Release 2.5.1.138 Available
Changes from 2.5.0.159
Platform Changes
- Added model context protocol (local AI) integration with a companion AI Connector Integration app.
- Rewrote Tuya local integration with more features, device types, and better device detection; added cloud Tuya support.
- Added network status and IP address attributes to Matter devices.
- Added local RTSP streaming support and a complementary RTSP Camera Stream device driver (use it in EZ dashboards). Includes ONVIF and Unifi device discovery.
- Z-Wave Node State now has command control for doing things that drivers don’t support.
- Redesigned Z-Wave SmartStart web UI, including QR scanning.
- Added Matter web UI QR scanning for WiFi commissioning.
- Replaced devices section of the Home page with EZ dashboard like interface to directly control the devices.
- Added live device status updates to Rooms and Devices.
- Improved EZ dashboard loading and initialization times.
- Added manual setup code handling for Matter WiFi commissioning.
- Updated ZWave-JS (see more)
- ZWave-JS Server Schema Update.
- ZWave-JS Device Firmware Database (see more).
- ZWave-JS Link Reliability Test (see more).
- ZWave-JS Version is now displayed in Z-Wave Details.
- Redesigned Hub Mesh page to be more user friendly.
- Updated Python process dependencies.
- Implemented matter Invoke callback for new parse drivers.
- Added optional isUrgent parameter for matter event subscriptions.
- Updated Zigbee graph to show all nodes right away and fill it once more info becomes available.
- Added a direct LED control endpoint at /hub/debug/setLEDs?red=true&green=true&blue=true. Replace true with false as needed.
- Added logging and a response delay for failed UI logins.
New Apps
- Lutron LEAP integration (experimental), available under existing Lutron Integrator integration. Currently aupports Pico remotes, dimmers, switches, and occupancy/vacancy sensors only and Caséta only
- Added Visual Rule Builder 2.0 (beta).
New Drivers
- Aqara Matter Dimmer Switch H2 EU
- Third Reality Smart Button ZB2 (3RSB01085Z)
- Somfy Inteo V3 compatible window shades/blinds.
- Eve Energy (including vendor specific energy monitoring)
- Govee Matter RGBW Light (mode select light effects support)
New Driver Features
- Eve Weather support pressure measurement from vendor specific cluster.
New Compatible devices
- Sonoff Mini Dim using Generic Matter Dimmer
- Lutron LEAP devices.
- ThirdReality Matter Smart Timer Light TL2
- Aqara Smart Lock U400
Bug Fixes
- Added missing initialize method to Generic Matter Multi-Endpoint Switch.
- Fixed Zigbee pairing info dialog.
- Fixed dashboard token related memory leak.
- Fix for Kwikset missing report on lock events from the keypad.
- Ring websocket health probes, stale-session detection, and safe reconnects.
- Ring uninstall now removes native Ring devices and persisted login state.
- Ring Beams/solar lights now expose SwitchLevel and setLevel.
- Fixed matter device initialization possibly missing some devices when hub is rebooted.
- Fixed out of order event processing for event subscriptions.
Release 2.5.1.139 Available
Changes from 2.5.1.138
Bug Fixes
- Fixed failing Matter update.
Release 2.5.1.140 Available
Changes from 2.5.1.139
Bug Fixes
- Fixed PIN login on legacy dashboards.
- Fixed missing logout button on the UI security enabled hubs.
Release 2.5.1.142 Available
Changes from 2.5.1.140
Bug Fixes
- Hardened JRE update, scheduler cleanup, and out of memory reboot logic.
- Hopefully fixed summary section flickering on the front page.
- Tweaked unsupported device tiles appearance for home page.
- Fixed Zwave-JS startup after update.
Release 2.5.1.143 Available
Changes from 2.5.1.142
Platform Changes
- ZWave-JS update to 15.26.0 (see more)
- Added parent/child device support to the direct device control page/EZ dashboards.
- Switched mobile app's devices tab to use the same device control UI as the hub's home page.
Bug Fixes
- ZWave-JS patch for WindowCovering devices.
- Z-Wave backup validate byte size of NVM binary when evaluating a failure.
- Fixed a small HTTP client regression.
- Fixed occupancy sensor display issue on device control page/EZ Dashboards.
Release 2.5.1.147 Available
Changes from 2.5.1.143
Platform Changes
- Improved loading time for EZ dashboards.
- Added a inactivity pause for cloud only legacy dashboards.
- Improvements to ZWave-JS JAMMED reporting. Including new backend logging for troubleshooting.
- Cleaned up Z-Wave restart after cloud backup.
- Added RGB/CT status support to default EZ dashboard tiles.
- Implemented value rounding and more consistent backgrounds for EZ dashboard.
- MCP/AI integration now supports Visual Rule Builder 2.
- Replaced device and room tile views with dashboard based views.
- Added standalone battery and voltmeter support to EZ dashboard.
New Apps
- Added measurements aggregator app for temperature, humidity, illuminance, and voltage.
App Changes
- Visual Rule Builder 2:
- Added thermostat mode condition.
- Added new rule dialog with AI options.
- Added alarm trigger and action support.
New Devices
- Philips Smart Button (RDM005)
- Third Reality Air Quality Sensor
- Third Reality Pressure Sensor
New Compatible Devices
- Honeywell X2S Smart Thermostat using Generic Matter Thermostat driver
Driver Changes
- Added syncClockTime command for Ikea Alpstuga Matter Air Quality Sensor.
Bug Fixes
- Zooz Zen12 fixed motion idle reporting.
- Expanded the list of media player devices for EZ dashboard.
- Added Zooz Zen12 missing parameter 17 "Motion Clear Delay".
- Fixed battery level on Generic Zigbee Moisture Sensor (no temp) for Third Reality (3RWS0218Z).
Release 2.5.1.152 Available
Changes from 2.5.1.147
Platform Changes
- Added a way to group child apps under the same parent app.
- Tweaked new (beta) ChromeCast integration to better report device status.
- Tweaked integrated mode manager to better explain the Away mode and show its trigger and exit rules on the main page.
App Changes
- WebCore updated to the latest community version.
- Added an option for OR conditions to Visual Rule Builder 2.
Bug Fixes
- Consolidated live and past logs time zone handling.
- Fixed an issue where dashboard links opened in the browser instead of the mobile app. It may take up to 24 hours for the old cached dashboard screen to reflect the change.
Release 2.5.1.172 Available
Changes from 2.5.1.152
Platform Changes
- Added Bluetooth speaker support (C8 pro only)
- Tweaked app grouping dialog, added app group selection on the app page.
- Increased cloud dashboards timeout to 5 minutes.
Bug Fixes
- Tweaked Tuya local RGBW bulb handling.
- Fixed Export/Import/Clone utility to redirect to the right page (app/integration/automation) and highlight the imported/restored/cloned app.
- Fixed hub WiFi onboarding over Bluetooth (from mobile app).
- Re-enabled legacy TLS that are disabled by default in JRE 11.0.31.
- Fixed an mDNS related memory leak.
- Fixed an issue with Alexa dimmer discovery and reporting.
Release 2.5.1.174 Available
Changes from 2.5.1.172
Platform Changes
- Added a new device details Assistants tab to directly assign a device to Amazon Alexa, Apple Home, or Google Home.
Bug Fixes
- Fixed Alexa fan control issue introduced in 2.5.1.172.
Release 2.5.1.180 Available
Changes from 2.5.1.174
App Changes
- Added CT prestaging support to adaptive lighting app (requires
presetColorTemperature command in device driver).
- Hardened Amazon Alexa Echo skill to hopefully avoid INVALID_REQUEST_EXCEPTION.
- Added device network id and Zigbee id to the Maker API device endpoints.
- Added an endpoint to get the device network id and Zigbee id from Bulk hub setup utility.
Bug Fixes
- Likely fixed the "Private Boolean Not Available For Condition in an Action" issue in RM 5.1.
- Fixed missing thermostatSetpoint on HomeKit thermostat drivers.
- Added logic to auto reconnect some stale Bluetooth speaker sessions.
- Fixed Alexa status errors for garage door opening/closing status.
- Fixed broken cron expression link in the Rule Machine.
Release 2.5.1.181 Available
Changes from 2.5.1.180
Bug Fixes
- Likely fixed the occasional high CPU use issue reported in .174-.180.
Release 2.5.1.182 Available
Changes from 2.5.1.181
Bug Fixes
- Fixed StackOverflowError for the C4 hubs (manifested with event streams and possibly elsewhere).
Release 2.5.1.183 Available
Changes from 2.5.1.182
Bug Fixes
- Fixed failing Visual Rule Builder AI requests.
