I’m not sure I understand what you are describing here
anytime
Ok.. I’ll test this to see what’s going on here
I do have duplicate event filtering.. But almost positive I didn’t enable this for buttons because of this very reason.. But I’ll test to find out what’s going on here:.
I am including all the logs. I am still seeing inconsistent behavior.
notes
errors in the logs occurred when i attempted to add an action for button 1 to press button 3. it didn't like that.
I didn't have debug logs enabled initially, and when i did attempt to enable them i first had to put #s in the auto timer fields instead of the default zero values to save.
I then changed the Association reporting and enabled Report Type Disabled Physical by mistake. Now even though i disabled it, the switch is not disabling the physical buttons, and of course now it works because the problem only occurs when they are disabled.
Just for debug purposes.
Since I was not able to press the same button twice, I had a thought of having one button press changing a light and then hitting another button that didn’t have any action assigned to it. Just playing. But it still should have been possible.
For instance if I wanted button 3 to do something and button 1 to do something first and then to run the actions assigned to button 3.
