Apologies if this has been discussed somewhere that I've missed, but are there plans to update this app for the oauth changes that Netatmo are making soon?
I honestly can’t recall if the app already supports oauth2. If it doesn’t, then I’ll be forced to abandon this app unfortunately.
I’m not a developer and don’t have the skills to update the authentication model. I initially took over the maintenance of this app as it had been abandoned by the original author, wasn’t in HPM and had some visuals I thought could be better.
I’ve also moved on from Netatmo after two of my modules died and it was cheaper to buy a whole new Ecowitt weather station.
Thanks for the reply! I believe Netatmo is changing the way it handles auth and refresh tokens to make it more compliant with the standards so it's possible the app's implementation already handles that. If not hopefully someone else might be able to look in to what's needed. Thanks for your work, most appreciated.
I've had a quick look at what Netatmo say they are changing, and a quick look at the code around the oauth handshaking. I think that the code already does correct handling of the oauth transaction and stores both tokens each time it refreshes, which if true means it should continue to work post May 29. Previously it seems Netatmo never changed the tokens after the initial auth and the changes would only be a problem if the code deliberately exploited that. Regardless, I expect it would be a simple change that someone (even me) might be able to manage if things stop working at the end of May!
The changes I made are mostly cosmetic. So if you are happy with it, don’t change.
I'm not a developer, just someone who can tinker around the edges of other folks code. As a result, I don’t have the skills to add that kind of support.
@dJOS I have used this app for a long time. I know it has changed the developers who work on it and that you have been "tinkering" with it most recently. I hope you still are.
For some reason, it stopped working on June 6. I have tried everything to make it work, including deleting everything. Now I can't get it to re install. I entered my old Client ID and Client Secret and signed into Netatmo. I authorize access, and it says it accepted the hubtat auth and to close that window and reinstall. It should not request that info again. Unfortunately, it does request all the info again. I can't get it to install. Now some of my rules are not working because my weather station is missing. HELP!
