New: Local Z-Wave Backup, Restore, and Import
We’re introducing a new Local Z-Wave Backup and Restore tool for Backup Plus and Hub Protect subscribers.
This provides direct control over your Z-Wave radio backup without requiring a cloud backup. A local backup includes the radio NVM, security keys, and available Z-Wave JS node-cache information.
What it can do
- Create and download a local Z-Wave backup.
- Restore a backup previously created by Hubitat.
- Import backups created by Z-Wave JS UI on another platform.
- Inspect and import a compatible raw Z-Wave NVM backup.
- Preview the detected Home ID, protocol version, node count, node IDs, security-key status, and cache information before restoring.
- Automatically discover imported nodes and create matching Hubitat devices when possible.
This means a Z-Wave network can be migrated from another Z-Wave JS controller without excluding and re-including every device.
Security keys
Z-Wave JS backups normally include the security configuration needed to communicate with encrypted devices.
When importing a raw NVM image from another platform, the tool will detect whether security keys are missing and request them before allowing the restore. Without the original keys, securely included devices cannot be recovered.
Z-Wave stack compatibility
The restore process identifies whether a backup came from Z-Wave JS or ZIP Gateway. If the backup uses a different Z-Wave stack than the hub currently has enabled, the restore is blocked and you’ll be prompted to switch stacks first.
This prevents accidentally restoring a backup into an incompatible running environment.
Important notes
- Restoring replaces the Z-Wave network currently stored on the hub’s radio.
- Do not reboot or power off the hub while a restore is running.
- A Z-Wave backup contains radio/network information—it is not a replacement for a complete hub database backup.
- Keep local backup files secure because they may contain your Z-Wave security keys.
- The feature requires an active Backup Plus or Hub Protect subscription.
You’ll find the new tool under:
Settings → Z-Wave Details → Backup and Restore
