Release 2.5.2.126 Available
Changes from 2.5.1.183
Platform Updates
- Added full local backup support and updated the subscriptions page.
- ZWave-JS update to 15.29.0 from 15.26.0 (read more)
- ZWave-JS Server update to 3.10.1 from 3.10.0
- ZWave-JS available now to C-5 C-7 and C-8 hubs (read more).
- Z-Wave UserCode command class (v2)
- Z-Wave UserCredential command class (v1/v2)
- Z-Wave FirmwareUpdateMD command class (v7/v8)
- Z-Wave Indicator command class (v4)
- Z-Wave Association command class (v4)
- Z-Wave Multi Channel Association command class (v5)
- Z-Wave Firmware Updater (batch mode for ZWave-JS) (read more)
- Z-Wave local backup/restore/import (read more)
- New ZWave-JS re-interview migration progress UI.
- Z-Wave backups now validate critical keys before marking as good.
- Matter firmware updates are now supported using the drivers updateFirmware command, obviously this presumes the manufacturer has any updates available.
- New interactive guided SmartStart in the web UI. (read more)
- Z-Wave SmartStart now uses location to assign the device to a room.
- Z-Wave Details CSV export.
- Z-Wave Firmware Updater device search.
- Z-Wave Firmware Updater better sleepy device messaging.
- Tweaked EZ dashboards to load faster.
- Revamped onboarding screens.
- Added a separate Echo device Bluetooth pairing mechanism.
- Hardened Bluetooth speaker integration.
- Hardened cloud and full local backup; added more failure details when appropriate.
- Blocked Z-Wave device firmware update over remote admin due to timeouts.
- Added API documentation to the Developers menu section.
- Added download database and file manager archive options to the cloud backups.
New Devices
- Generic Z-Wave Lock DT driver (utilizing UserCode V2 and newer UserCredential)
- Zooz ZSE43 800LR Tilt Shock XS Sensor
- Added RadioRA 3, keypad, fan, and shades support to Lutron LEAP integration
New Integrations
- Sonos Integrator, the existing Sonos Integration is depreciated in this release. (Read More).
- Added Reolink integration - big thanks to @JdThomas24!
Driver Changes
- Added updateFirmware command to all inbuilt Matter drivers (excluding bridge devices)
- AVR drivers sourceInput UI element now contains the list of supportedInputs
App Changes
- Added curl/bearer token examples to MakerAPI. Same bearer token authentication is available to all apps.
- Added hub mode support to the Alexa skill.
- Updated Reolink integration to v1.6.3.
- Added Zigbee quality reporting to MakerAPI.
- STR Code Manager, added booking groupings by year and month.
Bug Fixes
- Various fixes for matter certification, mostly related to BLE commissioning handoffs.
- Added CSA's vendor ID for Hubitat, as well as a matter fabric alias, connected services as seen from other matter controllers will now show Hubitat, Inc as well as the source Hubs name. Note: These values will only show for newly added devices.
- Matter attestation now uses CSA's DCL (online database) for device attestation, this should fix issues where devices have failed commissioning at the attestation phase.
- Got rid of the repeated Amazon Echo skill errors.
- Fixed blank cron expression builder page.
- Fixed Z-Wave restoring 7.19+ firmware on a hub with 7.18 firmware.
- Fixed matter OTA logging.
- Fixed ZWave-JS interview pending failed node removal.
- Fixed ZWave-JS node list not updating after node removal.
- Fixed Zooz ZSE41 potential incorrect state after wakeup.
- Fixed ZWave-JS Notification CC Access Control possible missed reports.
- Fixed a bug in Generic Z-Wave Lock driver when configure hasn't been run.
- ZWave-JS patch for NVM change between 7.18 and 7.19 causing some backups to fail.
- ZWave-JS fix for Protection CC error.
- ZWave-JS fix for backups when firmware version is not yet known.
- Likely fixed garage door "not responding" error in Alexa when command successful (and minor other fixes).
- Likely fixed the issue of ChromeCast stop() command bringing up the app screen.
- Fixed BeSense Motion Sensor driver duplicate events.
- Fixed ZWave-JS possible false Notification reports during driver WakeUp.
- Fixed a ZWave-JS bug affecting Notification Light Sensor reports.
- Fixed the issue with sending premature connection established notification to the drivers using the MQTT interface.
- Added
boolean connectToBuiltInBroker(String clientId)to the MQTT interface. - STR Code Manager, fixed canceled bookings not being removed.
