It appears that the driver is having trouble communicating with the API service.
I was recently impacted by a Synolgy Threat Prevention update that impacted my Hubitat hubs ability to communicate with GitHub and Hubitat update servers. Once I put in an outgoing exception on my router, everything returned to normal.
I’m wondering if Netatmo do maintenance and take down their API service overnight AEST (Melbourne, Australia). I see regular errors around this time, and then they go away.
Shortly after midnight (pacific time) this morning, my Netatmo stopped reporting. The app and website say that the big module is offline. I've tried power cycling and I can even seen the SYN, ACK, FIN and FIN ACK in my tcpdump from my firewall. There are no API errors in HE and the app knows of my devices, but nothing is being reported. My second Netatmo in a different house is still reporting too. I even tried changing my wifi and location. Still nothing.
Anyone else having any issues in seeing their data?
Mines working ATM. I do find that every few weeks my indoor unit will stop communicating and so I put it on a Zigbee outlet and power cycle it when that happens.
Yeah. Both my units do that too so they are each plugged into a smart outlet with a rule that if the temp hasn't updated in the last 4 hours, turn off the outlet, wait 20 seconds, and power it back on.
I reached out to Legrand and spoke with their tech support. The first guy wasn't helpful at all. Basically said, "oh, you are on an old version of firmware and there's nothing we can do until that updates to the latest, which is v200." I was at v101. "Give us a call back in 10-15 minutes, after you let it upgrade the firmware. Had you changed your wireless network via the method I was trying to get you to, it wouldn't have factory reset the device." Well.... the way you told me was the same exact way I did it. So it would have reverted regardless.
Off my soap box. The second guy was helpful, to a point. He did care about the issue, but needed to escalate it over to the France team. Long story short, after a couple of hours of me digging through my firewall logs, trying to force DNS FQDN's to point elsewhere, the unit finally downloaded firmware v201. Waiting to hear back from support if there was an issue with v200 that bricked units or if it was fixed on the backend. My other Weather Station is on v200. The good news though, it's back online. Now just waiting for the other modules to report in.
My other unit is on v200 too. And everything on this unit was working until 12:09 AM this morning. My firewall logs show fetching a firmware and it shows the URL of fw.netatmo.net/firmware/... Strangely, on port 80. Maybe this unit was trying to upgrade to v201 and it went sideways. And maybe the hour ish of being unplugged was all it needed.
Per the non-helpful support rep. When you press and hold the top of the unit, until the blue/white leds flash, that causes a factory reset and it will revert the firmware too. I think this is why I went back to v101.
I had a recent issue with Synology's Threat Prevention module on my router swatting "suspicious traffic" from my Hubitat hubs to GitHub and the Hubitat update servers. I ended up needing to add exemptions for them (not firewall holes, just an ignore traffic from rule).
Im going to try updating my Indoor unit and see if it'll upgrade to v201.
Yeah. I looked through my logs to see if the Threat Prevention in my Check Point firewall was blocking something too. I didn't see anything, but did add an exclusion just in case. The only error I see is within HE and pertains to the wind angle of a NULL object. Totally unrelated to my issue.
There's no way that I am aware of to force an upgrade. I would say unplug it for >15 minutes. I think it does a fw check upon power up. I'll update here when I hear back from Netatmo about my versioning of 200 vs 201.
No real update from Legrand support outside of "some network work was done that could have impacted you." But no details on that. And nothing about the firmware 200 vs 201. My second weather station is still on v200 as of rn too.
Did your Netatmo Connect app disconnect? I might run through that setup in the app again and confirm that you are seeing all the devices.
Also not sure if these are related, but when I was having issues with my Netatmo connecting a few months back, I put an exclusion in my firewall to not prevent any outbound threat prevention stuff. I later removed that and my connectivity issues came back. I added the exclusion back and (knock on wood) haven't had an issue since. I didn't look at the Netatmo Connect logs during the issue.
Can you please modify the code to include the URL of the call that is causing the 403 error?
I found https://api.netatmo.com in my router logs at the time of the error but the connection was allowed so it appears there is something wrong with the API call to Netatmo?
Can someone please tell me the best way to reconnect the app to Netatmo, after changing my Netatmo password? When I go to the Netatmo Connect app, it says it is connected, but the logs show that it obviously can't refresh since the password changed. I was hoping to not have to remove and then reinstall the app. Thanks.
