See what happens when I look away? Somebody answered the question!
And yes, I believe most smart plugs max at 10 amps.
EDIT:
So long story short, in my installation anyway, I do not have a bulb bridge, but am running my Sylvania Smart+ bulbs directly. I know not optimal, but it is what it is...
I have a grand total of 7 Iris V3 smart plugs, 1 GE / Jasco smart plug with power reporting, and 10 currently unused Ikea Tradfri Wireless Control Outlets, A.K.A. Zigbee smart plugs.
The Iris Smart plugs are set up to control bedside lamps in the bedrooms. The home Office has a desk lamp hooked up to it, and the kitchen, well it is just sitting there as a repeater. I can, and do put holiday lights inside the window that I can control with this one.
I had originally thought to replace all the Trafri outlets, but they are very useful for controlling box fans, holiday lights etc... A short, and I mean 6 to 12" extension cable to get the Tradfri away from the outlet enough to unblock the second outlet is fine for what I will use it for. And then are plentiful, cheap, and common for computer usage. The ones I used are from Cable Matters are are at https://amzn.to/3z96OkP We use them a lot with UPSes and connecting SOHO grade equipment into switch / server racks and rack mounted UPSes or PDUs. But I digress...
Back onto the subject at hand. IF you are having drop outs due to the mesh not reaching, and you have Zigbee bulbs in the same space but are not acting as a repeater to the same Zigbee Network, then no, your mesh will be incomplete, and yes you should use Zigbee Smart plugs instead of just repeaters. Mostly so you don't loose function of an outlet.
And as stated above, and by others, be careful of the load you put on the smart plugs. Most are limited to 10 amps...
The Ikea Tradfri Wireless Control Outlets have been easy to pair on both Smartthings, and Hubitat, pretty much trouble free, and aside from the chunky form factor, and in the case of hte living room TV lack of ability to monitor power, have been what I needed which was basic outlet control and Zigbee repeater. And to top it off, have a super low price of just at $10.00
