ZWave-JS Device Firmware Database
New: Z-Wave Firmware Database Integration
We’ve added automatic firmware discovery to the Device Firmware Updater for hubs running Z-Wave JS.
Instead of manually locating and uploading firmware files, you can now select a Z-Wave device and choose Check for updates. Hubitat will query the Z-Wave JS firmware database for compatible manufacturer-provided firmware.
When an update is available, the updater displays:
  • Available firmware version
  • Stable release channel
  • Release notes
  • Firmware target information
  • Region information, when applicable
  • A warning if the selected firmware is a downgrade
The firmware is downloaded from the manufacturer-provided source, verified for integrity, and installed through Z-Wave JS.
How to use it
  1. Open Settings → Z-Wave Details.
  2. Select Device firmware updater.
  3. Select a Z-Wave device.
  4. Click Check for updates.
  5. Review and select an available update.
  6. Click Install discovered update.
The existing manual firmware upload option remains available.
Important: Firmware database integration is available only when the hub is running Z-Wave JS. Devices are included only when compatible firmware has been submitted to the Z-Wave JS database, so updates may not be available for every device.
As always, avoid powering off the hub or device while an update is in progress.
