When you press and hold while plugging the outlet in, this does a factory reset. If you did that procedure it would explain the blinking light and the fact that you had to resync the zigbee portion.
You may need to reboot the hub at this point. Wait at least 10 minutes after the reboot before attempting to pair again. This allows the zwave/zigbee netwoerk time to stabilize. Then try my procedure again.
Unplug---Wait 30 seconds---Start zwave pairing process on the hub---Replug---after 3 seconds start thumping away
Kato,
I had Zigbee/Z-Wave backwards on my first response...corrected now. Once I had paired the Zigbee, a few paired Z-Wave without any additional button presses, the last ones I performed the 8-button press 20-30 seconds after plugging the device in. (I initiated the z-wave pair on the hub prior to the 8 button presses.)
I paired my zigbee on the 3210-L I have when I first got my HE, however did not pair the zwave as I currently do not have anything z-wave on that side of the house. I went out to pair it just now and it did not detect. I moved it near the HE and pressed the power button 8 times and was able to include it. I then moved it back to it's original location and ran a z-wave repair.
Don't forget to try what @stephack suggested and reboot the hub. I now have over 20 of these plugs and usually reboot the hub after 3 failed Z-wave pairing attempts. Also it helps to get the plug close to the hub. It doesn't like pairing with more than 2 hops with my observation.
Ok, well, let's say I did almost everything recommended. I just moved it closer, probably only 5-6 ft closer and it found it. Super touchy...but it worked!
So it was the 8 super fast pushes of the power button while in z-wave pairing mode and being very close to the hub that worked? Do you know which firmware version your plug is on?
Correct. I moved it closer, probably 4-5 feet away from the hub, and pressed the button 8 times (it seemed like 10 times always turns it off) and it paired.
Is there a way to see the firmware version in hubitat? I paired them about two weeks before iris went offline so I assume they had the latest as I doubt Lowes really cared about doing anymore software updates for their devices.
Ok, next outlet didn't work. Tried moving it closer, and following all of the steps I did before but no luck. So then I remembered the only other thing I did with the previous one and that was (unintentionally?) doing the factory reset by holding in the button when I plugged it in. So I did this, the outlet reset and went back into pairing mode. I paired it to Zigbee, then did the ZWave and it worked. So here are my steps that I took:
Moved the outlet 4-5 feet next to the hub.
Unplugged the outlet.
Started Zigbee pairing on the hub.
Held the button and plugged it back in.
As soon as the light on the outlet came on, I released the button.
The device was found as the previous outlet with name and everything already there. I made sure it was saved by going into the devices tab in the hub app.
Unplugged the device. Waited 30 Seconds.
Started Zwave discovery.
Waited 5-10 seconds.
Pressed the button 8 times very quickly.
The device showed up. I saved it. After moving it to the original location, I did a ZWave repair.
I have 3-4 more of these so I will try this same process on those.
So it looks like this process works but when I tried the next one, it assigned an id of 0E to that device. I fat fingered something because I am using my phone to do this and it hung and didn't finalize the addition of that device. When I repeated the process, it assigned an id of 0F to the same device. What happened to the other id? Is it ghosted somewhere in the system or does it not matter? I looked through my device list and don't see anything with the id of 0E.
All but one paired the Outlet (Zigbee) right away, I did replug one once. That may have been my impatience and expectations after reading some of these posts.
Three of the Repeaters (Z-Wave) paired with 8 fast button presses without issue. On two I did the following once each:
One was paired in place, the other four in the same location and then moved them. Z~Wave repair is running hoping my sensor issues (intermittent response failure) get resolved.
