown tag=68 dataType 0x20 rawValue=0
dev:64092023-03-02 06:49:09.326 AMinfoAcccccccc monitoring_mode is undirected (0 )
dev:64092023-03-02 06:49:09.324 AMinfoAcccccccc (tag 0x66) sensitivity is high (3)
dev:64092023-03-02 06:49:09.312 AMinfoAcccccccc Motion is active 46605s
dev:64092023-03-02 06:49:09.310 AMinfoAcccccccc presence is present
dev:64092023-03-02 06:49:09.308 AMinfoAcccccccc (0x65) presence is present (1)
dev:64092023-03-02 06:49:09.307 AMdebugAcccccccc unknown tag=12 dataType 0x20 rawValue=0
dev:64092023-03-02 06:49:09.306 AMdebugAcccccccc unknown tag=10 dataType 0x20 rawValue=1
dev:64092023-03-02 06:49:09.305 AMdebugAcccccccc unknown tag=0C dataType 0x20 rawValue=20
dev:64092023-03-02 06:49:09.303 AMdebugParent NWK is 03C5
dev:64092023-03-02 06:49:09.302 AMdebugAcccccccc unknown tag=08 dataType 0x21 rawValue=310
dev:64092023-03-02 06:49:09.301 AMdebugRSSI is 5 ? db
dev:64092023-03-02 06:49:09.300 AMdebugdecodeAqaraStruct len = 92 valueHex = 2D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003
dev:64092023-03-02 06:49:09.296 AMdebugAcccccccc parse: Desc Map: [raw:E26401FCC062F700412D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, dni:E264, endpoint:01, cluster:FCC0, size:62, attrId:00F7, encoding:41, command:0A, value:03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, clusterInt:64704, attrInt:247]
dev:64092023-03-02 06:49:09.291 AMdebugAcccccccc parse: description is read attr - raw: E26401FCC062F700412D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003, dni: E264, endpoint: 01, cluster: FCC0, size: 62, attrId: 00F7, encoding: 41, command: 0A, value: 2D03281805210500082136010A21C5030C20141020011220006520016620036720006820006920016A20016B2003
