ZWave-JS Update to 15.29.0
ZWave-JS Updated to 15.29.0
Changes from 15.26.0
Features
  • Redundant and superseded commands are now automatically deduplicated. The corresponding API calls can now be aborted or will share a single transaction, depending on the specific situation (#9136, #9137)
  • The new lastAwake property now indicates when a node was last awake. This information is persisted across restarts (#9173)
  • Some "invalid payload" warning logs now include the node ID (#9196)
  • Significantly improved capabilities of the experimental RCP firmware driver (#9076, #9077, #9078, #9080, #9081, #9083, #9087, #9088, #9090)
  • Read bootloader version from Nabu Casa controllers during the interview (#9095)
  • When querying the firmware update service, additional chips' firmware versions are also passed (#9110)
  • Zniffer can now parse PTI captures from Z-Wave CTT (#9148)
  • The Manufacturer Specific Device Specific Get command is now answered correctly. If desired, you can pass a device ID in the driver options, which will be used in the response (#9151)
Bugfixes
  • Notification Reports with event 0xfe in response to a Get now idle the corresponding notification variables (#9160, #9174)
  • Fixed an issue where regular RSSI measurements could interfere with automatic polling (wakeup compat queries, Hail, etc.) if the commands were slow (#9183)
  • When destroying the driver instance, abort Serial API commands that are waiting for an ACK (#9099)
  • Do not retry commands when destroying the driver instance (#9100)
  • The listening flag in the SerialAPIStarted command is now parsed correctly (#9102)
  • The controller NIF is now set on every startup, preventing controllers from incorrectly behaving like a sleeping node (#9105)
  • Prevent the OTW firmware update from aborting itself when entering the bootloader (#9108)
  • Fixed a bug where Driver.ready was not reset when entering bootloader or CLI mode (#9109)
  • Fixed an issue on Windows where SONOFF controllers could end up in the bootloader during Z-Wave JS's startup (#9118)
  • Correct signal-to-noise margin units from dBm to dB (#9131)
  • Association Group Information command list reports now serialize without trailing bytes (#9146)
  • Fixed an issue where nodes that were excluded by an inclusion controller would not be removed from Z-Wave JS's node list (#9149)
  • Fixed a regression where the S0 Commands Supported Get command was not answered on S2-capable nodes (#9150)
  • Fix: parsing a Door Lock CC Configuration Report could crash due to an incorrect length check (#9155)
  • Parsed CommandClass instances now preserve the frame type (singlecast/multicast/broadcast) of the incoming command (#9147)
  • Ignore report fields that are only valid on higher CC versions than the node advertised support for (#9154)
  • Limit Z-Wave.me proprietary GetRegion command to firmware 5.3+ (#9093)
  • Updated a few instances where env variables were read directly instead of through getenv (#9015)
  • Keep the DRBG key and counter in separate buffers (#9014)
  • Fixed an issue where zero-valued enums were not deserialized from the network cache correctly (#9013)
  • Fixed a race condition where the driver could attempt to persist CC values after the value DB was closed (#9038)
  • Supervised Notification Reports with unparsable event parameters are now answered with supervision status Fail instead of being silently dropped (#9049)
  • Proceed with User Code CC interview when User Credential CC capabilities are unknown (#9068)
Config file changes
  • Add Aeotec ZWA056 Water Sensor 8 (#9161)
  • Restrict ZWA055 Basic Set values to the legal value set, correct template key (#9208)
  • Add Aeotec ZWA065 Siren 8 (#9207)
  • Add Aeotec ZWA057 aërQ Temperature and Humidity Sensor 8 (#9206)
  • Add Aeotec ZWA055 Door / Window Sensor 8 (#9089)
  • Update Inovelli VZW32-SN P50, P107 for firmware 2.4 (#9187)
  • Add Zooz ZEN12 800LR Motion Dimmer (#9181)
  • Add Zooz ZEN37 parameter 10 for firmware 2.40 (#9180)
  • Add "Off" option for Heatit Z-TRM7 standby display brightness (#9177)
  • Update Zooz configs for new firmware parameters (#9175)
  • Add Simon 100 Battery Master Roller Blind (#9158)
  • Update Inovelli VZW32-SN P111 to match public docs (#9116)
  • Fix malformed notifications sent by HomeSeer FS100 devices (#9140)
  • Add labels to several endpoints, add tools to discover them (#9096)
  • Correct external sensor resistance options on Heatit Z-TRM7 (#9129)
  • Add fingerprint 0x0c02:0x3002 to "Fibargroup FGSD-002" (#9114)
  • Update Zooz ZEN32 config for firmware 3.30 (#9097)
  • Add fingerprint to Climax SDCO (#9075)
  • Add Heatit Z-TRM7 and standardize Heatit config parameters across devices (#8995, #8997)
  • Add productId 0x5600 for YRM276 with ZW3 module (700 series) (#9002)
  • Remove Multi Channel CC support for Vero Duco CO2 sensor (#9036)
  • Update manual URL for Lamp-ZW2 (#9070)
Changes under the hood
  • Switched the formatter from dprint to oxfmt (#8596, #9191, #9197, #9202)
  • Migrate syntax-only custom rules to Oxlint (#9203)
  • Fix flaky Transport Service SegmentComplete test (#9023)
